Question about Acer AL2016W 20" LCD Monitor
Acer P241W LCD Monitor
I can not get this monitor to work with my computer.
When I go into settings -- it shows the correct setting, but I get no picture when I connect the new monitor.
Can you help me?
Mine freezes in standby and I have to turn it off and then turn it on again each time
Posted on Mar 08, 2008
Acer p241w stays standby
CHECK IN BIOS MODE ,THIS PC NOT GOES TO STANDBY SO PROBLUM IN YOUR OS .FORMATE PC NOW CHECK .
Aug 31, 2017 | Acer P241W 24 inch Monitor
Comes on for second with picture and goes black. turn off and back on will do same thing.
Sounds like it is probably the inverter board. You can find one on eBay, they are usually the problem, not the backlight or screen. Simple change usually and you are good to go. Very inexpensive too, search ebay for inverter board acer P241W, or I have gone to laptopaid.com too.
Dec 17, 2009 | Acer P241W 24 inch Monitor
Can't change the resolution of ACER X193W. All attempts to change the resolution come up with "... not supported". What is the problem?
check in your computer graphic drivers are installed correctly.
If installed then when you power up the computer press F8 key then enter in enable vga mode.Set screen resolution to 1024*768 then apply and ok.
You can set screen resolution in control panel dispaly property.
Jul 14, 2009 | Acer X193W LCD Monitor
Hp laptop is has docking station connected to acer monitor. The acer monitor has the desktop background but does not show desktop icons. How do I get the icons to show on acer monitor
you will probably find that you have set the screens to run side by side, do a check by clicking the identify monitors, icons will be normaly on the left screen, check the dispay settings and you probably want to set the monitors so they both are showing the same screen at the same time.
good luck.
Jun 30, 2009 | Acer AL2016W 20" LCD Monitor
"No signal" msg on new Acer X193W LCD Monitor with Vista 64-bit
this should be easy...go to your desktop...right click on it and choose "personalize" it will open up a window. on the bottom it will say display settings...click on it...at the top right it should say "identify monitors" click on that...if that dosent work.click on the monitor that has a 2 on it and it will ask you if you want to add a monitor...it should work
if not, post a comment and i will check back with you
Jun 21, 2009 | Acer X193W LCD Monitor
I have 3 acer al1603w widescreen monitor.. it was working ok before, then i let my brothers used them. afterwhich it is displaying "input not supported". WHOAAA!?!!? what do i do? its bugging me for 3 days...
Sounds like somebody messed with the monitor setup on the monitor controls. Check the manual to set it up correctly. If they changed the monitor's Frequency settings, the problems you are having will occur. Gotta set them back to 70Hz and check the other settings. If you need a manual, get back to me with the exact model number of the monitor.
Jun 11, 2009 | Acer AL1916W 19" LCD Monitor
No monitor display
Return the monitor. I had one like that and I replaced it with a Dell.
Mar 23, 2009 | Acer AL2016W 20" LCD Monitor
Distorted picture on 20 inch monitor
second problem some unit on the board in the monitor has gone bad return it for an exchange
first problem the display setting need to be set correctly
Dec 28, 2007 | Acer AL2016W 20" LCD Monitor
Horizontal lines lcd monitor
I think monitor is defective. Contact manufature
Dec 13, 2007 | Relisys RLT1720 17" LCD Monitor
Acer monitor
you have to change the monitor setting in the display box in windows properties right click to get in windows desktop/settings/display resolution
Nov 24, 2007 | Acer AL2016W 20" LCD Monitor
Acer AL2016W 20" LCD Monitor Logo
158 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
