Question about Minolta PagePro 1300W Laser Printer
Unwanted repeat printing
When turning the computer and printer on in the morning, it prints again the last page of its previous print run. You might suppose that this is a minor problem, except for the security aspect. Can anyone help please?
    Sniper:
  • 60 Answers
There are 2 possible reasons:
  1. The last printjob remains in the COMPUTER'S memory
  2. The last prinjob remains in the PRINTERS memory
You can easy find out in witch case you are by turnig on the printer in the morning before turning on the PC.
If the page from yesterday do not print without the PC on then try reinstalling the printer (after uninstalling it - or delete it from Control Panel - Printer and Faxes). Pay attention before shutting off the PC if there are running jobs in the printer. (doubleclick the printers icon in Control Pannel - Printer and Faxes). If they are, try to delete them before shutting the pc off.
If the page do print evan without the PC turned on, than it's in the firmware and i have to admitt that i dont know exactly what the solution could be, but let me know and i'll search again.
Posted on Jan 25, 2008
HP psc 1100/1200 all-in-one stopped printing
Press and hold the cancel button and then press the start copy button release them together.
You should print a test page. No Test page an internal printer problem is likely!
If test page is good reset the spooler \. More than one way to reset spool file. Spool file controls transfer from computer to printer. Spool file a mess then printer hangs!!!
Method 1
a. Go to Start / Control Panel / Administrative Tools / Services
b. Select "Print Spooler".
c. While Print spooler is stopped, start it by double-clicking on "Print Spooler" and then click the "Start" button.
d. Verify that the "startup type" is set to "automatic".
Method 2
Create a new txt file
Type in exactly as the following text:
net stop spooler
del %systemroot%\system32\spool\printers\*.shd
del %systemroot%\system32\spool\printers\*.spl
net start spooler
Rename txt file killspool.bat
save on desk top
Double click off of desktop file to run
Next time printer hangs you can use this file again
Hope this helps?
Dec 03, 2016 | HP Office Equipment & Supplies
Image of last print shows up on presant print
This is usually caused by the left over toner not being properly cleaned from the transfer belt.
Open the printer front cover and close it. Wait for the printer to cycle. It usually make a little noise then stops. Then open the cover and close it again. Then print.
If the first page of the print out is clean. but the next page you print has a shadow of the first page, then you have a a problem with the cleaning mechanism.
Unfortunately the cleaner is part of the image transfer belt assembly which runs about $150 to $200. Unfortunately not terribly cost effective as compared to the original cost of many of these printers.
Good Luck.
Feb 11, 2014 | Samsung CLP-315W Laser Color Printer
Got to work this morning and the thermal printer had continuously printed the previous days manifest until it had run out of labels. I inserted new labels and it started to print the manifest again. I...
Uninstall the printer and restart the computer once installed reinstall the printer from the CD that came with the printer or get the latest software / pilots from the printer's web page
Jul 21, 2011 | Datamax E-CLASS DMX-E-4203 Label Printer
Previous prints
Hello sir; The reason is the previou memories not clear that's why when you turn on it print last memories left over from last time, go to manu, looking for memory to clear memory.
Aug 28, 2009 | HP Photosmart C3135 All-In-One InkJet...
Epson R230 printing unwanted lines
The problem is waste ink around head sprayer (at (bottom plate of head). Turn of printer. Move head to center. Put wet tissue (with hot water) at head cleaning mechanic pad. Move head to parking position. wait till 10 minutes. check it. You can repeat 3 times.
Jun 09, 2009 | Epson STYLUS R230 InkJet Photo Printer
My hp deskjet 5150 will not stop printing
If you are using Windows XP
1. Click start then run then type in cmd then click ok.
2. Type in NET STOP SPOOLER
After that in the lower right corner of your screen you should see a printer icon. Delete the queueu
If that still does not work Unplug the power from the printer then wait for 5 mins then restart your computer and turn it back on.
Nov 11, 2008 | HP DeskJet 5150 InkJet Printer
My HP printer 2420 leaves "ghost" prints on the pages.
This can be caused by one of two things.
1. faulty wiper blade on your toner so that the previous image in not being wiped off the drum.
2. worn fuser sleve.
To work out which it is you will need to do a half stop test: print off a normal document then when it is about half way through the printer ( unfortunatly you may have to repeat this to get the timing right) open the front cover. remove the toner cartridge. if you can see the ghosting on the page the it is the toner. if its not there then its a new fuser. to save on money and if your confident enouh you may be able to just chane the fuser sleve depending on the state of the fuser on a whole.
hope this helps
feel free to email me if you have any other questions:
pete@wedotoners.com
Oct 21, 2008 | HP LaserJet 2420 Printer
Scanner leaves three vertical lines on scanned page
A dirty glass base can cause ‘spots’ or blemishes to appear on your final printout. Additionally, if you had some sort of opaque liquid that may have transferred on to the glass base from a previous operation. But the majority of the unwanted vertical lines are generally caused by either a dirty or damaged print roller or faulty LEDs in the Scanner Module.
To separate one from the other you have to check the following:
Do you only see the lines with a Scan operation?
Do your print jobs print fine without any unwanted lines?
If you only see the unwanted lines during a Scan operation, then most likely you have a fault/dirty/obstructed LED module.
If you see the unwanted lines with all print operations (Scan, Print and Copy), then you most likely have a worn out, damaged or dirty Print Roller.
Hope this helps…
RojoSho
Sep 29, 2008 | Brother MFC-7820N Laser Printer
Prints a decription of my print job on one page ... additional unwanted page.
It sounds like you are printing from Word 2007. Go to the Office Button, Print, Print, Options and under "Printing Options" uncheck the "Print Document Properties" box.
Regards,
Bob Headrick, MS MVP Printing/Imaging
Jan 22, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Last page of printing stops 3/4 through the page.
Try cleaning your heads with appropriate solution. Then, cancel all print jobs. Try again. If it does the same i would turn it off, inplug all the cables, replug all and turn on. Try again. If still no good, completely unistall printer then reinstall it. Try once more. Good luck
Jan 16, 2007 | HP PSC 2175 All-In-One InkJet Printer
Minolta PagePro 1300W Laser Printer Logo
90 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
