Question about KitchenAid KERC601 Electric Kitchen Range
Oven sparking problem
I used the broiler on my oven the other day, and when I turned on a burner to boil some water, it threw the circuit breaker. I ran downstairs and flipped the breaker while my sister manned the oven. When I flipped the breaker, the oven sparked right inside the control panel near the knob and blew the circuit breaker. I can't turn the circuit breaker for the oven on without it sparking and blowing the breaker for the whole house. Any suggestions?
  • 2 more comments
  • steph2000 Jan 24, 2008
    Ah shoot. I'm at work.
    What do you think I will find? I know there was a burn mark on the wall by where the cord goes into the back.
  • steph2000 Jan 25, 2008
    yes! the power cord is burned up.
    so i can just change that out?
    thanks!
  • steph2000 Jan 28, 2008
    You were right--It was the power cord. My sister's boyfriend put a new one on and tightened everything up back there and it works now.Thanks!!
  • robert samples May 11, 2010
    first un plug the oven pull the back panel and tell me what you find
    President:
  • 1,314 Answers
I think you will find the power cord is burned this happens if it wasnt tightend up properly and gets loose turn the oven breaker off before you pull it out
Posted on Jan 24, 2008
  • robert samples Jan 25, 2008
    if that's all that's bad you can sometimes you have to replace the terminal block too can get all that and a new cord at Lowe's home depot make sure the nuts are fairly tight as that's what causes this don't forget my four boxes if this fixes it it helps the site
  • robert samples Jan 28, 2008
    well you just too welcome
The bottom element give out in the oven, removed it. Waiting on one. I was using the top burner on the stove. Forgot about having the element out. Turned on broil. Had a spark, now burners won't work.
check breakers and fuses --if power good to unit will need to start going through the circuits the broiler shouldnt have sparked with out element unless the connector is grounding out against something or damaged when taken out will need to look and examine the connection
Dec 15, 2016 | Kitchen Ranges
Why oven not heating
Bad element, bad switch or other electrical problem. You could double check switch by turning on broiler element to see if that
gets hot. If so then either oven thermostat, or element. Did the circuit breaker pop off and then you reset? So there is a short somewhere, especially if it happens again. The above test with broiler element could verify power to oven. If it pops the
circuit breaker again. You need a service technician. Usually the oven requires a dedicated wire to the oven. Don't use the oven again until the problem is resolved. There's a slim possibility
that the circuit breaker needs to be replaced. How long did you use the oven? If a long time circuit breaker is more likely because
when they begin to fail they get too hot and therefore pop. You will need an electrician to change the circuit breaker if that is the problem.
Feb 13, 2015 | GE JKP90 Electric Double Oven
Oven burner and broiler burner don't warm at all. Stove top burners work. Clock display normal. When turned on lights indicate oven on and preheating (normal). I have reset the main circuit breaker with no...
Hi Brian, thank you for your post!
Sounds like the either both bake and broiler element may be faulty or a potential wiring failure to the elements. You may want to connect with a local servicer who will be best equipped to pinpoint the problem. If you don't know a qualified technician, you can use the service locator option on the manufacturer site to find one near you.
Sep 15, 2013 | Frigidaire 30 in. Electric Gallery Series...
The broiler keeps turning on automatically in the lower oven, along with a loud beep. It has done this periodically when boiling water on the back burner. Now it is doing it constantly.
There are 2 possibilities
1) the touch pad is bad so even the slightest thing makes it thinks its being touched to turn on
2) a relay on the control board is sticking and even a small amount of vibration such as turning on the surface burner is causing it to come on
So replacing the touchpad and or control should fix it. Im leaning toward the touchpad
Gene
Aug 02, 2011 | Maytag Ovens
Last week when my wife turned on the oven a flash and popping noise happened and the circuit breaker popped. I ordered a new control board part number WB27T10229 and installed it. When I turn the circuit...
The broiler is a different element. Sounds like your main (bottom) element is out. Turn off breaker and remove. To test, use an ohm meter and ohm out the element. If yuor meter reads 0 or OL (open load) your element needs to be replaced.
May 19, 2011 | Kenmore 95882 / 95884 / 95889 Electric...
Whirpool Range suddenly tripping the circuit breaker
It could be one of the elements is shorting out causing the breaker to trip. Try using one burner at a time to see which one causes the short.
Aug 21, 2009 | Whirlpool RF262LXS Kitchen Range
GE glass top and oven are not heating?
I have an electric oven that is turning on but not heating up. The oven, broiler, & stove top are not heating up. Any easy solutions to this?
Jul 18, 2009 | GE Profile JKP18 Electric Single Oven
Burners won't turn on
first this i would check is the  circuit breaker in the house, stoves work off of a 220v dual breaker. one breaker may have tripped. the oven may still work but the burners will not.
Jun 28, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Ignition sparking repeatedly
I have a Creda gas stove ,yesterday some water boiled over. I have a continuous spark ever since and the stove is not even on. Is there any way to reslove this without calling a repair person?
May 01, 2008 | Cooktops
Open Questions:
See all KitchenAid KERC601 Electric Kitchen Range Questions
KitchenAid KERC601 Electric Kitchen Range Logo
712 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
