Question about GE WJSR1070A Top Load Washer
GE WJSR 1070A Leaking
When Washer starts filling with water and immediately starts leaking out of the bottom of the Washer. No water leaks are occuring at any pipe connections. Maybe something is wrong with the stopper system? Any advice would be greatly appreciated.
  • 1 more comment
  • Anonymous Feb 09, 2008
    Hi I have a GE washer about 7 years old, Model # wbse2090A2ww that started leaking from the bottom last night. It is not the hoses that supply water. Water was pooled under the washer. Appreciate the help.
  • Pathun Mar 31, 2008
    water leak. None of the hoses are leaking, it just leaks from the bottom after cycle starts.
  • gjeanne1 Jan 13, 2009
    when the washer started to fill up it began leaking underneath, evenutally i ended up with most of 5 gallons on the floor. its not the hoses and when the wash machine starts to agitate it is off alignment and shakes. I just recently had this washing machine moved from one house to another, i was told it was flipped up on its side during the move. when i look under the wash machine while running it appears to be coming from the clear tub but cant tell for sure.
    Sniper:
  • 68 Answers
It sounds like you have a leaking pump. The pump is easy to replace:
#1 Use a shop vac and pull all the water out of the drain line. This will keep you from having to clean up about 1 gallon of water off of the floor.
#2 Lift the front of the machine enough for you to get under and see.the pump just inside the front of the washer.
#3 Lift the 2 retaining clips off of the pump. This will allow you to pull the pump off of the motor.
#4 Remove the 2 clamps off of the hoses.
#5 Install the new pump into the hoses, and reinstall the clamps.
#6 With the retaining clips installed into the motor housing, install the pump.
#7 Attach the retaining clips, and set the washer back on the ground.
You have now replaced the washer pump.
If you have any questions, let me know
Please rate this solution
Posted on Jul 29, 2008
  • 240 Answers
Have you removed the front cover to see if one of the hoses has come loose? If so, can you see where the water is leaking from. If not, remove the front cover (put a putty knife between the top and front cover about 2 inches in from the sides and pop the clips up that hold the front cover, then swing it down a little bit and lift off) and see if you can see where the water maybe coming from. It could be a tub to pump hose, pump to drain hose, water valve to vacuum break hose, etc. Could also be a leaking pump (should be front corner, will notice it), or leaking water valve. I could also be a leaking tub seal. If its a tub seal, you will see water flowing from directly between tub and transmission. Let me know if you find where the water may be coming from, then write me back, and will go over repairs step by step for you. Thanks!!!!
Posted on Jan 25, 2008
GE WASHER STOPS DURING WATER FILL WASH AND RINSE LIGHTS LIT.
there is a small plastic tube that runs from the washer tank up to a pressure switch to let it know tank is filled and to start washing. As water fills it creates increasing air pressure in that tubing. If the tube is clogged at bottom end or is leaking ANYWHERE that pressure bleeds off. Those switches are also adjustable via a small set screw on the switch. Is problem affected by load size? If tube leaks usually it may overfill and NOT shut water fill off. Likely the switch is bad, but inspect that line thoroughly.
Oct 26, 2017 | GE Washing Machines
Why is my amana front loading washer is leaking as soon as i turn it on
If it's leaking immediately it starts to fill check the detergent dispenser isn't clogged up (pull it out and clean warm water and an old toothbrush). Or a pipe to the dispenser may be split, you would need to take off the top panel and observe it filling but beware of high voltages so no touching anything inside with mains connected!!
Jul 30, 2014 | Amana Washing Machines
My GE topload washing machine is leaking
Check the hose that connects to the bottom of the tub to the drain hose. Make sure that hose is securely fastened.
May 29, 2012 | GE Washing Machines
Hotpoint washing machine model vbxr1090b2ww leaking from bottom of unit
Here are some solutions.
Hope this helps you...Jim...Please leave a comment...Thanks!
LEAKS ALL THE TIME Is your GE washer leaking all the time, even when not in use? If so the problem is the fill hoses or the valve. Look behind the washer to see if water is coming from the hoses. If not, take the cover off to the control panel. Once off, you should see if the water valve and if there is leakage - it needs replacing (if it is leaking). This is the most popular water valve for GE top-loading washers made after 1995 and the part number is WH13X86 Order Here. show?id=6bjnatppuce&bids=92089.1&type=10. Note that some models have a water valve with more than two coils. In this case, you will need to order the valve by model number at AppliancePartsPros.comshow?id=6bjnatppuce&bids=92089.10000015&type=3&subid=0 Buy Fill Hoses Here. show?id=6bjnatppuce&bids=92089.1&type=10
LEAKS DURING FILL CYCLE Is your GE washer leaking during the fill cycle? If so the problem may be in the valve. Follow instructions above, only this time start the fill cycle before looking at the valve.
If your washer overflows with water during fill cycle your problem is the water level control or the water valve. If you must cut the water off from the house plumbing to stop the water then there is no need for testing, just replace the water valve. First, you need to turn on the washer. The washer should start to fill with water, now cut the washer off and on repeatedly (note to yourself whether the water turned off every time). If it does cut off every time you cut the washer off, then it's most likely in the water level control. If it keeps running after you cut the washer off then, the water valve is bad and needs replacing. (Note that the valve can stick intermittently so it still may be bad if it passed the test) Water valves can be purchased at AppliancePartsPros.comshow?id=6bjnatppuce&bids=92089.10000015&type=3&subid=0
If the water valve doesn't stick in the first test then you need to check the water level control. First, remove the front of washer (insert butter knife between the top and the front pushing on the clips) then look on the side of the tub and you should see a tube attached to a box. Remove the tube (make sure all the water is out of the tub) look in the tube to see if is stopped up. Often it will stop up near the end. If it is, you can clean it out with a toothpick. Once it's clean, reinstall it and your washer is fixed. If the tube is not stopped up reinstall the tube. Now set the water level control on the lowest setting and start filling the washer with water. If the water stops when the tub is approximately half full (this varies with every model) turn it up to the next level (you may have to reset it). Repeat until the tub is full. If at any the water level gets above the last row of holes in the tub, unplug the washer. If the water stops running when you unplug the washer, replace the water level control. If the water doesn't stop, turn the water off at the wall then replace water valve. Water level contorls and water valves can be purchased at AppliancePartsPros.comshow?id=6bjnatppuce&bids=92089.10000015&type=3&subid=0 . LEAKS DURING WASH Is your GE washer leaking during wash? If so the problem is the tub seal (seals around the transmission where it goes through the tub), drain hoses (including the tub to pump hose) or the pump. First take the front off the washer (insert butter knife between the top and the front, pushing on the clips) then start the fill cycle. Now start watching until you see a leak. If the leak is coming from the tub seal, the transmission needs to be replaced (note that changing the transmission is expensive and takes special tools, so you may consider replacing the washer). If the leak is coming from the drain hose or the pump you need to replace it. If you don't see it leak at all, your soap may be the problem. To check this fill the washer with water and the amount of soap you normally would use. Then start the washer and watch the tube coming from the left back of the tub (the overflow pipe). If soapsuds come out of the overflow pipe then try cutting down on your soap or switch to another brand. This may fix your problem. These parts can be purchased at AppliancePartsPros.comshow?id=6bjnatppuce&bids=92089.10000015&type=3&subid=0
LEAKS DURING PUMP OUT Is your GE washer leaking during pump out? If so the first thing you should look at is the drainpipe (to your house plumbing). Fill the washer with water, and then turn it to spin and start it. Now while it's pumping, look at your drainpipe if water backs out (it may not back unless you have soap in the tub), then the problem is in your plumbing. If it doesn't, follow the same steps as above in "leaks during wash." Only this time watch for leaks during pump out as well.
Feb 13, 2011 | Hotpoint VBXR1090B Top Load Washer
MAJOR leak in new JUST installed WCVH6800 front load washer
If you hear of a solution, let everyone know. Our machine did the same thing. From the research I have seen, GE makes **** machines and I will NEVER buy a GE product again.
Feb 07, 2010 | General Electric WCVH6800J Front Load...
My GE Washing machine appears to be leaking from the bottom
It sounds to me , you need the seal and bearing kit.. It is over 300.00 dollar repair, if it is an old washer I would say go get a new one
Jan 13, 2010 | GE Profile Performance WPSF4170WAA
Our washing machine started leaking lots of water during the fill and empty cycles. Water pours out of front bottom left corner. Any ideas as to what is wrong?
My Maytag Ensignia washing machine leaks large amounts of water when filling and during spin cylce. What could be wrong?
Jan 04, 2010 | GE WSXH208A Front Load Washer
Water leak
it sounds like the bleach fill line. at the top of the washer is a bleach fill cup, it might attach to it. this black bleach fill line attaches to the bleach fill cup to the bottom of the tub.
Jun 15, 2008 | GE WHRE5260E Top Load Washer
GE WJSR1070A Top Load Washer Logo
283 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
