Question about Nintendo Game Boy Advance SP Console
Gameboy Color Pokemon Games Not Saving?
Hello, I am really strated to get upset because I have had many of the pokemon games including Red Version, Yellow Version, Gold Version, and Crystal Version and ive noticed that after a while they just stop saving my profiles. I have tried repeatedly saving before I shut off my console, some of them wont even save the first time I try, others will save for a short period of time then just delete themselves. If anyone has any ideas please let me know asap. Thanx
  • 14 more comments
  • ckline46 Jan 28, 2008
    Thank you for your suggestion but your only allowed to have one saved game on these games, and i have no idea how to delete it unless you start a new one and save over the previous game...
  • Anonymous Mar 08, 2008
    Pokemon crystal version wont save any data
  • Anonymous Mar 11, 2008
    hello im christian the pokemon in game doy is not save
  • dquinn87 Mar 17, 2008
    Gameboy Color Pokemon Gold and Silver versions will not save the game. I went to play them and my old files were deleted so I started over and whenever the gameboy is shut down regardless of how many times I saved the game is never there when you turn the gameboy back on.
  • Anonymous Apr 08, 2008
    Hello me and my little brother have an issue on pokemon cristal version it cant save any more it is in a new game but it still cant work.
  • sachinsree Apr 19, 2008
    My Pokemon game is not getting saved as it is showing that the game is saved
  • Anonymous Jun 16, 2008
    I Have the same exact problem. I turn on my gameboy to play pokemon silver and there is no saved game. All it says is new game or options. I start a new game and play for a while. Then ill save my game before turning it off. When i turn it back on to play again and pick up where i left off, there is no game that is saved on it. Once again the only option i have is to start a new game. It wont save my game even though it tells me that it is. Is this because my gameboy is to old? Im pretty upset about this.
  • Anonymous Jun 29, 2008
    I was pissed because it's been ver 6 years and my internal battery went dry so i just went to microplay and saved it there.
  • acer1182 Jul 14, 2008
    when i try to save the game and turn off the game i always have to start a new game and it is starting to tick me off i need assistance
  • Anonymous Jul 29, 2008
    my pokemon games wont save (gold and crtistal) how do i save them?
  • TheBounce Aug 04, 2008
    i have Pokemon silver and on my gameboy advance that i had a few years ago it works perfectly fine, the kbuutons dont work properly on my gamoby advance so icant play my games, i went to game a coupklre of weeks ago to buy a new gameboy adavance, and when i did buy 1 i played Pokemon silver, i tried to save my game, it saved. after a few hours decided to go back onto it and open up my saved game, and all it showed was
    New Game
    Options
    can you help me
  • Anonymous Aug 09, 2008
    my leafgreen and firered versions dont't save my games so i'm very mad. if there is a solution i would love to know .
  • Joe-1337 Aug 17, 2008
    Ive had pokemon silver for about 5-6 years now, When I used to play out it I had no problems with saving.. I recently started playing my gameboy advance again and now i cant save anything ive done. Its really frustrating.
  • Darthjedi777 Aug 24, 2008
    SOLUTION TO YOUR PROBLEM! My daughter has the same problem but with
    her
    Game Boy Color. After reading info from the net I have found out that
    there is a battery inside the game cartridges that needs replaced. You
    will need to be able to open up the game cartridge and replace the
    battery. The GBA SPs are the same problem. Follow link and read how to
    replace battery. If you can't do it have your parents do it for you.
    Gameboy GB/GBC Pokemon battery replacement http://www.pdroms.de/phpbb/viewtopic.php...
  • Anonymous Dec 16, 2008
    you cant even have one save file, it dosnt let you
  • nathanielcor
    nathanielcor Jan 21, 2013
    the original is run a batter in side the game. the battery after a set of years dies. take the game cartridge apart and put a new on in
U just have to press select+start+a+b
Posted on Dec 20, 2008
It's actually very simple. Because Gold, Silver and Crystal have an internal clock the battery would run dry faster than other GameBoy color games. Your Red, Blue and Yellow would have run dry just because they've have a save file on it for such a long time. You're best bet is to either buy a new copy that works or go to an electronics shop to get them to replace the battery. Doing it yourself isn't the best idea because the battery is already soldered on to the tabs connecting it to the game chip. There is also another possibility whish is highly unlikey but the connectors to your game boy could be dirty. If this is the case then take a cue tip dampen it (it can't be drenched with water because that will ruin the game) and do up and down strokes on the connectors of the game. (don't do side to side strokes becasue that can ruin the game too).
Posted on Aug 05, 2008
These games depend on a battery to save. If the battery goes bad, the save function is gone.
I do not know if the batteries are replaceable- I've never heard of doing it.
Posted on Jan 30, 2008
I think the person above means the internal battery in the actual game, not in the gameboy itself.
It seems that there is no real fix for this.
Do a quick google search for some more info.
Posted on Apr 15, 2008
  • 99 Answers
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
a-60
Posted on Jul 23, 2009
I also had this problem before on my pokemon fire red version...though everytime i save it appears that the game was saved but the next time i turn on the console to play....i must start a new game.
i guess this has something to do with the game itself and not with the console...Gameboy cartridges (GB original, color, advance, and SP) can be pirated or copied. in this case the unscrupulous people who do these things are those who makes profit with less budget. copying an original cartridge to be sold on the market but most of the time removing the "save" and "options" category of the game....meaning less program on the cartridge....less cost to manufacture....more income for them.
the only suggestion and solution i can advice is...always make sure that the item you are buying is an original merchandise. so that if ever it has some problems...you can immediately have it replaced or fixed by the manufacturer or distributor
Posted on Jul 19, 2008
When you get a new battery will all of your save data still be there?
Posted on Aug 14, 2008
Go to a game shop and they can fix it
Posted on May 28, 2008
Delete some of your savings
Posted on Jan 25, 2008
How to download the pokemon olnine for pc
First off, it sounds like you are aiming to load a version of Pokemon onto some sort of emulator on your PC. You can get one of the best gameboy emulators at this website. After you install this onto your computer, you will need a ROM to run on the emulator. There is a large collection of Pokemon ROMs located here. After you download the ROM you want to play, load it up through the emulator and enjoy!
Alternately, you can play all of the games online at this website if you have java installed on your computer.
Apr 18, 2011 | Nintendo Gameboy Color Console
My gameboy advance game pokemon silver version always says save file corrupted
there is a small battery inside the carriage, replacing this will give the game the ability to keep saved data once again. *Note* I do not suggest doing this unless your experienced doing such thing. you can damage the board of the game if on careful.
Feb 20, 2011 | Nintendo Pokemon Crystal
How can i find ho-oh in pokemon fire red
The only way to obtain it in fire red is with a mystic ticket which was an event item, which you had to attend the pokemon rocks tour. Otherwise if you have or know someone with a gold or silver version for original gameboy you can trade from that. Preferably gold beccause you get him sooner in the game.
Feb 05, 2011 | Nintendo Pokemon FireRed for Game Boy...
My Game Boy Color game: Pokemon Gold has recently stopped working. By this I mean it does not save anymore and always resets itself whenever the game is turned off, despite "saving." I'm not...
There is no easy fix. Well, there is, but you have to open the game cartridge
all gameboy game cartridges have a battery inside. this battery powers the save module. Pokemon gold is such an old game that the battery has likely died; open the game, replace the battery, and it should work. images?q=tbn:ln15bafqcr5fzm: Leave me good feedback please.
Jan 13, 2011 | Nintendo Pokemon Gold
I am considering buying "POKEMON SPECIAL PIKACHU
Your link is broken but regardless...
"POKEMON SPECIAL PIKACHU EDITION" should work in your gameboy color assume neither the gameboy color nor the game are broken.
Dec 21, 2010 | Nintendo Pokemon Yellow Version: Special...
How do i make my game boy to read my game
make sure u put the game on a game boy, gameboy color, gameboy advance, or gameboy advance SP.. blow inside the game, there is usually dust there which wont allow the game to start.
Dec 01, 2009 | Nintendo Pokemon Red
How do transfer packs work? Will it work on a nintendo DS?
A Game Pack is the game cartridge you insert to play a game. GameBoy Advance Games are not compatable with the Transfer Pak. The Transfer pack and Pokemon Stadium 2 only support the following: Pokemon Red, Blue, Yellow, Gold, Silver and Crystal versions. No Ruby will not work with the transfer pak as you will not be able to insert it, and the software would not pick it up.
May 17, 2009 | Nintendo 64 Console
Cannot save
This a problim that cannot be solved as the cartradges may be fake or the memory has been damadged inside the cartradge.
Apr 12, 2009 | Nintendo Video Game Consoles & Games
Pokemon duplication
put two of the same pokemon in the daycare it has two of the same breed or put a ditto in the daycare it doesn't matter if you put in a boy or a girl pokemon then let them have good hot sex and when the old man is outside of the gate he has a egg for you and you have to have space in your party and then ride your bike back and forth and check on your egg once in a while and when your person says "Huh" you egg has hatched
Oct 25, 2008 | Nintendo Pokemon Emerald for Game Boy...
Nintendo Game Boy Advance SP Console Logo
7,073 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
