Question about Dryers
Gas dryer turns but there's NO heat : ( What do I need to replace?
  • GARDENMAN Feb 02, 2008
    TGDX640JQ2 DRYER RUNS BUT WILL NOT HEAT. TOOK BACK OFF, CHECKED VENT PIPE, RAN DRYER AND AIR OUTPUT GOOD. i HAVE NO KNOWLEDGE OF GAS DRYER OPERATION. I AM HANDY WITH REPAIRS. IS THERE THINGS I CAN CHECK OR ISOLATE.
    THANKS FOR ANY HELP AND DIRECTION.
    New Friend:
Remove the front panel. Look for an orange glow when the dryer starts up, if so, the igniter is fine, then it is most likely the solenoids
Posted on Jul 08, 2010
    President:
  • 1,314 Answers
Either the igniter or the two solenoids on the safety valve are the most likely culprits
Posted on Jan 24, 2008
6ya staff
SOURCE:
My gas dryer runs but with no heat
Most likely you need to replace the heating element that ignites the gas.just turn off the gas line unplug the dryer and remove the front cover then you will see on the bottom right there Is a heating element bolted to the gas valve with one single quarter inch bolt.You can either remove it and inspect it for little hairline cracks or check for continuity with a multimeter.If you see a crack or have no continuity replace the ignighet
Apr 15, 2014 | Kenmore HE5 Steam 7.5 cu. ft. Electric...
Dryer only works on 1 setting and is not heating
If your dryer is not heating assuming is a gas dryer. It could be due to The electrical fuse igniter is not working or no gas is going in. Need to remove the front bottom cover and check that the fuse is igniting when you turn on the dryer. You should hear a clicking noise just before the igniter turns red ( glowing) to receive the gas and create the flame to then produce the heat. If you are not able to see the fuse/igniter conduct this process, you might need to replace it.
Nov 16, 2013 | Kenmore Dryers
Kenmore gas dryer no heat.
the automatic ignitor is bad and needs a replacement
Feb 05, 2010 | Kenmore 73952 Gas Dryer
KELVINATOR GAS DRYER. IGNITORLIGHTS UP THEN TURNS OFF. NO HEAT.
the ignitor needs to be glowing white hot not orange. it is not hot enough to ignite so you need to replace it.
Oct 04, 2009 | Frigidaire FGQ1442ES Gas Dryer
Gas dryer does not heat
The reason to this problem is due to the faulty
heating element.It needs to be replaced.
Sep 01, 2009 | Frigidaire GLGR331A Gas Dryer
Whirlpool gas dryer heats for one cycle, then cool air only.
Yes , replace the coils . Should take care of the problem .
Jul 13, 2009 | Whirlpool Dryers
Dryer turns on and spins, but will not heat and dry clothes
Here is a quick course on the reasons why a gas dryer won't heat. If you are not mechanically inclined you will have to get a repair man because none of these reasons are quick fixes.
If your dryer doesn't heat, check these:
Igniter
Gas valve coils
Thermal fuse
Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too.
The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one.
Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
May 21, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Kenmore gas dryer that turns but does not heat up
mostly you need a thermal fuse,,take the back of ,,maybe 12 1/4 nut driver screws,,you will see a little white fuse,,replace it..onthejob
Jan 12, 2009 | Kenmore 74902 Gas Dryer
Kenmore 70 series electric dryer runs but won't heat up?
Hi!!! If the unit is electric your heating element needs to be replaced if its gas then replace the coil boosters located on top of the gas valve..Good luck..
Jan 04, 2009 | Kenmore 73952 Gas Dryer
KENMORE GAS DRYER - MYSTERIOUS HEAT PROBLEM
Most times I replace the coil assy. on gas control valve. OR could be the sensor.Or both.
Nov 27, 2007 | Kenmore 73952 Gas Dryer
Dryers Logo
175 people viewed this question
Top Dryers Experts
Marvin
Marvin
jimorris77
