Question about Westinghouse LTV-40w1 HDC 40.02 in. LCD HDTV
Sony bravia kdl32p3020
Moving to nea zealand and want to know if tv will work there with thier PAL B/G
0 characters
1 Points
Sony Bravia KDLnd -40S4100 purchsed at US and it is not functioning at Sharjah when electric connection is given. Only sound is comming and picture is not comming. Is there any convertor is available to...
The TV you have purchased from US, will be only meant to receive NTSC video signals. It will not work with PAL signals. No need to alter the TV circuits. Just try to get an NTSC to PAL converter, and connect it.
Sep 25, 2013 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
How do I get a US Sony Bravia KDL-42V4100 to work in the UK?
I have encountered this before---there are set top boxes that will convert the NTSC to PAL and the only other concern is the line voltage being the same or not.
May 29, 2012 | Sony Bravia KDL-42V4100 42 in. LCD TV
I'm looking for 46''-Sony-KDL46HX820--BRAVIA-Full-HD-3D-TV.It supports NTSC,Just would like to know whether it works for PAL after using converteers as i want to use it in India
the TV have tuner :Clear QAM/ATSC/NTSC
You can``t see PAL Tv channel
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 22, 2011 | Flat Panel Televisions
I have connected cable (in India Tata Sky) to my Sony Bravia kdl-40V2500 (bought from USA). But I am able to see the picture all black and white and not color. I need to know how can i fix this.
Bravia KDL series are for use in US and its reception system is differnt to that of in India. Your TV can only accept signals of NTSC and ATSC. These are the statds of transmission used in US. In India, all transmisssion and recordigs standards ar of PAL. Your TV won't accept PAL system signals properly. Theese systems mentioned above anr the colour transmitting standards. You have to choose a multisystem compatable TV from there in US. There is no hopt for you to get PAL type transmission signals to recive with your tV. It can play NTSC recoreded dvds or Blu-rays or Video casette tapws, whatever it may be, properly. There is no chance to get it converted to a multisystem, or even for a PAL system converstion with your TV. The colour informatin will not be processed properly. OK.
Feb 06, 2011 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Brought it from the US to Israel and its looks like this TV is not a multisystem TV - so anyone knows how can it work in Israel with the cables company HOT- reciving PAL and not NTSC?
Sorry this tv can't be used.The whole tv electronic boards circuitries are design to used NTSC signal frequencies.Pal signal frequencies can't be inter changeable with NTSC signal frequencies.
Oct 23, 2010 | Sony BRAVIA KDL-46V3000 Television
NTSC to Pal
it will not work with PAL, and I am not aware of a PAL converter. Sorry.
May 24, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Will A Sony Bravia KDL 32s2010 TV purchased in the
This TV will work in Australia as its multi system and auto-power TV.
Apr 13, 2009 | Sony BRAVIA KDL-32S2010 32 in. LCD...
Convert ntsc to pal for sony bravia tv
While a modern PAL TV can display NTSC sources (namely DVD players and PAL VHS players that support pseudo-NTSC), an NTSC TV can not display a PAL source, unless it's an expensive multi-standard TV. Sorry pal, bad choice.
Mar 30, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Sony Bravia KDL 52 XBR-5
If you purchased the TV in the US, it is probably strictly for use with the NTSC system and will not work with any PAL components. You can get some multi fornat devices (DVD, VCR) that will output NTSC, PAL and Secam. That is probably your best option.
Mar 15, 2008 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Flat Panel Televisions Logo
18 people viewed this question
Top Westinghouse Flat Panel Televisions Experts
Dave Naylor
Dave Naylor
Jaime Hernandez
Are you a Westinghouse Flat Panel Television Expert? Answer questions, earn points and help others
