Question about Canon Pixma MP500 All-In-One InkJet Printer
MP600 - Says inside cover is open - but it's not!
I've tried everything short of uninstalling and reinstalling the software. All I did was check one of the ink cartridges and now I can't print because it keeps saying the inside cover is open....ANY suggestions ???
  • Anonymous Feb 28, 2008
    Scholar:
  • 66 Answers
This is a hardware problem nothing to do with software; somewhere inside the printer a cover is not closed correctly.
Posted on Jan 30, 2008
Print job disappearing and not printing
1. Check for a paper jam. Paper jams occur when one or more sheets of paper become stuck in the feeding or printing mechanism. Gently remove any jammed paper and reset the printer.
2. Check ink levels. Those ink cartridges run out fast. If your printer looks like it is printing but nothing comes out on the page, you might be out of ink. Try replacing the cartridge and printing again.
3. Check for a clogged print head. If you know you have ink, the print head might be clogged. Navigate to "Control Panel > Printer > Right Click > Properties > Maintenance > Clean Cartridges" to attempt to clean the print head.
4. Reinstall printer drivers and software. If none of the above helps, try uninstalling and reinstalling the printer and software to correct possible software bugs, errors or conflicts.
Canon-Specific Issues
5. Check printer drivers. Navigate to "Control Panel > Printers > Right Click > Properties > Update Driver" to check for a new driver for your printer. You can also find drivers and software on the Canon Support site (see Resources).
6. Resolve the Waste Ink Error. Press menu on the printer and press scan/copy to enter service more. Press the right arrow to access "NVRAM." Set ABS-M level to 0. Set ABS-P level to 0. Press "Stop" to exit.
7. Resolve Wrong Cartridge Message. Turn off the printer and unplug the power cord. Remove the cartridges and the print head. Clean the print head in lukewarm water. Set it aside to dry. Clean the contacts gently with an eraser and wipe with a tissue. Reinstall the print head and reinsert the cartridges. Run a cartridge alignment.
8. Resolve E0D02 error. Clean the cartridges and the sender strip. The sender strip is behind the rubber drive belt behind the main hatch. It runs horizontally across the machine. Wipe it gently with a lint free cloth.
Aug 19, 2012 | Canon Pixma Mp250 Printer
Tip
When a Inkjet Printer does not Print.
After we have installed our Printer Software and we think our Printer is ready to Print. Even after we have carefully installed the ink catridges. There are times our Printer will not Print.Here are a few helpful Tips on making sure the Printer will Print.
1. Check all connections to the Printer to the Computer and to your wall outlet.
2. Make sure before you install your Inkjet Ink Cartridge that you peel off the small plastic tape that covers the tiny hole on the Ink Cartridge .After peeling off this tape insert your Ink Cartridge into the proper place. It should just snap in. Also most Printers now can not use generic ink It calls for the manufactors brand of your Printer in some cases..Check your Printer Documentation.
3.Make sure your Printer Software is installed properly.
If your Inkjet Printer does not Print .Try all these measures and even try uninstalling the Printer Software and reinstalling your Printer Software.
on Jul 29, 2010 | Office Equipment & Supplies
My epson DX8400 won't print yellow at all, green prints as blue, red prints pink on certain documents i've created. I have printed an email off today which printed all the colours perfectly??
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken . Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or poor ink cartridge contacts. Sometimes the power supply unit must be checked as a poor SMPS unit can deliver low voltage and cause issues to the printer function. Check all the leads and connections of the mother board , the tags to the ink cartridge. Also check the mechanical settings of the ink cartridge , if jammed or tight remove motor and manually free the drive before it is set back.
Thank you for using Fixya
Aug 22, 2011 | Office Equipment & Supplies
My i550 won't print When I turn it on there's a short grinding noise Then there's a short green flash, then short orange, short green, short orange then longer green This cycle then keeps...
Aug 18, 2011 | Canon BubbleJet i550 InkJet Printer
We just bought a new ink cartridge for our HP c5580 all in one printer. All the other colors print fine - EXCEPT BLUE. It comes out as a "tealish" looking green. We've tried cleaning the...
Jul 08, 2011 | HP Photosmart C5180 All-In-One InkJet...
I recently replaced the light magenta and magenta ink cartridges and now my printer will not print any of the red tones. There was no error message or anything to indicate a problem. I've tried...
poor ink cartridge
Jun 15, 2011 | Office Equipment & Supplies
My Dell V505 printer won't print documents from the computer, when I press print the printer prints a page of dash's and ticks. there is ink in the cartridges. i've disconnected the power....
Turn the printer off.
Disconnect the AC power.
On your computer, click Start
Click Control Panel
Click Printers
Select the Dell Printer
Uninstall it
Restart your computer
Turn the printer on
Allow the computer to reinstall the device-device for the printer.
Print a test page.
May 09, 2011 | Dell AllinOne Multifunctional (v515w)...
I've tried everything and my printer won't print ... not even the test page! Frustrated !!!! I have a Dell A960 all in one printer. I use Windows XP ... windows 8 with firefox ... ink cartridges are new...
uninstall ur printer software then try reinstalling ur software if this does not help refer to ur instuction manual and check to see if ur printer is compatible with the type windows u are using
Jul 25, 2010 | Dell A960 All-In-One InkJet Printer
Prints purple instead of black on photos only
My Canon printer has TWO slots for black ink cartridges. I assumed one was extra and didn't replace it when I ran out. Text printed just fine with only one installed, but my photos were printing with purple instead of black. I looked into it, and the two cartridges are different: one holds dye-based ink, the other has pigment based. Photos must require both kinds. If your printer is the same as mine, use both!
Jul 23, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Canon Pixma MP500 All-In-One InkJet Printer Logo
129 people viewed this question
old marine
old marine
