Question about Logitech QuickCam for Notebooks Pro Personal Web Camera
AIM software/ Web camera
AIM software, pop up message says AIM can not find the (web) camera
How can I get the software to recognize that a camera is installed and available for use
  • 2 more comments
  • Imua Jan 28, 2008
    Found out that the camera only works with the software that comes with the camera (10.5) and not the latest available (11.5)software on line. Also need to download the AIM software within the camera software to get the camera and AIM in sync and to recognize each other.
  • Anonymous Mar 04, 2008
    D link
  • Anonymous Apr 02, 2008
    i have webcam and i want a software that can make me use it
  • coiley59 Oct 19, 2008
    i have similar problem,i used to have windows xp,my web cam worked ok for a long time then it just stopped working,so now several months later i have a new pc with windows vista,and am still with aol 9 vr.i can exchange pictures with aim messenger but not web cam,the cam works ok with yahoo and msn messenger.i tried going into device manager but it doesnt seem to have a list with tick marks in there just gives the name of my web cam etc,and says this device is working ok.i have also tried uninstalling and re installing aol vr but problem is still here,how can one just delete and re install the aim buddy list set up??is that possible,the problem is frustrating,especially as the aim will let you do anything on it except let you use the web cam,you dont even get an error message just says"connecting to user"but it never does,sometimes it says firewalls stopping it but have tried with it switched off,and still it happens.aol tech guys are useless,the web cam is working fine it is a lifecam vx-1000,please please need some help kind regards mike.
Ok
ok
Posted on Sep 30, 2008
Assuming your camera works with some other software or online application the problem is probably AIM...uninstall and reinstall AIM. If it does not work with other software go to device manager in Windows and make sure the device is listed without an exclamation mark next to it. If there is one reinstall the driver. If any of this is not clear....bug me. 80% chance one of the above should solve the problem. Tango...
Posted on Jan 25, 2008
How can i install a usb web camera
If the web camera came with an installation disk, use the disk to install drivers then plug the web camera in a USB port. The computer should recognize it. If it is properly recognized it will work with all applications that support a webcam (Skype, MSN, Google chat..) If it is not recognized and you do not have an installation software, you should go to the manufacturers web site to download appropriate drivers.
Apr 21, 2011 | Computers & Internet
How to i get webcam working on acer 5732z
1.
Install the web cam software. Before deciding to install the disc that came with the camera, check the Internet for an updated version of the software and download that if available.
2.
Plug in the web cam. The software should give a prompt at the appropriate time. Cameras are usually installed with a USB cable. If installed correctly, the computer will acknowledge so by popping up a message saying it can see the new device.
Now you are done. Your web cam is ready to use.
Thanks.
Have a great day.
Oct 16, 2010 | Acer Computers & Internet
I have a Dell 530 S Dell Inspiron. Its Webcam has stopped working. Any solutions
The very first step is of course to check your web cam connection. Most web cams use the USB port to connect to the PC, so check if your USB cable is properly plugged. For build-in web cams this steps does of course not apply. Many new laptops have a build-in web cam. Also try connecting your web cam directly to your PC instead of through a USB hub (if you are using one).
The next thing is to do is to check your Windows Device Manager and see if the hardware is recognized and installed properly.
It might be that the hardware is recognized as a camera, but the right drivers are not installed. The yellow explanation mark will indicate a problem.
Other devices in Windows XP device manager
If the device is not recognized in Windows XP, Right-click the device, and in the pop up menu select Update Driver Software. Then follow the instructions on screen, but make sure you allow Windows to search the web for updated drivers.
In case no driver for the web cam can be found, you can try a third party driver finding program that scans your PC for installed hardware and allows you to install missing drivers.
If this fails, the next step would be to un install the software that came with your web cam. Use the Add or Remove Programs feature in the Control Panel. If that does not work you can use a third party un installer.
After un installing the software, restart your PC and then reinstall the web cam software. In most cases this will solve the problems. Depending on the software, you might need to unplug your web cam during the software installation.If your problem is not fixed then you have to buy a new one.
Hope the above information will be helpful to you.
Thanks.
Oct 08, 2010 | Dell Inspiron 530 Desktop Computer
I have problems with my hp web camara it freeze it a lot on messanger any help
If your web camera freezes check your Windows Device Manager and see if the hardware is recognized and installed properly. It might be that the hardware is recognized as a camera, but the right drivers are not installed. The yellow explanation mark will indicate a problem. If the device is not recognized in Windows XP, it will be listed under Other Devices
In either case you can try to update the drivers. Right-click the device, and in the pop up menu select Update Driver Software. Then follow the instructions on screen, but make sure you allow Windows to search the web for updated drivers. In case no driver for the web cam can be found, you can try a third party driver finding program that scans your PC for installed hardware and allows you to install missing drivers.
If this fails, the next step would be to un install the software that came with your web cam. Use the Add or Remove Programs feature in the Control Panel. If that does not work you can use a third party un installer. After un installing the software, restart your PC and then reinstall the web cam software. In most cases this will solve the problems. Depending on the software, you might need to unplug your web cam during the software installation.
If the drivers and web cam software are correctly installed, and you still it freezes, there can be a problem with the program settings. Most chat and meeting software have a configuration option to select the video source for the web cam feature. If you have multiple devices that qualify for video, you might need to select your web cam device as the source for the web cam feature in that program. Some web cams and programs require additional software, although that should be installed with the web cam if things are right. But is does not harm to check if your Java, Flash and Quick time software are installed and up to date. But certainly check your DirectX software, since all video applications, including web cams, use DirectX for video processing. Try downloading the latest DirectX version and install it (Windows XP: DirectX 9.0c – Windows Vista: DirectX 10).
Thank you !!
May 30, 2010 | HP EW192AA Webcam
How do i install my web cam ew192aa
Plug the camera's USB cord into a free USB port on the computer, if this hasn't been done already. After giving the computer a moment to recognize the camera, a balloon will pop up saying new devices have been found.
Insert the web camera's installation CD, and wait for the installer to appear. Click "Next" on each window as needed to install the software. If the installer does not automatically appear upon inserting the disk, open "My Computer", right-click on the CD drive, click "Explore", then open "setup.exe".
Launch the web camera software, which can normally be found in the start menu under "All Programs". Test the camera to ensure it is working properly.
Save a tree.
Apr 13, 2010 | HP EW192AA Webcam
I have a canon 300D rebel digital slr camera unable to download p
maybe the your HP pc doesn't recognize your slr camera. download a software or driver for it on the web site of the canon.
Mar 05, 2010 | Office Equipment & Supplies
Aim!!!!!!!!! problems
hi if you tell the model no. of your webcam i can help you with a software download for your webcam
Feb 14, 2009 | Logitech QuickCam for Notebooks Pro...
Aim/ichat is blocked on my school mac
use meebo.com
login with ur aim id..njoy...
Dec 24, 2008 | AOL Instant Messenger
USB
visit the web site of fuji finefix camera .com , you may select right driver of the camera.
Jan 28, 2008 | Fuji FinePix A500 Digital Camera
LOGITEC WEB CAM ~ NO SOFTWARE
www.download.com
Look there, also try google, explain a little more about your AIM problem
Dec 28, 2007 | Logitech QuickCam Express Web Camera
Logitech QuickCam for Notebooks Pro Personal Web Camera Logo
122 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
