Question about Electrolux EW1000i Front Load Washer
Instructions i have been left this washing machine with no instructions. What do the buttons on the front mean please.
  • mitchel1912 Feb 20, 2008
    i have just moved house and the washing machinewas built in to the house but i have no idea how to use it please help
    President:
  • 1,294 Answers
Click on your model number above, (below FIXYA) on this site, & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
And dont forget to rate me on this great site.
Posted on Jan 25, 2008
I have an Omega CW 675-A washing machine and I have just moved in but the owner did not leave an instruction booklet for the settings. Is this a free service? Can you help me? Paul
Hi
The particular model number is not listed in the list of manuals of omega washing machine.Please call the customer support for assistance.However given bellow are some settings of the washing machine,which is extracted from a website.Hope it helps:-
7 is warm wash delicates (warm cycles then it runs through the number 10 delicate cold cycle too)
10 is cold wash delicates
1 is the longest regular cycle
I normally wash with only the cold tap on, 3 for dirty washes, 4 for regular washes.
Soap goes in the middle slot
3 Buttons from left to right
left - in to spray rinse
middle - in to NOT spin dry
right - in for NOT boost heat (or maybe it has no booster and it is just in for cold wash - not sure)
when standing in front of it, reaching over the back, the left connector is cold and the right connector is for hot water.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Aug 09, 2011 | Washing Machines
My washing machine keeps showing test, what do i do?
Here are the instructions to clear the 'test' depending on the date code:-
Date code 39 March 2005
Press start/cancel until ALL LEDS are lit
Press both start/cancel AND on/off together until 'dOFF' is displayed
Date code 39 March 2005 to date code 42 June 2005
Press the cancel button and the machine should return to normal
Date code 43 July 2005 onwards
Press both start/cancel AND on/off TOGETHER with top left option button until 'dOFF' is displayed.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jul 13, 2011 | Hotpoint Ultima WF865 Front Load Washer
Hi my washing machine is coming up with error E20,as i do not have the instruction book ,i dont no what ,or how to do it,thanx
E20 means Drain error in wash phase.
This could be a normal clogged Drain Filter or worse maybe a faulty drain motor.
Please do the following:
- Clean the filter, by removing the drain filter compartment Lid (Found Left lower area of the front of the Washing Machine), then draining any excess water, afterwards turn the cap anti-clockwise to remove it. You can then put your fingers in to feel if there is any obstructions or foreign objects that may be obstructing the drain pump impeller from moving freely. Re-fit the lid and test the machine.
If it did not help, you will need to replace the pump. I
Apr 04, 2011 | Electrolux EW1200i Front Load Washer /...
I have a LG TROMM WM2277HS front load washing machine. Error code UE displays when there is 3-5 minutes left in the cycle. I have tried rearranging the load, making it lighter or heavier. I have also ran...
Hi.. UE error means unbalance error..Check your floor level and machine legs... after u checking ur floor level and legs also perfect means change the suspension rod.
Sep 25, 2017 | LG WM2277H Front Load Washer
What does control lock mean?
This means that the machine will not respond to any controls and will have to finish its current programme completely before it will respond to any operator controls again. It is very useful to stop anyone changing the programme mid cycle. It also means that if the power is cut or you have a brown out that the machine will just carryon where it left off and finish the programme.
To unlock the Control Locked feature:
Press and hold the End Of Cycle Signal button for 3 seconds to turn this feature off.
When the machine is running and Control Locked light is on, the machine can be stopped by pressing the Pause/Cancel button, but cannot be restarted until the control is unlocked.
Oct 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
''Control Lock'' won't ''unlock''
Press and hold the "End of Cycle Signal" button to lock or unlock the control panel. The instructions should be printed directly below this button. I hope this helps you.
Nov 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Error on Westinghouse mastermind 708 front loader washing machine
This happend to me once, and it was in relation to a blocked intake filter.
- Check that the intake houses are not cloged and the small filter under neath is clean (Use an old tooth brash)
- Also check the opening on the front bottom left of the machine. (Open with a flat head screw driver)
. My one had coins in it. Note: drain with the small pipe into a backet so when you open it you don't have watter everywere.
Oct 21, 2008 | Washing Machines
Stops at 19 minutes left and will not do anything
As a first step, try cleaning the lint filter as per instructions elsewhere on this site.
Jun 30, 2008 | GE WSXH208A Front Load Washer
Creda W120VW washing machine - Energy & Deep Rinse Buttons. How do they work?
I found the manual on a website which I didn't note down, but which was very useful as it had almost every washing machine manual on the planet! Now I know that the energay saving and deep rinsing buttons are activated by pressing them in. Thanks anyhow for your attempt to help!
Apr 24, 2008 | Creda W120VW Front Load Washer
Electrolux EW1000i Front Load Washer Logo
77 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
