Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
HP Blackbird PC Connection 'Incompatible Signal'
I have an existing Dell that runs on the Aquos using DVI to input signal 5.
However a new PC (top of the line HP Blackbird) gives no picture except for "Input Signal Not Compatible" on the screen. So the question is how do I fix this ? Do I somehow chnage monitor settings (not obvious) or is it a PC issue ?
Please help !
  • 1 more comment
  • jbitz Feb 08, 2008
    incompatible signal when trying to use monitor instead of pc screen using ASUS EEE. Cable is VGA - RCA male,male 15 pin to three RCA blue, red and green.
  • Anonymous Oct 19, 2008
    sometimes it works and sometimes in don't
  • silverbird7 Dec 22, 2008
    I'm going to keep looking around for the solution... It's probably the cable I'm using...
    Problem Solver:
  • 6 Answers
You may have the wrong type of DVI, I would try a different cable to hook it up with.
Posted on Jan 24, 2008
Dell 2407 Can't get rid of "No S-video input signal" message on screen. How do I get rid of this?
Your S-Video connection is referring to a round plug for a TV input signal. Most computers will not have this connection unless you have a TV based video card. If your using a TV 'monitor' as your computer's video device, their will either be a button on the monitor or your remote to allow you to choose the input signal. If you are using a VGA or HDMI or DVI cable as the connector between the two devices, most likely, the light is referring to one of these, as its video source. You will need to match the cable & monitor source detected to get a usable picture output.
Good luck.
Toby.
Sep 28, 2015 | Dell Computers & Internet
NO DVI INPUT SIGNAL AND MONITOR GOES TO SLEEP
you can't run 2 different inputs at the same time. VGA takes prescedence.
Apr 06, 2014 | HP L1950 Monitor
Link ASUS laptop to Sharp Aquos LCD TV
No, a DVI to VGA adapter will not work. (The TV is looking for the digital signal from a set top box. This is different from the analog signal on the VGA cable.) You need a converter. Your best bet would be a VGA to component video converter. (I am assuming that the Sharp TV has a component video input.) This page has some examples: http://www.ramelectronics.net/audio-video/video-converters/vga-rgb-hv-to-component-video/c10000-c11200-c11215.html?sorter=productname-en-asc . Note a VGA to component video cable will not work. The VGA to component cables are for projectors that read the RGB signal. The component video signal is YPbPr.
Connect the VGA cable to the converter and the component video cable to the TV and the converter with the computer and TV off. Turn on the TV first and set it to the component video input and then turn on the computer. Then (assuming the VGA port is enabled - adjust in the BIOS if needed) set the computer's video output to the VGA port. (On my Windows 7 laptop, this can be done by right-clicking on the desktop. Choose Graphics Properties and set the display to the external monitor or both. Click Apply and then confirm the change (on the external monitor if using the single monitor). (VGA to Composite video converters also exist if you do not have an available component video input on your TV.)
If your computer is fairly new, you may have an HDMI port. Your TV may be able to read the signal with a DVI to HDMI cable. (It depends on the TV. Not all of them will read the computer's signal on the DVI port. Check the documentation for your model. TVs without a VGA port are less likely to support this feature.)
I hope this helps.
Nov 28, 2011 | Televison & Video
I have a samsung syncmaster 930b attached to an HP Pavilion Slimline s5660f Desktop PC, plugged into the DVI port of the PC. However, I cannot get the monitor to come up. There is power to it. I get the...
from user manual troubleshooting section
(When connecting D-Sub cable) Check the signal cable connection. (When connecting DVI cable) If you still see an error message on the screen when the monitor is connected properly, check to see if the monitor status is set to analog. Press Source button to have the monitor double-check the input signal source.
Source button Activates a highlighted menu item.
/ Push the 'SOURCE', then selects the video signal while the OSD is off. (When the source button is pressed to change the input mode, a message appears in the center of the screen displaying the current mode -- analog or digital input signal.) Note : If you select the digital mode, you must connect your monitor to the graphic card's port using the DVI cable.
https://images10.newegg.com/User-Manual/User_Manual_24-001-063.pdf ninth page in user manual
source button fourth from the left when facing monitor. looks like a box with an arrow pointing left.
Mar 05, 2018 | Samsung SyncMaster 930B 19" LCD Flat Panel...
I just purchased an ACER P236H-BD monitor described as full HD 1080 but does not have an HDMI input. Does a DVI input give full HD 1080?
Yes dvi can output 1080p video. There is no signal conversation when using hdmi and dvi. Vga however has lower picture quality because signal conversation do exist.
Mar 20, 2011 | Computers & Internet
My DVI has no signal but my VGA does! what do i do? Please help me!!!
Your HP2009M monitor supports (3) methods of accepting signals from a computer. They are: 1) VGA, 2) DVI and, 3) HDMI.
You would connect the computer to the monitor using one connection only. Generally the VGA is the least desirable as it is an analog signal. The DVI and HDMI method provide digital paths into the monitor and often perform better. Your computer may only offer 1 or 2 connection choices, so you'll have to choose a cable type that is supported by both the computer and the monitor. The HDMI choice will pass audio signals to the the speakers in the monitor without needing to run a second cable between the stereo audio jack of the computer and the audio input jack of the monitor (located next to the HDMI jack) or to a set of external speakers (unless of course you prefer the external speakers).
The message you're seeing is normal. Once the monitor is connected to your computer, there will only be one active selection; VGA, DVI or HDMI. Since you're using the analog VGA jacks and cable, it is expected that you'll see a message that there is no signal present on the DVI (and HDMI) inputs when attempting to view signals on other inputs.
I hope this helps and good luck! Please rate my reply, thank you.
Feb 26, 2011 | HP 2009M Monitor
Can you fit a pc terminal to a shap aquos lcdtv??
sorry NO not just a connector would be nedded but serval are parts required
Nov 24, 2009 | Televison & Video
DVI no input signal......VGA input active.
Are you running an additional Video card? Or are you using the built in one.
You might try cleaning the connector / plugs with acetone from finger polish remover or de=natured alcohol.
Never jam anything on a computer.
If its an add on card, remove it and reboot. Shut down and reinstall card and reboot.
keep me posted please,
Feb 22, 2009 | HP dx2300 Monitor Personal computer Intel...
PC DVI to HDMI Regza Connection
I'm getting the same problem with an ATI Radeon HD 2400 going to a Regza AV555D on HDMI 1. In order to get the picture back I have to call up the source menu and move down to HDMI 2 (without clicking OK, just hover) and wait for the screen to change. Then go back to HDMI 1 for a few seconds until it flickers and then press OK. A bit long winded and far from a solution but it's enough to sync it all back together again
Apr 22, 2008 | Televison & Video
Trying to connect new HP Blackbird PC
try updateing the system pc 1st all latest drivers video ect windows update ok
Feb 04, 2008 | Sharp Aquos LC-45GD6U 45 in. LCD HDTV
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
312 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
