Question about GE WBSR3140DW Top Load Washer
Loose noisey tub
G e top load old style washer
  • 4 more comments
  • gilpen Feb 21, 2008
    I have a similar problem with my GE WWSE5240GOWW washer that just went out of warranty 20 days ago. The tub is loose and flopping around. Any suggestions?
    Thanks,
    Gil
  • Anonymous Nov 23, 2008
    does wash clothes
  • 19bloom Dec 20, 2008
    My washer makes a loud knocking sound only in the rinse part of the cycle. I am assuming a loose tub, because the tub seems loose when I open the lid to stop the cycle (and the noise). It is a serious issue because the washer has even moved a couple of inches due to the loose knocking tub.... please help! This is a GE Top load washer as well.
  • Dorothea Moore
    Dorothea Moore Dec 20, 2008
    tub leans to one side and is noisy when spinning
  • Anonymous Dec 31, 2008
    My tub is loose, How should I go about repairing it? Thanks!
  • mtroe Jan 02, 2009
    How can i get the instructions from solution #1?
  • 240 Answers
This is probably a normal GE washer tub issue. Problem is, you have to remove the inner drum to repair it. Before we go through all the instructions, let me know if you want to take this on yourself. Will need a good sized tool chest to do the job (1/4" and 5/16" nut drivers, screwdrivers, hammer, good sized pipe wrench, torks bits, etc). Let me know and we can go from there.
Posted on Feb 13, 2008
Gilpen, call the customer service number, your warranty will likely be honored. Sounds like the nut that holds the basket on backed off. Pull hard on the agitator to remove it, then remove the airbell. You should see a large nut at this point, if loose it, can be retourqued with an impact wrench. The nut needs 100+ ft-lbs and is a left hand thread.
Posted on Feb 22, 2008
Top load washer about 8 years old- Problem 1 = during the finial rinse/spin the tub will not fulling drain and leaves clothes very wet...had a service call replaced the pump, however stills does not drain...
most likely its the electronic board, easy to change. if you can use a second hand one out of a known working machine- see how that goes- it will probably cure the noise problem
Sep 24, 2010 | Fisher and Paykel GWL11 Top Load Washer
The tub is off balance. What would be the cause of this and how do i fix the issue?
main bearing is gone needs replaced this machine must be noisey/making a lot of noise.adrian,,,,,
Jun 28, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Noisey spin
The noise is from the transmission and is usually pretty expensive. You really are better off getting a new washing machine.
Feb 24, 2010 | Amana DLW330RA Top Load Washer
Maytag washer top loading leaks water seems to be coming from the tub itself 7 years old thank you mija
does unit leak constant or only when spinning ther are 2 screws done low on front panel fill unit with water and watch center shaft there is a seal below basket
inside washer changing seal is a little difficult have also had this style of washer leak when starting spin cycle if water has not drained out fast enough
http://www.repairclinic.com/Washing-Machine-Top-Load-Maytag-Style-Appliance-Diagram
this page has a break down of normal maytag top load machine part at center is called boot and seal have also had thi type unit leak where bolts go through tub
good luck ron
Dec 12, 2009 | Cameras
Maytag A511 washer tub vibration
The tub should not become unbalanced over time. There suspension springs may wear unevenly, however. Replace all of the suspension springs and it should be fine.
Jul 31, 2009 | Whirlpool LSQ8000 Top Load Washer
Maytag top load performa, put clothes in , fill up and now the agitator is noisey, looked under washer belt appears to be loose 2-3 inches in play, should I replace belt,or something else to repair noise...
thats normal tension on the belt if the agitator is making noise the cams within the agitator are worn (loud clicking or popping noise during wash) the agitator will need to be replaced
Dec 15, 2008 | Maytag HAV2558 Top Load Washer
Washing machine
a gibson has a bar with 2 bolts that holds it on the trans shaft .... remove it and keep trying to turn tub till it breaks loose
Sep 20, 2008 | Kenmore 24032\24036 Top Load Washer
Re: lg wm1812
There is a vent at the back of the machine near the top that is covered by a small round white plastic cross pattern. Inside of the machine there is a black flexible hose that attaches to the vent from the top of the outer tub. inside of the tub attachment point is supposed to be a light blue plastic valve that looks like an old style army helmet on a peg. The peg fits into a flange in the opening on the outer tub. If this valve is missing water will escape from the vent on the back of the machine. Another likely point of water leak is a loose inlet hose or missing washer on the inlet hose.
Mar 14, 2007 | LG WM1812C Front Load Washer
GE WBSR3140DW Top Load Washer Logo
982 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
