Question about RCA DRC629N Portable DVD Player
Rca dual portable dvd player
When I put a dvd in the player it starts to try to read it then it says: err disc.
This happens everytime I put a different movie in, it just won't work can you help me?
  • 3 more comments
  • rodrico Apr 03, 2008
    my player wont play movies. when I press play it spins around and finally gives me err disk message. However it does plays dvd of short duration like children's 30 DVDs.
  • jojo4 Jun 09, 2008
    We have and RCA dual screen portable DVD player. It played disks fine then one day became really picky about reading disks. It seems only to read the cheaper movies. It will no longer play videos it once played. The disks spins and spins then finally stops. Sometimes after opening and closing the unit multiple times it will finally read. Also, when it does read the disk the picture will pixel.
  • eg0221 Jul 19, 2008
    when I put a dvd in the player it starts to try to read it then it says: err disc.
    This happens everytime I put same or any movie in, it just won't work can you help me?
  • hvan1960 Jul 20, 2008
    Our RCA dual DVD player played fine and then would just stop playing after 20 mins or so and then would only play for shorter and shorter periods. Most of the time we get an err disk message and sometimes it will start to play and then just stop.
  • Anonymous May 15, 2009
    no disc problem error in goodmans (GDV84WLCD). need also a remote control unit for this model. does anyone have this kind of remote?
SOURCE: invalid disc
we also used my husbands converter (little black and decker he has for the "office" in his truck) and we had no problems the last time we used ours
Posted on Dec 29, 2007
SOURCE: rca dvd/vcr dual recorder, wont play dvd
My VCR/DVD Model # DRC6200N is not working. I can hear the DVD but no picture, do you have any suggestion what is wrong?
Posted on Jul 17, 2008
SOURCE: My portable dvd player won't load any dvds anymore
lachallep,
The solution for your problem will be needing a little knowledge with electronic repair and hands on.Most common problem for portable DVD player is their 1) Spindle motor the 2) flex cable ( tin ribbon wire connecting the optic lens and the main board)
note: to check if your spindle motor is working good, you must measure it's resistance and it should be around 200ohms.
For the flexcable all you have to do is check the continuity.
cheers.
mark
Posted on Jan 16, 2009
sree-here
  • 61 Answers
SOURCE: rca drc628 portable dvd not reading disc
This is due to faulty DVD lens/head. Try cleaning it with DVD/CD lens cleaning CD.If still the problem persists, contact near by service center for replacing the faulty Lens.
Posted on Mar 13, 2009
SOURCE: attempts to load then reads no disc
The problem is with the lens assembly. sometimes you may have to replace it(lens assembly) or optical pickup
Posted on Jul 03, 2009
Why does my philips portable dvd player not work
It is attempting to read the disc. Try another KNOWN GOOD disc. If you get the same error, try cleaning the lens using a lens cleaner disc or a dry q-tip. If no go, sorry, she's a gonner :(
Jul 20, 2014 | Philips PD7012 7" Widescreen Portable DVD...
Attempts to load then reads no disc
Jul 03, 2009 | RCA DRC629N Portable DVD Player
DVD-Player not reading discs.
Well if it happens to every disc, then you know its the discs that are the problem. It should be the DVD player. Check if you plugged in the yellow, white, and red plugs accordingly. And also try blowing inside the DVD player, to blow away any dust that might be fogging the disc from beiing read.
Good Luck!!!! Rate Please!!!!!
Jun 13, 2009 | Philips Televison & Video
Rca drc628 portable dvd not reading disc
Mar 12, 2009 | RCA DRC629N Portable DVD Player
?Can't play anything on my DVD player, Everytime I put the DVD in, it reads, no disc and err disc, what's that? Can I fix this or do I need to take in for service?
Try cleaning it with a q tip and alcohol.  The inside where the dvd actually goes.  The dvd reader and everything can be cleaned and it should work for you.  Hopefully.
Feb 19, 2009 | Durabrand PDV-709
DVD PLAYER
Hope it was the non-acetone type of polish remover - acetone will melt plastic !!
Invest in a laser eye cleaning disk - the kind with the tiny brushes.
OK what type of file format are the files in on the disk you are tying to play?
IDM-1731 does not like .AVIs.
Check your documentation as to what type of files your player can actually read and play.
Sorry I'm not more help.
DW
Mar 21, 2008 | Initial IDM-1731 Portable DVD Player with...
Err disc
The laser eye is tired(out of alignment) from playing alot of burned disc. Have some one who know re-align it. Goodluck.
Mar 07, 2008 | Dual XDVD8180 Car Video Player
DVD player won't work
same problem as above===put disc in and get no disc or error disc also mine will read then just stop
Dec 30, 2007 | RCA DRC6300N DVD Player/VCR
DVD player issues
Most likely the dvd is dirty, scratched, or chipped. Try cleaning the dvd disk with a soft cloth (chamois works best). Look at the surface of the disk and if it is scratched lightly, dust and dirt particles, fingerprints, etc will cause refractions from the laser light in the dvd player, which is then read as an error by the dvd player. Cleaning it with a soft cloth will sometimes help.
If that does not work, hold the disk up towards a light source and look for light coming through from the other side. If this happens, the disk is unreadable and unrepairable as the data source has been corrupted.
Dec 17, 2007 | Televison & Video
Portable dvd
err disc, what does it mean? My player suddenly displayed this error message, how do i solve it?
Aug 18, 2007 | NextBase SDV-17 Portable DVD Player
RCA DRC629N Portable DVD Player Logo
1,088 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
