Question about Tomtom ONE GPS Receiver
Car accessory outlet
My Honda CRV front accessory outlet does not work since I have plugged in my Tomtom GPS receiver. Honda dealer says that my car cannot support the Tomtom unit and therefore a fuse blew because of amperage overload. The rear accessory outlet does work with my cell phone charger but I did not put the Tomtom charger in there for fear of blowing that fuse.. I do not want to go to the Honda dealer for repair until I determine whether the Tomtom charger cannot be used in the CRV accessory outlet specifically since the service dept. told me that it draws too much power and therefore blows a fuse. I am a woman of certain age but I can't bring myself to stick my hand in that fuse box to look at fuses. What do you think is the truth? It is a 15 amp fuse according to my service handbook.
  • 1 more comment
  • Grandma Mar Jan 24, 2008
    You did not answer my question. Can the Tomtom blow the fuse on the 2006 CRV front accessory outlet? It is a 15 (volt or amp?) fuse. Aren't all accessory outlets the same? My Tomtom charges well on a Nissan Murano with no fuse problem.
  • Grandma Mar Jan 29, 2008
    Yes, thanks. Checked the fuse, it is fine. There is no power in the accessory outlet which makes one think of a wiring problem which the Honda dealer was not going to tell me about. Will go to another dealer. Thanks again, good answer.
  • Anonymous Mar 21, 2008
    I just bought a 1992 subaru with intent of using my gps system in it but the accessory outlet doesn't work. I then looked in the book provided with the car and it says that it might not work for anything other then the cigarette lighter. My questions are will it work with a GPS system if I fix it? How do you fix the outlet? Would there be another way around charging my GPS system in this car?
  • 174 Answers
The power cord for the Tomtom actually step down the voltage from 12v to 5v. The power chord is also rated at 2A so if the CRV power accessory can't supply 5v at 2A then I would suggest that you find another dealership to have them look at why the fuse is blowing.
Tomtom interal battery is usually 3.7v at 1800mAh or 1.8A.
Posted on Jan 27, 2008
  • 4,402 Answers
You might be able to go to a local car parts place and have a nice guy check it put for you
Posted on Jan 24, 2008
  • Cary Farah
    Cary Farah Jan 24, 2008
    no they are not all the same.
My cigarette lighter will not charge my TomTom
The plugs which are used with car lighters are often very poor; compare the firmness of the seating of the lighter with your accessory plug. The latter are often too loose to make decent contact.
Also, that plug is equipped with a fuse; unscrew the plug body and check the fuse.
I also recall someone having a failed plug on the Tomtom itself; it may be a weak point.
Jul 08, 2010 | Tomtom ONE GPS Receiver
Honda CRV 2006 front accessory outlet not working. Fuse replaced and still not working.
have you got power to the outlet plug.may have a faulty plug or broken wire to plug
Jan 01, 2010 | 2006 Honda CR-V
My tomtom one no longer recognises the car charger.I have purchased a new one from a dealer and it won''r make it charge.I can only bharge it with my bomputer hook up cable...what can I do now?
Seeing as it charges from the computer
I doubt that it is the tomtom.
I would suspect either the outlet in your car or a posible problem with the lead even if it is new.
Aug 28, 2009 | Tomtom ONE GPS Receiver
TOm TOM bluetooth GPS receiver can not charge in the CAR
This can be a major repair if the plug has been torn from tyhe board. The cost of repair is almost as much as a new purchase.
Aug 17, 2009 | Tomtom Navigator Bluetooth GPS Receiver
My Tomtom ONE XL will not start inspite of being connected to the car's system. Is there a special trick to get it to come on?
I tried connecting it to another car's system and it worked. Outlet in primary car needs new fuse. Simple. Sorry to bother you.
Aug 15, 2009 | Tomtom One Xls Car Gps Receiver 3.4"...
Tomtom Rider GPS won't turn on
My Rider 1 is showing the same sympton. Was working fine now I can't get past the initial "Tomtom" screen.
Does it power up when connected to the mains charger?- No, need to prod reset and then turn on manually.
Does it switch on when connected to the bike cradle? - No, only sign of life if by manually turning on but only get as far as the Tomtom screen, not the main menu.
Any ideas welcome
Jul 14, 2009 | Tomtom RIDER GPS Devices
Cant find fuse for cigarette lighter in 2008 honda crv
look under ur dashs fuse box covers for a white label which should tell u of the locateion of the fr-acc fuse or rr-acc socket fuse location. replace the burnt fuse or fuses.(acc = accessory)
Apr 01, 2009 | 2009 Honda CR-V
I can't start my tomtom
Are you plugging it in to your car, is the cig outlet in the car have a bad fuse, does the charge
plug for the unit have a fuse in it.Check these first to make sure power is getting to the unit.
I can not tell if the unit needs to be charged first or if it comes charged as you did not post the model.
Mar 27, 2009 | Tomtom GO GPS Receiver
My cigarette lighter outlet is not working and want to a dvd player this weekend. is there a battery adapter I can use
Too much of a problem to hardwire. Possible though. Most are ugly fixes. Check the cars accessory fuse. Many devices have the fuse built in to the plug. Good luck.
Mar 25, 2009 | Tomtom ONE GPS Receiver
Can i first charge my tomtom 330xl on the usb port of my computer
If it is plugged into the car, you use the DC charger. You can charge it using the usb port on your computer as well. In the accessories section of you will find an ac adaptor as well that can be purchased to charge it to an electrical outlet.
Jan 30, 2009 | Tomtom XL 330S GPS Receiver
Tomtom ONE GPS Receiver Logo
1,318 people viewed this question
Top Tomtom GPS Experts
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
