Question about Kenmore 44102 Front Load Washer
Kenmore front loader washer
My washer will not go into its spin cycle during any washes. It seems to tumble the clothes, however it will not go into a full speed spin and drain the water. Any suggestions?
  • cmagicladi Feb 09, 2009
    the tub does not spin during the spin cycle,
You need to replace the speed control unit (board) in the lower right corner in the back of the washer it is faulty
Posted on Jan 24, 2008
I bought the Whirlpool Duet to replace my old standard washer & dryer and I find that the wash time is longer than the old washer. Even the quick wash takes about 1 hour. Am I doing something wrong...
I assume from your comment that your old washer was a top loader. Yes, front loading machines typically have longer cycle times than top loaders. There are several contibuting factors... first of all, the wash action of a front load is to oscillate the drum back and forth as well as provide a slow tumbling motion whereas a top loader w/ agitator or impeller has a more aggressive action. The more aggressive action rolls and tumbles your clothes more often and therefore cleans faster. Also, because front loaders spin very fast (up to twice as fast as top loaders) to reduce the amount of moisture left in the clothes, they need to have balanced loads. They accomplish this by testing and rebalancing your load several times during each cycle before beginning to spin.
That was a long answer to your question- no, you are not doing anything wrong.
Good luck.
Jan 28, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore top loader washer - No spin - motor rattles - wtr pmp ok
Bad/broken coupler/
Sep 01, 2009 | Kenmore Washing Machines
Kenmore Elite Washer 110.24992300 spin problems
The pressure switch is mis-reporting the water level to the ECU.
Test/replace the pressure switch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 29, 2009 | Kenmore 24032\24036 Top Load Washer
The washer bounces during spin cycle
Front loaders don't like small loads. There's not enough clothing to settle around to balance it. Only do large loads.
Apr 29, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore heavy duty 2 way tumble washing machine
You may have a broken inner tub spider. Check for play between the inner drum and the outer tub by moving the inner drum up and down.
If there is excessive play, the spider is broken causing an unbalanced load and therefore no high speed spin can be achieved.
In this case the inner drum would need to be replaced, which means taking the machine almost completely apart. A good tech can do it in about 1.5 hours.
Jan 16, 2009 | Kenmore 44102 Front Load Washer
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
And pl rate me if helped.................
Jan 24, 2008 | Kenmore 43142 Front Load Washer
Kenmore 44832200 banging during spin cycle
The support spring beside the spinning hausing are cut replace w/new spring available appliances store. bring sample.
Jan 07, 2008 | Kenmore 44832 Front Load Washer
Broken washer/dryer
This sounds like a motor control board is faulty. Please load a couple of towels in the machine run it. Watch the machine as it goes through its' cycles.
1. Do the towels tumble when the machine is washing ?
2. When it begins to spin, does it spin one way at a fast pace or does it spin one way and then the other ?
Answering these two questions will help in troubleshooting your problem.
Jan 07, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 44042 - No spin cycle
The front load washers are supported by springs on the top and shocks on the bottom.  More than likely you broke a spring on the top or cracked one of the shock mounts which causes and unbalanced load all the time.  Will it go through a spin cycle with no clothes is it?
Oct 17, 2007 | Kenmore 44042 Front Load Washer
Kenmore 44102 Front Load Washer Logo
123 people viewed this question
Sal De
 Brian Main
Brian Main
