Question about Canon PC-940 Black and White Copier
Canon PC-940 copier
When trying to copy, we end up with copies that have a wide white bar running through the middle. How do I fix this?
Take the toner cartridge out and shake it. Then put it back in and see if it's better.
Posted on Feb 25, 2008
Sounds like white out on the scanner. clean all glass and slit glass
Posted on Jan 24, 2008
Canon c130 copier stuck in middle of copy
Hi Ben,
Please Watch This video and fix your issues.
In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On : Canon Printer Support
Mar 04, 2014 | Canon C130F Black and White Copier
When making copies, there's a line running through every copy-- along the entire length of the paper
If line appear on drum scratched change drum & cleaning blade.otherwise change only cleaning blade
Mar 24, 2013 | Canon PC-940 Black and White Copier
Copy has a white 4" strip down the middle I have a canon k940
PROBLEM WITH THIS COULD BE LASER SLICK GLASS CLEAN, ALSO CLEAN TRANSFER UNIT
Oct 20, 2010 | Canon PC-940 Black and White Copier
I have a Canon PC 940. The copies are coming out with black lines ( 1/2 inch wide ) on the sides of the paper. Do I need to get the copier cleaned? Thank you.
Could be optics needing to be cleaned. First I would rule out the toner cartridge. If you have a spare swap it out or remove your current cartridge, turn it over and slide open the "gate" that covers the drum cyclinder. The drum should be clean all the way across it's surface. If you see toner on each end then that is where your dark sides are coming from. If the drum is clean then most likely you have dust building up on the optics mirrors. One test for this is to manually lighten the exposure control on the operation panel and then recheck your copy quality. This may cause the rest of the copy to be light but if the dark sides goes away then your optics are dirty.
Good Luck and Thank You for using Fixya.
Aug 11, 2010 | Canon PC-940 Black and White Copier
Copier wrinkles copies
It cuold be that paper has too much moisture or you nned to replace press roller bushings alonh with cleaner and fixing film
Apr 30, 2010 | Canon PC-940 Black and White Copier
Black line through the middle of each copy
Hello sir; There have two ways to check it; 1, if you make copy throught by ADF, then you have to clean a piece narrow glass at the end of plateform, 2, if no. 1 case not apply to you, then you have to change drum cleaning blade.
Oct 15, 2009 | Canon PC-940 Black and White Copier
PC 940 Canon Copier help with cleaning
Hello sir; Discharge corona unit dirty it cause this problem, got to be discharge corona wire covered by tone, clean outby rubbing alcohol,it will take care your problem.
Feb 17, 2009 | Canon PC-940 Black and White Copier
Dirty Copies and Black Line in Middle
the electrostatic drum probubly whent out if it was a cheap copier get a new one if it was expensive have it serviced or replace the drum yourself
Jan 22, 2009 | Canon PC-940 Black and White Copier
Canon PC941 Copier: Wide white bar down middle of copies
Try replaceing the cartridge the toner has run out.
Any problems please get back to me.
Thank You
Mar 25, 2008 | Canon PC-940 Black and White Copier
Canon PC-940 Copier
There are no fiber optics in the copier. It has 6 mirrors that send the image to the drum unit. Did you try to clean the copyboard glass? Also, do the marks move up and down the page? Also, have you replaced the drum cartridge recently? Pull the drum unit out can you see track marks on the drum it self. If not I would have to say it may be comming from the fixing ass'y, the hot part of the copier. Try to use a dry rag and wipe up any loose toner in the paper path then try to run some blank pages in the copier this may clear up the problem...
Mar 04, 2008 | Canon PC-940 Black and White Copier
Canon PC-940 Black and White Copier Logo
159 people viewed this question
old marine
old marine
