Question about PC Desktops
Problems updating bios
I am trying to find an update for my bios but on the asus website on the downloads page i cant find my motherboard model number. i have checked the motherboard itself and embossed on it is ptgd-la and on my computer it says my motherboard is a puffer2 . i have recently bought a new graphics card ( nvidia 8600gt super) and i have tried to install it and i am having problems . i have been told i need to update my bios and the should resolve any problems i am having. my computer is a hp
any help would be greatfully appreciated.
  • 1,601 Answers
Re: problems updating bios
Unlucky me,
Here is the latest bios fro HP. If this too old please let me know ,so I can look further. Thanks.
Posted on Jan 24, 2008
0 characters
3 Points
Where do I download the latest BIOS setting for my desktop.
You have to visit the motherboard manufacturers support website to download the latest BIOS version for it.
Apr 28, 2011 | PC Desktops
Asus motherboard bios recovery
Rank:guru_s.gif Guru
Rating: 85%, 1169 votes
In the disk you burned, the bios can't read a zip file, the file needs to be extracted and as far as I remember you need to use a diskette instead of a cd. but I will look into it now.
Comment by Ekse, posted on Aug 07, 2008 Bios warning
Please note, BIOS update is only recommended when experiencing technical difficulties with your system, And is not recommended to be performed regularly.
Moreover, due to the nature of BIOS update, there is certain level of dangers involved. BIOS update must be performed with extreme caution . During BIOS update process, your system must be maintained without interference or power loss to prevent unexpected damage.
In case of BIOS update failure, please follow instructions in your User's Manual for guidelines on BIOS recovery via CrashFree BIOS. In the event that BIOS recovery is not recoverable via CrashFree BIOS, please contact your place of purchase for further assistance on BIOS recovery.
Source Asus
You can get the bios from here
Get the 1008 version
its under Bios and 3rd entry, all os version 1008
File is in zip format, needs to be extracted.
the rom file inside needs to be placed in a diskette.
Comment by Ekse, posted on Aug 07, 2008 Diskette or if you can get the bios to read a cd then that is fine also. Comment by Ekse, posted on Aug 07, 2008 if the setup is looking for a file named as
it may be required to rename the PV8XX08.rom to P4V8X-X.rom
But im not perfectly sure what you are trying todo or why it is asking for it. il have to look into this more. Comment by Ekse, posted on Aug 07, 2008 As I suspected, BestDarnGood linked us the manual and the correct page about the problem. it confirms that the file has to be renamed and placed in a floppy.
Thanks BDG
Aug 07, 2008 | PC Desktops
Bios recovery Asus motherboard P4V8X_X
Did you run the utlity to put the firmware onto a floppy disc or cd so that it can boot up on the disc to install it?
The utility is available for download in the same section that you got the firmware update from.
When you unplug power cord it loses it settings even though cmos battery is good g
If the battery is good for sure and you tried a different battery just to be sure then you might want to try updating the BIOS. Go into the BIOS and see the version that is in there.
Then go here:
Type in your model number and then get to the download page and see what version is on the website. If the version of the BIOS on the website is newer then on your machine then download and install that one.
If you update the BIOS and it still can't keep the settings then you know at that point the motherboard is bad.
Nov 28, 2009 | HP Compaq d530c PC Desktop
Want to updat bios for xp
Operating system doesn't have an effect on the bios update process. Simply you can go online and search for your motherboard's website for BIOS flash utility, and new bios files. And through that website, you can follow the instructed steps and update your BIOS. (For example: Asus Mainboard Model P5GD1 Pro -> Go to Asus international website and select your mainboard model, you can find the tools and updates related with your particular model there). You just have to look up for your mainboard's complete brand and model name first.
Apr 14, 2009 | PC Desktops
BIOS Upgrade
bios update will be avilable in the site of your motherboard itself
Jan 26, 2008 | PC Desktops
New computer won't boot -
I had a similar problem with asus. 1) check online that the motherboard supports that cpu. Mine did not. I had to return it. 2) try the memory in different slots and combinations 3) try a different video card 4) check the CMOS clear jumper os properly set to disabled. Set it to enabled (power off first) 1 time to clear it. reset jumper back to disabled, and power on as usual. I'd suspect the motherboard needs to be flashed, but you obviously cannot flash it without it working... return it to point of purchase, or have them flash it and show you that it's working with your processor before you bring it back home.
Aug 26, 2007 | PC Desktops
We want to update bios for motherboard asus (p4bgl mx) model please let us know how we can procced and where we can find the bios drivers for motherboard.
Just follow the link below
In product select motherboard
In series select socket478
In model select your model P4BGL-MX
click on search then select your oerating system and then download the BIOS and run the file to update the BIOS
Apr 12, 2009 | PC Desktops
Desktop hp Product Number P6402A
Step 1: Find the current BIOS version number
  1. Turn ON your pc. When the first screen appears, press F1 to enter the BIOS Setup. On certain Compaq Presario PCs (prior to 2002) press the F10 key at the logo screen to enter setup.
  2. The BIOS revision number is listed on the Main menu. Write down the current BIOS version that is listed.
  3. To exit the BIOS setup screen, press F10 , select Yes , and then press the Enter key.
Step 2: Check the Drivers and Downloads page for BIOS or ROM updates
  1. Go to enter the model of the PC (for example, Presario 5002US or Pavilion a518d), and click the download button.
  2. Click the link for the PC Operating System (like Windows XP).
  3. Try to find the BIOS update listed under the heading, BIOS , BIOS- System , or RomPaq.
    NOTE: The term "Rompaq" refers to BIOS updates for Compaq Presario PCs prior to 2002.
  • If a BIOS update is not listed, HP does not have a BIOS update posted for your PC at this time.
  • If there are several BIOS updates available for different motherboard names, you need to find out what motherboard is installed in your PC. This can be done by turning off the power to the PC, removing the side panel, and reading the name that is printed on the motherboard. The name of your motherboard should match or be similar to the name of the download link.
  • If a BIOS update is listed, proceed to the next step to download and install the BIOS update.
Step 3: Download and install the BIOS update
  1. Click the download link. The instructions for downloading and installing BIOS updates vary.
  • For most PCs with Windows XP, download the file, open it and follow the on-screen instructions.
  • For many PCs before Windows XP, save the downloaded file to the hard drive, insert a formatted disk, open the downloaded file to copy the BIOS files to the disk, and then restart the computer with the disk still in the drive.
  • The instructions on the download page may be different so carefully read and follow the instructions on the download page and in the installation setup screens.
  1. If a 251 or CMOS Checksum error occurs after installing the BIOS update, perform the following steps:
  2. Restart the PC and enter the BIOS screen by pressing the F1 or F10 key at the first screen.
  3. Press the F5 key to load the default BIOS configuration.
  4. Select YES by using the arrow keys, and then press Enter .
  5. Press the F10 key to save the settings and exit.
  6. Select YES by using the arrow keys, and then press Enter .
    When the BIOS update is complete, the new BIOS revision number is updated on the Main BIOS screen.
Please rate this solution. Thank you.
Feb 01, 2009 | PC Desktops
Abit NF8-V drivers (non-bios)
  • Bios Downloads
  • Bios Motherboard Update
  • Bios Updates
  • Bios Drivers
  • Vista Driver Update
  • Driver Scan; Registry Scan; BIOS Update; CD/DVD-ROM Drives; Hard Drives; Infrared; Input; Modem; Monitor; Network; Other; PCMCIA ... All Drivers. Scan Computer For All Drivers Driver Updates
    Best of Luck ! Please dont for get to Vote.Thank You
    Dec 11, 2007 | PC Desktops
    PC Desktops Logo
    146 people viewed this question
    Top PC Desktops Experts
    Brian Sullivan
    Brian Sullivan
    Are you a PC Desktop Expert? Answer questions, earn points and help others
