Question about GPX HM3817DT Shelf System
Auto timer My problem is that I want to learn how to operate the clock built into my GPX system. I don't have an operating manual because I bought it at a second-hand store. My system is old and stands about a foot and a half high. It's probably called a tabletop model because it has a lid on top that covers the turntable. Every night at 6:55 p.m., my CD player is activated, which is very annoying when I'm watching TV or talking on the phone. It has a 5-disc changer, double cassette player, AM/FM radio, and turntable. Although it does have a clock and a timer, it has no buttons that say "set time," "clock," etc. Thank you. Marcia
  • 25 Answers
What is the model of the radio and i can surley find out for you.
Posted on Mar 04, 2008
BO6255SS - The clock turns on but we are unable to set it and therefore cannot turn it on. Can you help?
this is as much as the manual says
After your appliance is connected to your mains supply for the
first time, the numbers on the timer display will flash. Before
you can select a cooking function or set a temperature, you
must set the appliance into manual operation mode.
o To select manual operation mode, press the manual operation
button (9) on the control panel.
http://www.manualslib.com/manual/956107/Baumatic-Bo625ss.html?page=3#manual
Jun 02, 2016 | Baumatic Ovens
I have installed a new adjustable thermostat unit (E1-BCANRT1W). Temp is set at 91 deg and I am using the timer. Two time periods are set and the switch is set to timer (not ON). The unit comes on at...
Double check your slide switch.
For timer: set switch to TIMER
For thermostat: set switch to ON
If slide switch does not operate, then Autocirc may be defective
Laing (800) 554-6853
http://waterheatertimer.org/pdf/Laing-E1-E3-E10-install-instructions.pdf
http://waterheatertimer.org/pdf/Auto-circ-manual.pdf
http://waterheatertimer.org/Water-heater-recirculation-system.html
1) Household AC wiring will not affect the timer.
You can check your outlet using cheap circuit analyzer from home center.
The clock rotates one direction and the pins push small lever down which turns motor on-off.
When the OFF pins pass, the small lever snaps back and the motor turns ON.
I cannot immediately find operation manual for the E-1 model.
Typical ACT303 auto circ manual says following:
2) If timer controlled operation is desired, set timer and move slide switch to TIMER:
Manual says: tabs/pins are outward for ON times.
Another sentence says UPWARD, so I don't know which way the pins are set for sure.
So if you want timer ON for 2 hours, you would set 4 consecutive pins outward or upward.
ON for 6 hours, set 12 consecutive pins outward or upward.
If the timer turns ON in reverse of instructions, then set the pins that way.
Autocirc does not make the timer, they buy timer modules from clock-makers like Grasslin, Intermatic, etc.
3) To operate Autocir thermostatically without the timer, slide switch to ON position.
The clock dial will continue rotating
Apr 14, 2011 | Laing Thermotech Autocirc Undersink...
My D61 e delongi cooker will not work the oven at all ,the cook top is fine
Most common oven problems are;
Faulty oven element - check continuity with meter - if faulty replace;
Burnt wiring at the oven element terminals - visual check - if faulty repair;
Electronic clock/timer on auto. - clock timer must be on manual for manual oven operation.
Feb 16, 2011 | Ovens
GE Wall Oven Model # JKP07G0D2BG - The clock has quit working. Any suggestions would be greatly appreciated.
I assume the display for the clock/timer is now blank. If the oven is still working the only thing you are missing is the clock. If you can't do without it you will need a new clock.
Most of the time the clock/timer stops working it affects the operation of the oven, the oven won't work. If this is the case you will need a new timer unless you can do without the clock/timer. If so a repairman should be able to bypass the clock with ease so that the oven will operate without the clock/timer.
Feb 12, 2011 | GE 24" Built-in Single Electric Wall Oven...
I am trying to st the timer to turn on at 5PM and turn off at 11PM.
You posted under Intermatic HB88RC timer
If you have different timer, add a comment
HB88RC timer manual:
http://waterheatertimer.org/pdf/hb88rc.pdf
HB88RC programming Instructions:
Install AA battery in timer so display will show, and you can program
Set clock:
Hold down clock button.
Press day button until current day displays.
Press Hour button until current hour displays.
Press min button until current minute shows.
Release clock button
Program timer:
Press PROG button until 1 ON displays
This is Event1 ON
Press Day button until selected day or days displays for event1 ON
If you want all week long, then press day button until all days show: MO TU WE TH FR SA SU
Press Hour button until 5pm shows >> this is event1 ON
Press Min button until :00 displays for event1 ON
Press PROG button until 1 OFF displays
This is Event1 ON
Press Day button until selected day or days displays for event1 OFF
Match days with ON time: so press day button until all days show: MO TU WE TH FR SA SU
Press Hour button until 7pm displays >> this is event1 OFF
Press Min button until :00 displays for event1 OFF
When programming is finished, press clock button to display current time
When programming is finished, press MODE button to select MODE > you want AUTO for timer programs to operate
Press MODE button once and this is manual override, and lights come on.
Press MODE button again and RDM displays, this is for random timer operation
Press MODE button 3rd time, and timer is set to AUTO
After setting MODE to auto, press clock button to display current time.
Plug timer into receptacle.
Plug lights into timer.
Dec 18, 2010 | Intermatic HB88RC - 7-Day Programmable...
Need operating manual for GPX TCR340 clok radio...
Customer helpline: 1-314-621-2881
I have the User's Guide V:1050-0714-09 but cannot make a PDF to upload.
Sep 20, 2010 | GPX TCR340 Clock Radio
Timer stopped running so I replace timer motor. However the timer still does not run. I can still turn pool pump on manually. Will I have to replace entire unit?
T103 clock motor is 125 volt WG1570
1) If you bought the 240V WG1573, the clock will not operate
2) If you connected the motor wires to wrong terminals, then clock will not operate.
3) If original box label says T103, but 240V T104 was installed in same box, and you bought wrong voltage motor
4) Test for 120Volts across terminals A and 1, and make sure clock motor matches voltage of timer, and clock motor wires are connected to terminals A and 1.
Open following links:
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#103
Jun 26, 2010 | Intermatic T103 Indoor 120-Volt 40-amp...
I need the user guide for the time Tracker countdown timer
SET AUTO TIMER 1. Press and hold START and ENTER buttons at the same time for 3 seconds. 2. Press buttons until SET AUTO appears on the display. 3. Press ENTER. 4. Total Time: (Enter the total amount of time. It will automatically split between green, yellow and red lights). Use buttons to scroll through numbers and ENTER to accept. 5. Sound?: Do you want a sound effect at the start of the green light? 6. Yes/No: Use buttons to move cursor and ENTER to accept. 7. If yes, use buttons to scroll through sounds and ENTER to accept. 8. Repeat steps 7 and 8 for yellow and red sections. 9. Press MENU.
Feb 03, 2009 | Learning Resources Time Tracker Visual...
GPX HM3817DT Shelf System Logo
167 people viewed this question
Top GPX Audio Players & Recorders Experts
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
