usually the manufacturing code will be like 1234,0000,or 9999 and if you have some type of set top box from your cable company same code should work unless you have changed itusually the manufacturing code will be like 1234,0000,or 9999 and if you have some type of set top box from your cable company same code should work unless you have changed it
You can't post conmments that contain an email address.
It is locked. Unlock it. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Unlock procedure and to override the password lock to many popular brand TVs are given. Search the site by type in this key phrase "How to unlock television"; in the search box at the top left of the display window, to get gathered related posts.
the three function keys across the top are in cellphoneese referred to by the acronyms lsk csk and rsk. (left center right) so csk is the large center joypad key. press it ..try a few times until you see the 'press * to unlock' popup then pressing * shows you 'keypad unlocked' then i turned the silly feature off
OSD Lock/Unlock Allows you to secure the current control settings so that they cannot be inadvertently changed. You can unlock the OSD controls at any time by using the same procedure. Push and hold the Menu ( ) button for 10 seconds or more to Lock or to Unlock.
I am having the same problem ,your TV has been child locked.In order to unlock it , on the remote control,there is a MUSIC BUTTON.You must press and hold this button for about 10 seconds and it will unlock your TV
