How do i put a chain on the chainsaw - Televison & Video
    Scholar:
  • 152 Answers
Set the saw on a bench with the bar to your right. Toward the back of the bar there will be two bolts. Remove them. You should be able to remove the side cover. Observe the bar and how it is mounted. There will be a small hole in it with a little metal piace sticking in it from the other side. This is the tension adjuster. Remove the bar by pulling it toward you. You will need to push it back toward the sprocket in order to slide the chain off.
Now you should be able to see the adjuster more clearly. Clean out any saw dust you can see that was behind the cover.
Take a good look at the adjuster. There is a screw that goes in right next to where the bar would have come out. this is what moves the sdjuster. Counter clockwise will loosen it. Clockwise will pull the bar out further tightening the chain.
To ease installation of the new chain, give it a few turns couter clockwise.
Put the new chain on the bar. Ensure that the sharp parts of the teeth on the top of the bar are pointing away from the saw.
Hold the bar somewhat in position, but at an angle and slip the chain around the sprocket.
Next, hold the bar in position where it goes and slide it away from the sprocket until the udjuster tang comes through the hole in the bar.
If it is too tight to do this, adjust the tension until you can get the tang in the hole.
Put the side cover back on and put on the nuts, but do not tighten them very much. just finger tight for now.
adjust the tensioner while snapping the chain like a rubber band until it returns to the bar, but can still be pulled away slightly.
Once this is done, tighten the nuts on the side cover completely.
Once the chain heats up for the first time it may get tight on you. When you let off of the throttle the chain binds up. If this happens, loosen the two nuts until they are finger tight again, and turn the tensioner counter clockwise. Do the same test, snapping the chain until it is back in adjustment.
Posted on Dec 22, 2009
Set out the chainsaw parts in front of you. Make sure the chain is facing the right way to cut wood; the teeth should be facing away from you when you are holding the chainsaw.
Secure the chain around the sprocket (a cog-type part found near the chain tension nipple) and align it along the grooves of the bar. You will see a hole for the chain-tension nipple on the end of the bar. Line these up so the nipple fits in the hole on the bar. Pull the chain to tighten it, using the screw to achieve the desired tension
Place the cover plate back on top of the bar and line up the cover-plate housing screws with their corresponding screw holes
Screw the cover-plate housing screws back in and tighten. Test the chain to make sure it spins freely when pulled.
Check the chain to make sure you can lift it about 1/4 inch, so it isn't too tight to spin while cutting wood
SOURCE:
What is the chain brake an where
not on the older chainsaws
newer ones it s normally the black lever you hold
Check the Chain Brake
Make sure the chain brake is working properly by putting the chainsaw on a stable surface. Release the chain brake, squeeze the throttle and then activate the chain brake by pushing your left wrist against the kick back protection without releasing the handle. This should cause the chain to stop rotating immediately.
source
http://www.tractorsupply.com/know-how_home-garden_outdoor-power-equipment_chainsaws_the-basics-of-using-a-chainsaw-for-beginners
can be part of the centrifical clutches
Apr 30, 2016 | Garden
My Poulan Pro PP5020av 50cc chain saw won't start
I had a popular. If you put the chain on to tight it won't start.
Nov 08, 2014 | Poulan Garden
How do I put the chain back on a chainsaw?
you need to loosen the nut on the side of the chainsaw and then take the cover off. Remove the bar and take the chain off. Then put the chain back on the bar being careful about the direction of the chain. Place the chain back over the sprocket and lower the bar back onto the plate making sure the hole lines up with the adjusting mechanism on the cover. After you line up them up put the nuts back on and loosely tighten them. Adjust the chain where it is almost tight and then tighten up the nuts.
Sep 20, 2014 | Poulan Garden
Troubleshooting chainsaw
You need to clean the chainsaw areas where the dirt has gone with a water hose. You may have clogged up the oil thing that puts oil on the chain. Hope this helps! And yes, dirt will make a chain dull. You might have to replace the chain or have it sharpened.
Jul 20, 2014 | Echo Cs-310, 14" Replacement Chainsaw...
Husqvarna Chainsaw Chain stopped turning
Have you take the chain brake off..? This is a band which grips the clutch drum and must be disengaged before use.
Check chain tension, this shouldn't be too tight.
Did you also put chain oil in the oil tank.?
Mar 09, 2013 | Husqvarna Garden
Describe your sears 18"
I put a new bar and chain on my craftsman 18" chainsaw because the chain keeps coming loose. I am still having the same problem, after running 10 seconds, the chain falls off.
Sep 11, 2011 | Craftsman sears 18" Chain Saw Chain (...
How to change a chain
First of all, make sure the saw is off. Also, before removing bolts, make sure the chain brake is not engaged (the chain should move freely).
Remove the guide bar side panel. Using a scwrench or wrench, unscrew the nuts and remove the plate to access the chain.
The side plate on most chainsaws will be held on by two nuts. Loosen the blade adjustment screw (a pin that is usually driven by a screw and pushes the blade out from the chainsaw to keep the chain tension tight).
The old chain is ready to be removed now that the sprocket plate is off of the saw. Pull the nose of the chainsaw's bar away from the chainsaw to release it from the tensioner.
Remove the old chainsaw chain.
The chain will easily remove from the guide bar with all that slack in it. Note the orientation of the cutting edges of the chain so you put the new one on the same way.
Pull the drive links out of the guide bar and slip the other end of the chain around the clutch drum.
Steps to Install a New Chainsaw Chain
Thread the new chain onto the saw.
Carefully thread your new or recently sharpened chainsaw chain around the chainsaw's clutch drum, making sure that the drive links engage in the sprocket.
Thread the rest of the drive links into the guide bar and around its nose, making sure all links are in the guide bar slot.
Align the guide bar.
With the chain properly threaded along the clutch drum and guide bar, put some tension into it by pulling on the nose of the guide bar away from the chainsaw.
While pulling the guide bar, make sure to seat it onto the saw's adjustment pin.
Replace the side plate.
The side plate is ready to go back on as long as the guide bar is properly positioned beneath.
Replace the plate and the nuts that hold it into position, but do not tighten the nuts down all the way yet. The guide bar must be allowed to move a little while the chain is tightened to the correct tension.
Tighten the chain to the correct tension. Use the tensioning screw to the side of the guide bar to adjust the tension on the chainsaw chain.
Finish tightening the side plate nuts.
The chainsaw chain replacement is now complete.
And here is a great overall reference guide to keeping a chainsaw sharp and running. Sharpening a chainsaw chain is a great way to extend the life and is less expensive and easier than replacing a chain. There are small grinding tools (like a dremel) that can be run off a small 12v battery or your vehicle battery that allow for quick 'tune-ups' on your chain if you are out cutting and need to sharpen your chain.
http://www.pcta.org/pdf/STUCHAP2_web.pdf
Aug 28, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Need to know what kind of oil to put in ryobi chainsaw
If it is an electric chainsaw (not gas powered) then the only oil you need is chainsaw bar oil, which lubricates the chain and bar during use (self feeding system). This goes into the chamber at the top of the saw. You can buy chain/bar oil for chainsaws at any good hardware store or outdoor power equipment store. You can use any brand of chain bar oil, most are pretty good.
If it is a gas/petrol operated model, I will need to know the model number to advise on that.
Jul 03, 2009 | Ryobi 18-inch Electric Chainsaw Chain Saws
Fixing the chain back onto a Ryobi chainsaw
pull the barcover and bar off and you will see the clutch put the chain back on the clutch and put the bar back on and run the chain down the bar and put the cover back on and you will see a little screw in the bar cover are in front of saw by bar tighten that screw until slack is out of chain then tighten bar nuts.
Apr 04, 2009 | Garden
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
