posted by XMOZZAZX on Jan 24, 2008
I bought an Emerson Av101. I hooked it up normal and correct. I have used it for some time with no problems. The subwoofer now 'POPS', more of a 'GAGOONK' sound actually.
I have tested the wires and the subwoofer for problems and they seem fine. It happens when the volume is low more than when it's high. If I have it up loud, it seems to go away entirely, but when a movie goes quiet for any length of time or when I have it turned low, it seems to happen more.
Is the system overloading somehow?
Comment by XMOZZAZX, posted on Jan 27, 2008
I can't get inside with destroying the box somewhat, I am going to try to cut it open and then redesign the plate to go back on. I agree though, the problem is more than likely inside there.
Best Solution
posted on Jan 24, 2008
have u checked for loosened pieces in the subwoofer case ?
Most probably is the wire that connect on to the speakers membrane, that broke off from the glue it holds it ...
also check the filters ... (the capacitors , see if they are inflated,burned, or blackened, and if so change them ..)
Rating Locked! (?) XMOZZAZX has rated this solution as Helpful
Suggest a new solution for this problem
Post a New problem for Emerson AV101 System
Email this problem
Email this problem
Can you Help with these Home Theater Systems problems?
yamaha rxv-992 receiver wont...
Hi, my yamaha receiver power on... Answer This...
Repair Service
Find Home Theater Sys. Repairman Near You:
