SOURCE: there is a water leak
I am the original owner of camry xle 1998 with wet floors. In 2000 I had drivers side door seal leaking at welt. Removed old door seal and new weather strip on drivers side installed. The door panel was never wet, but wet at bottom of door where there are drain holes...slowly leaking under carpet.
In 2001 later water again. Coming from overflowing A/C evaporator-drain plugged/ tank full of debris. Removed evaporator, cleaned + drain cleaned.
In 2003, driver door seal against window rotted. Removed door panel and found leak at window belt molding at the mirror joint inside + out. Lots of mold under carpet needed to replace! Made a fuss at dealers for reacurring problem and they replaced the carpet for free.
SOURCE: water leak on fwd passenger side after every rain storm
If your car has a sunroof, there are drains from the front corners of the sunroof, and they drain down the sides of the windshield pillars, and then empty out on the ground.
What I would do is open the surnroof, and pour water into the front corners, and then oobserve where the water drains out. If you have a difference in water drainage between the left and the right sides, I would think that you may have loose sunroof drain. They commonly come loose at the sunroof corners. This will allow the water to pass down the windshield pillar, and onto the floor.
Also, I would check the condensate drain tube for blockage. Pull back the carpet, under the glove box, and fins a black hose that pokes thru the firewall. Pull it out, and see if it is blocked internally. If this tube is clogged, water will build up in the heater box, as the black tube is the drain for the heater box.
One of the two above solutions will cure your problem. I see both quite often.
Thanks for choosing FixYa for assistance.
SOURCE: water leak on fwd and back passenger side after every rain storm
pull your carpet up near the leak area and look for muddy body seams. it is possible one of the factory body seams are leaking- possibly in the cowl(under wipers) area, especially if it leaks when the car is sitting. there will be dirt/mud around the seams that are leaking. also you can check door seals by running the car on HIGH DEFROST with all doors and windows closed. spray around with a 50/50 soapy water solution. obviously bubbles will form around your leak.
