Question about GE Spacemaker JVM1640SJ Microwave Oven
GE Spacesaver microwave model: JVM1653sf001
This morning my microwave just quit working. Everything works fine on it but the actual heat. The light works, the fan, etc.
Any idea without calling a repair man? I am a single mother taking care of a sick parent. However, I am very handy with mechanics.
Thanks,
Tina
  • 1 more comment
  • Troitino Jan 24, 2008
    GE Spacesaver microwave, Model # JVM1653SF001
    It's not the fuse....Were is the Magnetron located?
    Thanks again for all of your help!
    Tina
  • foglinerider Sep 02, 2008
    Our GE space saver just quit from working one minute and stopped the next.. Fan Lights everything sles works but it doesn't heat.. My question is,
    Where are the fuses located? or is it the magnitron tube?
    If I have to take it out to get it serviced how do I do it? It seems to be attached to the exhaust vent.
  • Anonymous Mar 20, 2014
    The GE Spacesaver XL over-range microwave is not working at all. Even the light and time are not working. Not sure what causes the problem. Thanks.
  • 2,130 Answers
It could be the Magnetron. First, If the unit is out of warranty, you can try to remove the rear cover (make sure unit is unplugged) and see if there is a blown fuse in the section that powers the Magetron. If all the fuses are good, I would suspect a faulty Magnetron. The Magnetron is the microwave tube which makes the food cook. They are not too difficult to replace. MCM Electronics sells them and you can call them with your model and they can find a replacement for you will be able to see how much it will cost.
http://www.mcminone.com/search.asp?keyword=magnetrons
1-800-543-4330
Good Luck,
- Jim
Posted on Jan 24, 2008
    Scholar:
  • 43 Answers
Tina, BEWARE! the magnetron is supplied by 24thousand volts some of which is retained in the HV Capacitor after the unit has been turned off and dis-connected. It can cause you to hurt yourself
I suspect the power relay board. Cold solder joints that feeds 120volts to the HV Transformer. Well known failure with GE Microwaves.
Posted on Jan 25, 2008
6ya staff
SOURCE:
Ge jvm1650wb005
one of the internal door switches, the high voltage circuitry or the circut board may have a problem to resolve this you need a qualified appliance technician
Jul 28, 2008 | GE JVM1650 1000 Watts Microwave Oven
May Spacemaker XL1800 stop heating food. Was working fine. Then just stop
Is this an over the stove type unit? I have had a few problems with my over the range spacesaver. I think the heat from cooking gets up into the microwave and damages it. The steam from me boiling things on the stove had mine quit heating and I purchased a new one. The parts to replace the faulty ones can be quite expensive over $150.00, so its better to purchase a new microwave.
Feb 24, 2013 | GE Microwave Ovens
Heat doesn't come on in microwave
If you have the experience with discharging a capacitor and you have a (VOM) Volt Olm Meter. Unplug microwave, discharge capacitor, and check the resistance of the two thermal cut-off discs by removing the lead and set VOM to RX1. If you don't get a reading of zero, replace the discs. For part go to www.partselect.com and enter your model number. If you found any of these suggestions helpful, please rate my solution. D. Lange
May 01, 2009 | Microwave Ovens
GE microwave not heating lights and keypad functional
You may have a fuse blown on the micro/ the vent and lights are a diffrent cercut , Try replaceing the fuse. its on the in side of the unit. if you need further assitance and you think you can do this I will be happy to instruct U DFD
Apr 11, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE XL 1800 quit heating
I don't like to pass on your problem but it sounds very much like either the high voltage supply ot the magnetron has bit the dust.
Either one would make the repair marginal at best.
This is apparently not a very good unit, many microwaves jsut kind of fade away as their magnetron emissions decay.
This one seems to have a bad rep. look at this link:
http://www.fixya.com/search/p489218-ge_xl1800_1100_watts_microwave_oven/not_heat
Sorry, have owned a lemon or two myself.
Aug 27, 2008 | GE XL1800 1100 Watts Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
465 people viewed this question
Top GE Microwave Ovens Experts
Poppa Maddo
Poppa Maddo
William Miller
William Miller
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
