Question about Hotpoint HSS25GFP Side by Side Refrigerator
Hotpoint sxs compressor stays running.
Compressor runs constantly. The sound cycles, hi the low then high then low. Both fridge and freezer are working well.
I can turn the freezer off and the compressor stops. Turn it to any setting and it comes right back on.
  • weinmb Jan 28, 2008
    I have the same issue. Mine does this intermittently, however. When it happens I unplug the refridgerator and plug it back in, takes one or two tries, but then the compressor runs normally.
  • 833 Answers
Fasnipe, it sounds like you are starting to lose the gas in the unit. Fairly soon, you'll see that the unit will fail to keep things cold. If it is less than 5 years old, you may have a warranty. If more, I suggest you get in a technician when the problem begins to impact the ability to keep food. You cannot fix this yourself.
Posted on Jan 24, 2008
Hotpoint RLA64T fridge freezing up after new thermostat fitted
WHEN U TALK ABOUT THE THERMOSTAT U MEAN THE COLD CONTROL THERMOSTAT OR DEFROST TIMER THERMOSTAT? WHEN UR PROBLEM SOUNDS MORE LIKE THE DEFROST TERMINATOR OR BAD HEATING ELEMENT, LOCATED ON THE FREEZER EVAPORATOR COILS? IF ITS STAYING ON ALL THE TIME U HAVE A DEFROST ISSUE? OR BAD SEALS ON DOOR AND DIRTY COMPRESSOR
Aug 02, 2014 | Hotpoint Refrigerators
I have a hotpoint freezer fza34 The red high temp
it could be that your fridge,freezer setting is not turned up high enough to keep the freezer cold enough.turn it up to setting number 5 at least and if that dont do it u could have a faulty thermostat.have it checked by a engineer.
Oct 30, 2013 | Freezers
Hotpoint HTR17BBRFRWW top freezer does real cold but bottom fridge stays at 52 or above. Coils clean and gaskets good, unit level and compressor runs quiet. What is obstruction between freezer and f
http://www.partselect.com/Schematics/GE/00113789i02.gif
look at number 304. Ice more than likely has formed and not letting air flow from the freezer to the fridge.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 03, 2012 | Hotpoint Refrigerators
Hotpoint Mistral Fridge freezer no Power Issue
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} . Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Dec 11, 2009 | Hotpoint FFA80 Bottom Freezer Refrigerator
Kenmore SxS 596.52673200 stopped cooling
You have a refrigerant leak. Your coil in the freezer should be frosted. You're looking at 600 dollars minumum for repair.
Sep 12, 2009 | Frigidaire FRS23H7CS Side by Side...
Hotpoint not chilling
looks like your compressor is busted. the sound that is not healthy is the compressor trying to start, as you have said, chugging... now everything is hot since the compressor is no longer running. have a qualified tech check it to see if the compressor could still be saved...it might just be a dirty condenser.
Dec 15, 2007 | Hotpoint FFA70 Bottom Freezer Refrigerator
Model # PLFU1778ES Fridgidaire
tilting it would not do any harm while running the tilting theory is if you lay a fridge over on its side the oil in the compressor can run into the suction tubing and it is recomended not to plug it in right away . this is to alow the oil time to run back into the compressor housing. did you posibly loose some air space around the freezer. refrigeration is all about the removal of heat. if you block the air flow around the unit it may not be able to aceave the low teperatur set points. hope this helped
Dec 11, 2007 | Hotpoint  21.8 Cu. Ft. Top-Freezer...
Whirlpool gd25sfxhs03
That click maybe you compressor cycling on its overload pertector... see if compressor is evern running..listen for a click there  .it maybe a bad relay on compressor
Oct 31, 2007 | Whirlpool ER6AHKXPQ Top Freezer...
FFA60 Hotpoint fridge/freezer Red warning light
if i read the english right, the compressor runs but the freezer fan only runs for a short time. no fan then no cooling. there is a fan stat so that the fan only runs when the evap is down to temp. this may be faulty. also on some hotpoint, the fan switches off when door opened. check door switch operating ok. this may also explain problem with fridge lamp
Mar 11, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
Hotpoint HSS25GFP Side by Side Refrigerator Logo
88 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
