Question about RCA Lyra RD2765 MP3 Player
Rca mp3 player h125
File system corrupted then shuts down
  • 4 more comments
  • Anonymous Feb 29, 2008
    turn on mp3 player an rca will come up then it will say file system corrupted. then it will shut down.
  • mustanglover Apr 06, 2008
    turn on RCA appears then it says file system corrupted then shuts off. My Copmuter does not recognize that it is hooked up.
  • Anonymous Apr 12, 2008
    when i turn it on it either says file not found or system corrupt
  • Anonymous Nov 28, 2008
    I also have the same problem
  • Anonymous Dec 01, 2008
    when i turn it on, it says file system corrupted. when i plug it to the computer, it WONT recognize it.
    after i turn it on, it turns on and off automatically
  • ladkins4 Jan 07, 2009
    What do ou do? Screen says File System Corrupted. HELP?
    rca mp3 H125
Press the power on and the center of the wheel and the M buttons at the same time after you turn it on. your computer will now recognize it. http://support.rcaaudiovideo.com/select.aspx?u=downloads then go here and get the download for your mp3 player. hopefully it works for you.
Posted on Mar 15, 2009
HOW DO I REFORMAT IT??????
Posted on Mar 05, 2008
No whootsley, you cant do that. the computer wont even recognize the mp3 player when its plugged in.
Posted on Mar 02, 2008
  • 121 Answers
Plug it into your computer and re-format it
Posted on Jan 24, 2008
6ya staff
SOURCE:
My RCA H125a 5gb won't work and reads "files
You can reset your player at any time if there is a problem by pressing and holding the On/Off button for 10 seconds. I will attach a link to the manual and support which further explains the device.
Thanks for using FixYa.
http://voxrightnow.custhelp.com/app/answers/detail/a_id/9514/~/operating-the-rca-h125-digital-mp3-player
May 30, 2011 | RCA H125 MP3 Player
It says 'File system corrupted' I don't know what to do.
back up your files, format the storage of the player, put the back up files back to the player
Apr 09, 2010 | RCA H125 MP3 Player
try getting the firmware and updater from the manufacturer and reloading the firmware
Sep 23, 2009 | RCA H125 MP3 Player
RCA Lyra H125
Hay 1 solución segura hay que desarmarlo y con tooooodo el cuidado del mundo sacal el disco duro o microdrive, hay unas computadoras que tienene la ranura para el micro drive (md) lo conectas ahy y lo formateas, el problema que yo tuve es que tuve que conseguir la carpeta lyra_sys que se encuentra oculta en el mp3.
Asi que si alguien tiene la carpeta, podria facilitarmela.
Gracias
Dec 26, 2007 | RCA Lyra RD2763 MP3 Player
Rca H125PA mp3 player
I had the same problem and went through RCA support to get a solution which (to my surprise) actually worked. Here's what you need to do. Connect your USB cable to your computer but do not connect to your mp3. Hold down the toggle switch on the mp3 while turning it on. Then insert the other end of the USB cable to the mp3. This should allow your computer to recognize the mp3.
Now go to website: support.rcaaudiovideo.com (no www. prefix). Go to "software updates". Click on "mp3 players" a couple of times and then your model "H125". Then click on "H115 and H125 Lyra Hard Drive Upgrade Utility" and follow the directions from there.
Jerry
Nov 13, 2007 | Audio Players & Recorders
RCA H125 MP3 player
Renee,
Jerry
Nov 12, 2007 | RCA Audio Players & Recorders
RCA H125 File System Corrupted
I've had this problem twice now and fixed it once. I'm in the process of fixing it again. Here's what you do, and this is a slow process so have some patience with it. Hook it to your computer then power it off. When you power it back on, with the cord still connecting it to the computer, hold down both the front buttons and the power button. You should now see it saying connecting. It will take a LONG time for your computer to recognize the device and give you access to it in My computer. Once it does, you can then remove the file system and replace it.
Jun 07, 2007 | RCA (T120PAK12) VHS Tape (12-Pack)
RCA Lyra RD2765 MP3 Player Logo
114 people viewed this question
Top RCA Audio Players & Recorders Experts
Ekse
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
