Question about Canon PowerShot A530 Digital Camera
How to show images on my TV or VCR
I have looked in the manual pg. 88 and followed directions, but nothing comes on my TV screen.
    Master:
  • 619 Answers
Hi connect rca cable to tv , rotate knob to play mode press function set and press play ,now you can view movie.
Posted on Jan 28, 2008
6ya staff
SOURCE:
Sylvania (SRD3900) DVD Player / VCR Combo i can't seem to plug in the red/white/yellow cables into the right places directly to my old toshiba tv to play either tapes or dvds. can you instruct me? thanks.
Greetings - It's very simple so I'll show you how and then I think it may be another problem (nothing broken).
You need to plug the corresponding color cables into to outputs on your player I've circled above and then into the corresponding inputs on the TV. You've probably done this correctly.
PLUS - You have to, using the remote for the player, set the source to either DVD or VCR and then you have to, finally, on your TV set the input (with the remote) to what is called probably VIDEO or VIDEO1. If there is still nothing on the screen keep (with the DVD or Tape playing) hitting the TV remote input button until you see an image or you've come around to where you started.
Unless something is broken (unlikely) you should be able to watch DVD's or Tapes depending on what input you select on the player.
If it's not working you've somehow missed a step or the Video input on the TV is called something else. If that happens come back here and give the player AND TV brand/model info and someone will be able resolve your problem.
Good Luck and thanks for using Fix Ya.
Mikeywaf
Apr 21, 2011 | Sylvania (SRDD495) DVD Player/VCR
JUST BOUGHT wii SPORTS FOLLOWED THE STEPS TO
The best thing I can think of is to turn on the wii, go to the tv and press tv/video once and if nothing shows up then press it again (this will take your tv to video 2) and if that doesn't work then turn your tv to channel 3 or 4 and see if one of those channels work, also if your wii is plugged into a vcr or dvd player make sure that vcr/dvd player is on!
I'd recommend just directly plugging the wii into the tv though on the count that its easier to setup that way...
If this doesn't work then call nintendo because their customer service is superb in my opinion.
Jan 25, 2010 | Nintendo Wii Console
Problems tuning TV and SLV-900
the video recorder has it's own tuner you do not actually record from the tv... think of the vcr as like a tv but without a screen... connect to your tv via a scart lead and while you are on the vcr's 'channel' (so you could see a tape playing on your tv) and access the menu on you vcr (not the tv's menu) choos auto tune if the vcr supports it or manual tune if it has no auto tune and tune in the required channels on your vcr... it is simply then a matter of selecting on your vcr which channel you wish to record
Oct 13, 2008 | Sony SLV-D900 DVD Player / VCR Combo
Vcr recorda blank when digital tv is put on standby.
this is because you are recording a direct connection (what is on the screen is recorded) that is an option with some equipment.. unfortunately this means if there is nothing on the screen well you get nothing..
You need to record from the machines own built in tuner dont use direct record.. a vcr/pvr/dvdr after all remember is like a tv without a screen that can record it has its own channels to do this
Sep 30, 2008 | Televison & Video
Recording Snow
If you hook your VCR up to the RCA jacks on the front of the DVD recorder, push 002 on the remote to use the front input jacks. (001 if you hook your VCR up to the rear input jacks)
Push record on the DVD recorder, and push Play on the VCR.
(Pg. 35 in the manual)
When you push play on the VCR, you should be able to see the movie being played on your TV. If you cannot, make sure your RCA cables are good and hooked up correctly.
That's all you have to do, so if it's not recording I would try to take the unit back for an exchange.
Dec 03, 2007 | Philips Magnavox MWR10D6 DVD Recorder
Samsung DVD V9700
Double check the cables. if it has a tuner, use that
Nov 25, 2007 | Samsung DVD-V4600 DVD Player/VCR
Camcorder Widescreen Recording Issue
THERE IS REALLY NOTHING YOU CAN DO as your settings conflict with each unit connected
Nov 13, 2007 | Insignia IS-DVD1001 DVD Recorder/VCR
PANASONIC PV4022
One way is to manually select the missing channel with the numeric keypad, then push "add." There is also an auto program function puts the VCR into a search mode, adding all channels where a good signal is found. Early VCRs (like late '80s or so) did not have this auto mode, but many later ones did. Also, make sure your VCR is set to the "cable" or "CATV" mode not "off-air" Do you have the VCR manual? If not, recheck your model and see if Panasonic has it online at http://service.us.panasonic.com/OperMan/Default. aspx I looked at at a manual for a PV-4651, and it showed functions which sounded similiar to what you need. Check pg. 10-12
Aug 12, 2007 | Panasonic PV-V4022 VHS VCR
Message protected program by tv-pg
Go into Menu /V Chip arrow key up to tv rating should show all locked volume down or visversa should should view all Note may have to volume up to get to options from menu depending on how old the tv is.
Apr 04, 2007 | Emerson EWV403 VHS VCR
Canon PowerShot A530 Digital Camera Logo
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
