Question about HP Business Notebook NX9110 Notebook
S-video I have all the correct cabling but when i plug the notebook into the TV nothing happens Help please !!!!!!!!
    Scholar:
  • 163 Answers
Should be a FN and top key to access and trigger it to S-video..(F-??)
Posted on Jan 24, 2008
When i connect my cables from my vcr to my element flat screen tv and hit sourse to video nothing happen! What am i doing wtong.. Help
Try making sure you are selecting the correct source input in the tv. Also some vcrs have a tv/video button which allows you to switch between sources moving through the vcr.
Jun 09, 2015 | Element Televison & Video
My ps3 doest display anything nor makes any sounds please help
Just a gander, but your PS3 may be set for HD output thus not displaying on your non HD television, your best bet in this case is to find an HD television, friend, coworker, etc, connect to it and switch the settings back to regular. Also if I understand correctly leaving the ps3 completely unplugged for 72 hours may also reset all settings. Good luck!
Jul 03, 2009 | Sony Playstation 3 (PS3) Console
Difficulty in setting up sega saturn
Uh... what kind of tv cord are you using? Does it hook up to the cable or is it just the Comp. Video? (Red, white, and yellow plugs) If it hooks up to the cable than the RF unit(a.k.a.-the tv cable) is probably shot; buy a new cable (you can find them on ebay). If it's the other one, it still may be broken, but it's less likely. Just try replacing the TV cable and if that doesn't work, just buy a new system.
Feb 10, 2009 | Sega Saturn Console
Cannot connect laptop to tv using 7pin 3rca s-video cable
eon your laptop keyboard there might be a button you push to change the display output on mine i push Fn F7 It has two screens on it and when i use this it lets me output my display to other devices
Dec 30, 2008 | Acer TravelMate 2300 Notebook
HP Pavilion dv2500 no display when power lights not blinking
Hello
To get the display on the TV . Please press Fn + F4 after connected TV to the Notebook using Svideo cable and the cable should be connected to the Svideo port of the Notebook.
If there is not display on the Notebook after the Svideo cable burns.
Then please perform the following steps.
= Power Drain =
1. Disconnect the AC Adapter.
2. Remove the Battery.
3. Hold the Power button down for 30 seconds to 1 minute.
4. Reconnect the AC adapter and Battery.
5. Turn on the Notebook power.
If the issue persists then check whether the display is same on the external monitor.
I hope this will work.
Thanks
Aug 24, 2008 | HP Pavilion dv2500t Notebook
Can't get my new wii to work
Hello.
Most likely it is not your console. Depending on what type of TV it is there may be many different inputs in the back. My HDTV has 5! It can get confusing. If you have it connected directly to the TV, note which ports the cables are plugged into, then make sure the TV is in the correct output mode. Ex...cables are hooked to Video 1 in, set TV to Video 1 output. Now if you are hooked up through a DVD or VCR player it could be different. If you are hooked up to your VCR and the VCR is hooked up to the TV, the VCR would need to be powered on also. It would be the same for a DVD player. I really hope this helps you. The Wii is very fun!
I wish you much luck. If you have any more questions, please do not hesitate to click on my "Ask Me" button.
Thank you.
Aug 01, 2008 | Nintendo Wii Console
Vga
you’ll need two outputs on your laptop that are typically found on most: the first is a small round yellow socket usually found on the back of your laptop, which is the S-video socket. The other socket you need is either a line out (unlikely) or headphones socket (more likely). You also need a TV with the correct inputs, which will ultimately decide which cables you need
First, you need two separate cables for video and audio: S-video to S-video...and Stereo 3.5mm plug to 2x RCA plugs..Both cables are two metres long and longer cables are also available..Your TV will require either equivalent S-video and RCA audio inputs or a SCART socket - if it only has the latter, you’ll also need a SCART adapter
Once done, plug them all in and switch your TV on, switching to the A/V channel. If nothing appears, open the Display Properties Control Panel, switch to the Settings tab and click Advanced. Look for a Display tab or something similar where you’re able to switch on the S-video port to enable the laptop’s display to route through the TV. Finally, when watching DVD movies (you’ll need a DVD player to do so), look for the option to run them full screen, so you get the best possible picture from your TV.
Mar 02, 2008 | Acer Aspire 5100 Notebook
Trying to connect note book to Plasma Tv.
hhmmmm...does your compaq have a special video card or upgrade by chance?
Feb 16, 2008 | HP Compaq Presario V2000 Notebook
HP Business Notebook NX9110 Notebook Logo
24 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
