Question about Zanussi 24 in. DA6141 Built-in Dishwasher
Zanussi da6141d dishwasher
When i turn the machine on the machine just keeps going does not let water out, it appears the timer does not ell the machine what to do, engineer looking now at timer however he feels the wires have not been fixed properly by previous engineer, do you have a diagram or explanation on wiring up the timer
  • Anonymous Feb 22, 2009
    wiring instructions for timer as numbers on wires rubbed off
  • 25 Answers
Not to familiar with this D/W but from what you are saying , I'm guessing that the unit will go thorugh part of the cycle then stop and just keep washing? if that is the case you may have a heat problem the unit could be waiting for the thermost to reach a design temp prior to moving on some D/W i have seen run all night due to this
Posted on Jan 25, 2008
Bosch Dishwasher model #SHU3002UC-06 continues to run on any cycle, does not stop at the timer shut off spot
Anti flood device in a lot of german machines and pump keeps running only way to knock it off is too un plug what has happened water has leaked possibly over a period of time ,and set the anti flood device off if ya disconnect macine plug and drain hose and lie on its side water will drain off anti flood put some towels to catch water and macihne should work after ya reconnect
Nov 01, 2015 | Bosch Dishwashers
Bosch classix 1200 exprss washing machine will not move on from the wash cycle. it will keep on washing and never moves to the rinse cycle. pump and motor works ok.
WASHER WILL NOT RINSE:
If your washer doesn't go through the washer rinse cycle, the most likely cause is the water valve. What happens is the water valve will stop letting cold water into the washer; therefore, once the washer gets to rinse it will either stop or not do anything during the whole rinse cycle.
This is because when you selected your water temperature, you selected warm/cold or hot/cold. The hot water came in and you didn't notice any problems. When it got to rinse, the cold water the cold water won't come in. Therefore, the washer does nothing.
To check the water valve, first cut the water off and remove the hoses off the back of the washer. Then one at a time point the hoses inside the washer tub and turn the water back on. If you don't have good water pressure, turn the water back off and remove the strainer that should be in one end of the hose. Inspect the strainer to see if it is stopped up, clean it and reinstall it. Now repeat this test. If you have good water pressure now, reinstall hose and your problem is fixed.
If you still don't have good water pressure, the problem is in your house plumbing and you need to call a plumber. If you had good water pressure the first time you performed the test, the water valve is bad and needs replacing.
TIMER
If your washer doesn't go through the washer rinse cycle the timer may be the problem. Sometimes the timer gets stuck in the middle of the cycle or won't turn at all. If the washer runs, but the timer doesn't turn, the timer is bad and needs replacing.
Do you have anti-flood hoses leading to the machine. If you do there is probably a loose tube in the back causing a small leak. When the hoses detect that water is still flowing after a certain amount of time due to the leak it shuts down and causes the machine to turn off during the rinse/spin cycle
Mar 25, 2015 | Bosch Washing Machines
Water keeps filling up the drum and inlet light flashes
either the inlet water valve is bad and needs to be replaced or the controller for it is not cutting off the electricty to it, If you are going to replace something, replace the water inlet solenoid valve.
Feb 10, 2014 | Miele Washing Machines
Wascomat washing machine w74 timer has 2 motors on a single shaft. Do they ever get out of sync ? if so how do you get them back normal?
yes timer gears do go out of sync and timer contactors bend or do not make contact to trigger the finish of the cycle
Dec 03, 2013 | Washing Machines
Zanussi dishwasher ZSF6161 starts program then stops after 15 minutes
check this steps and fix it. God bless youFloat Switch
The float switch may be hung up and this can cause the dishwasher to be stuck in a cycle.
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace the timer /electronic control.
Apr 02, 2013 | Zanussi Dishwashers
Gardena t14 manual swich button is stuck . Cannot program timer
There is no magic cure for plastic, battery-operated, digital, water timers that are exposed to weather.
Try spraying WD40 on the button.
Turn timer upside down and spray WD40 again so debris can work it's way out of timer button.
Keep a cover over timer, do not expose to direct hot sun, and do not expose to freezing water or inner plastic valves will break.
Buy another timer.
Copy following link for Gardena manuals:
http://waterheatertimer.org/How-to-program-Gardena-C1060.html
Copy following link for various other water timers, Toro, Orbit, Melnor, Raindrip etc in no particular order.
http://waterheatertimer.org/Woods-timers-and-manuals.html#sprinkler
Aug 30, 2012 | GARDENA Water Timer
Zanussi zwf1421
Thermostat or heater most likely causes. Does timer button move round without doing anything? Timer knobs on Zanussi notorious for breaking off inside.
Apr 28, 2012 | Zanussi F1245W Front Load Washer
Have a zanussi dishwasher ZDF601K trouble shooter says -,antiflood device activated call engineer is there anything I can try ?
antiflooddevice bottom of machine it detects water and shuts machine down or pump keeps runnining ,clear water from bottom of machine and dry check for leaks UN PLUG FROM MAINS WHILE YOU CHECK IT AND DRY AREA
Jan 22, 2011 | Zanussi Dishwashers
My Zanussi dishwasher DE6744 leaks clean water during the wash cycle. The water appears to be coming from the plastic tank overflow holes, left hand side as you look from the front. Any ideas?
I have the same machine and I took mine outside and turned it on its side and removed the clean water feed and all the screws holding the white plastics off and then un-clipped them off and I saw that there was a blue tube that was leaking on mine, I cut the end off and reattached it with a new clip and hey prestow all working now with no leaks.
Dec 29, 2009 | Zanussi 24 in. DE6744 Free-Standing...
Zanussi 24 in. DA6141 Built-in Dishwasher Logo
225 people viewed this question
Top Zanussi Dishwashers Experts
Owen Barnes
Paul Carew
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
