Question about Garmin iQue 3600 GPS Receiver
Fritzed Unit when antenna up
I bought my iQue 3600 in 2005 and it has worked great until about 6 months ago. Now, even after charging, the unit only stays on for only about 15 seconds when removed from either the Hot Sync or Travel Cradle. Also, in what seem to be a separate problem, whenever I extend the antenna to turn on the GPS, the unit fritzes out and gets stuck in a continuous reset loop where it resets itself every second and only ends when I close the GPS antenna. All other functions appear to work fine.
  • Sqelam Jan 25, 2008
    Actually, I called Garmin Tech Service. There is a software problem and they were very helpful in getting me to download the patch and install it. About 30 minutes total and no fees.
  • kram 6 Feb 09, 2008
    i am experiancing the same problem and have linked it to the waas being enabled when i disable it the unit will behave with gps on.
Why does the backlight on top of my iQue 3600 won’t turn off?
Posted on Apr 08, 2008
I have a similar problem but I can't turn the GPS off at all, even when the antenna is down. As far as the power on/off cycle, I found another link on this site that said to turn off WAAS while the GPS is off then when you turn it on the unit will not power cycle continuously. You loose the WAAS feature but the GPS and unit still works.
Posted on Jan 25, 2008
Sirius Receiver goes silent and displays Acquiring Signal.
I have a 3 year old Sportster 2 replay unit that worked perfect until 1 month ago. I posted my problem on this website a day before you did with this same problem. I googled to no end and even spoke to Sirius who wasn't willing to replace my unit at no charge since it was out of warranty. I found an unusual solution on the internet that worked for me. I place my receiver in the freezer for at least 20 minutes (this was recommended by a guy somewhere on the internet with the same problem). I have actually left it in freezer overnight too. This has solved my problem. It is the craziest thing but I thought I would try it before I resorted to replacing all my accessories and receiver since Sirius was less than cooperative with the issue. Anyway, hope this helps.
Jun 04, 2009 | Sirius Satellite Radio Receiver
Garmin iQue M5, Not aquiring satellites
Two possibilities - Antenna (in power cable) or electronics related to antenna. First, do a hard reset. Place the pen top into the RESET hole for 3 seconds...
Next, when the unit is powered, page over to the screen showing satellite signal strength....
If NONE appear within 1 minute (and you are outside and NOT under trees), you have an antenna or antenna interface issue.
Garmin WILL repair the unit for 3 to 4 times its value... A 265WT GPS is cheaper, faster and more accurate. The IQUE is no longer worth repairing....
-Jim
Apr 07, 2009 | Garmin iQue M5 GPS Receiver
When antenna is open screen starts flipping out of control
TRY USING AN EXTERNAL ANTENNA. THIS SOLVED MY SIMILAR PROBLEM.
LENN
Mar 20, 2009 | Garmin iQue 3600 GPS Receiver
Ique 3600 antenna reception problem
How long does it try to find the satellites? If it trys for a half hour of more with no results, the antenna may be broken. I have read in other forms that people have added an external antenna and their units would then work, evfen with the built in antenna broken.
Feb 25, 2009 | Garmin iQue 3600 GPS Receiver
No serial number for Ique
I have the same problem, I bought one off ebay from
s.gifjohnthefisherman_123
If he does fix this for us make sure you post a negative, the way ebay list sellers now is based on rating.
Jun 06, 2008 | Garmin iQue 3600 GPS Receiver
Ique 3600 does not work why?
Well unfortunately, sounds like it's replacement time.... same problem I had with mine. Even with an external antenna...no or little signal. Garmin charges $200 canadian for an exchange unit.
So much for costumer support.
Good luck.
Apr 28, 2008 | Garmin iQue 3600 GPS Receiver
IQue Resets itself when using antenna
When I left it running eventually it came up with a "Fatal Alert" message:
"SystemMgr.c, Line 5852, SysLinkerStub(): Failed to load the Shared Library.
I don't know what this means or how to correct it. I am in the Caribbean and was also affected. Thanks!
Victor
Feb 26, 2008 | Garmin iQue 3600 GPS Receiver
IQU 3200 no longer finding any sattelites
Try using and external antenna. If that works your internal antenna is kaput.
Jan 06, 2008 | Garmin iQue 3200 GPS Receiver
Garmin 3600 GPS issue
I just started having the same problem today too. Go to preferences for gps. I did it by clicking down where the battery symbol is and where the satellite indicator comes up. Then click the quegps in the top left hand corner of the screen. Click preferences and disable WAAS. Seemed to work fine after that. I would like to have WAAS enabled so if you find anything else let me know. Wierd that happened on same day. Let me know s.conley@hotmail.com.
Sep 25, 2007 | Garmin iQue 3600 GPS Receiver
Unit will not charge, changed battery but still does not work... Help
Sound as though you shorted something on the main board when you installed the new battery. Just sell the unit for parts on Ebay
May 03, 2007 | Garmin iQue 3600 GPS Receiver
Garmin iQue 3600 GPS Receiver Logo
99 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
