Question about Memorex Mega TravelDrive 4 GB USB Hard Drive
Memores 4G Mega Traveldrive doesn't read
I have a Memorex 4G Mega Traveldrive that just stopped working one day. When I plug it into my USB port, it does not light up and doesn't read. Any suggestions?
  • 1 more comment
  • atiati Nov 28, 2008
    hi,i have mini memorex travel drive 1 GB, the problem is that when i connect my flash drive, the autorun doesn't come up , also when i click on the icon to open it, it says that i need to format my drive,,, well,,,, i don't want to format my flash,,, cuz i have important files on it,,, how can i fix this problem?
  • Anonymous Dec 14, 2008
    same for me... but for me its the rotating traveldrive
  • Anonymous Jan 14, 2009
    will not light up
Step one is try it on another computer. This will seperate issues....is it the drive or the USB port (hardware or software actully in both cases are possible.
Step two, if it works elsewhere, is to check under device manager, and reinstall the driver (if not embedded in the drive which most are)....both USB and the disk.
Step three is to download (again assuming it did not work) the disk diagnostics from Memorex (most drive manufacturers have a host of utilities and they may exist even for flash drives - they use them internal to their mfg operations as well). Check to see if it's good. It is possible that it just lost the embedded driver by the way in which case you need to put it back on the drive...haven't done that but assume it's possible and available.
Can give you more "stuff" to do but this will probably solve the problem....and I am guessing it died. If it did they are not expensive...and even cheaper if you really don't need 4 gb...few people do for personal and even work data.
Check at pricewatch.com (not a seller) for pricing. This site is used by GEEKS United for finding "stuff".
This gives you some options.....Tango
Posted on Jan 25, 2008
6ya staff
SOURCE:
I cannot get my Memorex 64GB USB flash drive to open on my computer. I have windows 7 and when looking at my control panel and under drive status, it says this device cannot start (code 10). What do I...
Trouble shooting steps I would probably take:
1) Power cycle the computer (unplugged), and try it again, when it is COMPLETELY booted.
2) unplug it and plug it into a different port(s).
4) Try it on a different computer (both PC and MAC, as it could be a formatting issue) (if it doesn't work, entertain the reality that I may have lost everything and may have to format the drive and/or buy a new one)
Oct 22, 2013 | Memorex Mega TravelDrive 4 GB USB Hard...
My memorex usb 2.0 4gb traveldrive is reading as full when there is nothing on it. how do I clean it up or reformat it so i can use it again?
You can reformat it by opening up My Computer, right-clicking on the drive, and clicking format. I recommend formatting your drive as NTFS as it will give you an option.
May 02, 2011 | Memorex Mega TravelDrive 4 GB USB Hard...
I have a Memorex Ultra Drive connected via USB to a Windows XP machine. It shows up in My Computer as a folder but then disappears again. It does this repeatedly. The drive is formated as a FAT32. How...
As you have described that your Memorex Ultra Traveldrive re-appears repeatedly, indicates that the communication between your computer and your external hard drive is intermittent. The FAT32 format does not produce these types of issues. What we can do first is identify what causes the problem.
Assuming that the hard drive in your Memorex Ultra Traveldrive is in good shape:
Troubleshooting Method #1. Try connecting your Memorex Ultra Traveldrive into another USB port. If the problem persists, use another USB cable for your external hard drive. If the problem still persists, you will have to replace the external casing of your external hard drive. If your external hard drive works with the other USB port perfectly, most likely, the USB port where you originally plug into of your Windows XP machine needs to be checked. That USB port might need some repairing.
Troubleshooting Method #2. Try connecting the external hard drive into another computer and perform the same troubleshooting as Method #1. If your external hard drive works with other computers perfectly, most likely, the USB port where you originally plug into of your Windows XP machine needs to be checked. The USB port might need some repairing.
If the problem only occurs with your Windows XP machine, assuming all USB ports are in good shape, your Windows XP needs to be checked for some software issues.
I hope this works for you. Kindly reply/comment for further assistance. Good Luck!
Thanks for using Fixya!
Mongkey
DELL Tech ID #456563
TIPS: Is your computer slow? This might help
http://www.fixya.com/support/r8158906-diy_manual_pc_tune_up
(for Windows only)
Apr 06, 2011 | Memorex Ultra Traveldrive - 160GB USB Hard...
Need software for 512mb traveldrive using Windows 7
The TravelDrive is a "plug-and-play" device, and Windows 7 supports Plug-and-Play.
So, any device-drivers are included, and will automatically be used when you connect the TravelDrive.
What problems are you having? Symptoms? Error-messages? Does the TravelDrive work in some other computer? Does any other USB device work in the USB port that you are using for the TravelDrive?
Dec 18, 2010 | Memorex Mega TravelDrive 4 GB USB Hard...
How to use
you can download your memorex mega travelDrive 4 manual from this link
http://www.memorex.com/PageFiles/1180/manual.PDF
and learn well how to use hope that was helpfull
Sep 11, 2010 | Memorex Mega TravelDrive 4 GB USB Hard...
MY VISTA NOTEBOOK WON'T RECOGNIZE THE MEMOREX 4 TRAVELDRIVE
Lb44145 ,when you got the item did it come with the disk? And if you have the packaging does it say 'Vista Compatible' if not i would recommend you buy one which is vista compatible.
Good luck,
Ben
Feb 02, 2009 | Memorex Mega TravelDrive 4 GB USB Hard...
Mini memorex traveldrive 1GB
To make any Drive Work formatting is a necessary step. If you don’t do it then it will never work.
Dec 19, 2017 | Memorex Mega TravelDrive 4 GB USB Hard...
Detected With Error Code 10 in Device Manager in Windows XP
Have you tried also plugging in the DC usb cable into the traveldrive? I was having problems where my computer wasn't working properly with my drive unless I had it either plugged into a powered usb drive/hub or I had the DC plug in as well.
Jun 04, 2008 | Memorex Ultra Traveldrive - 80GB 80 GB...
Memorex Mega TravelDrive 4 GB USB Hard Drive Logo
956 people viewed this question
Top Memorex Computers & Internet Experts
Ekse
Vernon Taylor
Are you a Memorex Computer and Internet Expert? Answer questions, earn points and help others
