Question about Dell UltraScan P992 19" CRT Monitor
Toshiba CF3272B Hi. Sometimes the screen goes dark but the audio continues. I suspect the issue to be a function of temperature because it recovers after turning it off for a period of time. Is this a component failure and an easy fix, or should I just scrap the set? Many thanks for your assistance. Gerald
    Top Expert:
  • Dell Master
  • 50,337 Answers
Depends on AGE of the monitor I personally would bin it and go for a new one
Posted on Jan 02, 2018
headstrong
  • 233 Answers
SOURCE: Screen Blackout
Don't bother with DELL if out of warranty, they can't fix it. Have the same model and same problem
probably It is a bad inverter board, in my case one of the 16 transformers is burnt out on the inverter board. still trying to find a replacement component. if not replacing the board is the only option or getting the inverter board repaired.
by the way, this TV has a Samsung panel: model LTA320W2-L03. so it needs parts for a Samsong not a DELL.
DELL does not manufacture or fix them becuase they don't make them
Posted on Dec 28, 2007
dragon_sun25
  • 107 Answers
SOURCE: Dark Screen Inspiron 9100
If you replaced the inverter board and its still dark you need and new backlight itself http://cgi.ebay.com/LCD-Backlight-Lamp-for-Dell-Inspiron-9100-15-4-WXGA_W0QQitemZ150217509448QQcmdZViewItem
Posted on Dec 10, 2008
20YrsCompExp
  • 227 Answers
SOURCE: Hi! my computer doesn't start normally it goes back to the same error every time. Errors: Floppy diskette seek failure Drive 3 not found: Parallel ATA,PATA-1 (PRI IDE Slave) Strike the F1 key to conti
Sounds like you have a bad/disconnected Hard Drive and the system is looking for a second boot device (ie: Floppy with a disk) or your primary IDE channel on your motherboard is bad
Posted on Apr 16, 2009
rhozel2010
  • 269 Answers
SOURCE: vizio 42" plasma image is dark & fading audio is good
how old is your plasma tv
Posted on Aug 04, 2009
  • 136 Answers
SOURCE: can't figure out how to restore the screen
goto control panels then to personalize then monitor settings or display setting and change it there.hope that helps
Posted on Nov 25, 2009
This is an LCD tv . Toshiba 40xv648u .Audio is good screen is dark. was taking longer and longer to come on.
Since the picture died slowly i suspect a capacitor on the powersupply board,if the screen flashes then goes black and sound is ok
could be the inverter board that drives the lamps.
Len..
Feb 28, 2014 | LG Televison & Video
HP 2000 POWER BTN FLSAHES DARK SCREEN
Try removing the power supply, battery, hard drive and RAM. Plug in the power supply and press power. If the screen recovers, add the RAM followed by hard drive. If it stops working at any point, that is the issue. If it still doesn't work, I suspect a GPU issue. (Possible overheating). If it now works, maybe a bad connection.
Dec 30, 2013 | Computers & Internet
Hi, I have Toshiba Satellite A305 S6905 model.
It is more on a hardware issue. The battery needs to be drained. Once on, let the battery drain and re charge it for 4 hours.
Oct 29, 2013 | Toshiba Satellite A135-S2386 Notebook
My Toshiba M55-S325 won't display on the screen
the back light is the issue, the right thing to do is to try and find one that comes togeather as 1 the back lights on these things can sometimes cost as much as the screen itself. Ebay can be your friend in these situations
Jan 17, 2010 | Toshiba Satellite M55-S329 Notebook
Toshiba Satellite Goes completley off! Black screen, NO POWER!
Hi Steven, in my experience as a tech support agent, it seems that you're having an issue with your hard drive, sometimes it might also be an overheating issue, to be clear on that, please be sure to check the temperature of the computer when it shuts down, then the first symptom of the issue seems to be the clicking sound which ussually comes from the hard drive's reading head, this might indicate the hard drive is damaged and that it cannot perform as usual. The steps to troubleshoot the issue will be as follows; First please enter the BIOS/ System Setup of the system, by pressing the [Delete] as soon as the computer turns on several times, you will appear in a black or blue enviroment with some information from your computer. Check if the issue will happen there as well. Second, if the computer gets really hot at the point when it shuts down, please ensure that all the fans in the computer are running (you should be able to hear them), And be sure of the temperature when it shuts down, we must know if the computer is too hot to touch, or there is no problem with it. Third step, how long will the computer stay on? Will it always shut down at the same time?
The best solution for this issue would be to replace the hard drive, or defective fans depending on the troubleshooting results, if you're still within your 1 year warranty with Toshiba, you should contact their tech support team to replace the part.
As an aditional step to the troubleshooting you should also try to remove the hard drive, and let the computer on for as long as its necessary, to discard the hard drive from the issue, if it doesn't shut down then the hard drive seems to be the problem.
May 03, 2009 | Toshiba Satellite 1805-S274 Notebook
Toshiba lap top screen goes blank
My laptop got problem with the interface the screen appear like gray.
Dec 15, 2008 | Toshiba Satellite M115-S1061 Notebook
Screen goes dark
Either the backlight lamp or the invertor for it is failing. I suspect the colors and contrast isn't as it once was either.
Dell UltraScan P992 19" CRT Monitor Logo
56 people viewed this question
Alun Cox
