Question about Claris Draw (DRAWV1) for Mac
Claris Draw v1.0v3 will not start with XP
I have used Claris Draw v1.0v3 for many years but not with the Window XP OS, I cannot even get the program to start. Is there some mod to a dll or running mode that is necessary to get the app to work.
  • John Panek
    John Panek Jan 24, 2008
    OK, I have Claris Draw starting up (after a long wait) but trying to open any existing files causes the app to crash.
  • John Panek
    John Panek Jan 28, 2009
    Solution Found!
    I found that Claris Draw files must have a filename of 24 characters max (including suffix). But, program will not startup correctly and open a file. Problem is that path+filenames (incl suffix) greater than 64 characters cause the app to fail.
    Must move files to high-level directory before using (to limit the number of characters to less than 64). Otherwise, ClarisDraw works fine on my XP system.
Right click on the Claris Draw program icon and open properties box. Then select "Compatibility" tab.
Under Compatibilty tab, check "Run this Program in compatability mode for:"
Select Windows 98/ Windows ME option from drop down menue.
Make sure "Claris" folder is in C:\Windows
Now do following whenever you thereafter want to run Claris Draw:
Try to open the Claris Draw program and you should get message saying it can't find Claris directory.
In the message box, browse down to Claris directory and double left click it.
Then left click on any file in the Claris directory window.
Now left click on the Claris directory again, but hold the left mouse button down.
The OK button should stay lit while you are holding the left mouse button down.
While still holding the left mouse button down, press the "Enter" key on your keyboard.
Claris draw should now run.
This nutty start up procedure seems a little complated, but once you get the hang of it, it takes only a few seconds to do it.
Posted on Dec 18, 2008
I found that Draw runs on XP but I have to tell it each time it opens where to find the CLARIS folder, and when it does run it won't respond to the OPEN menu item. I can still open files though by clicking on the file to open, but it's pretty inconvenient. Looks like I'm going to have to run the program on my old pre-XP windows machine.
Posted on Feb 25, 2008
6ya staff
SOURCE:
Can CLARIS MACDRAW PRO V 1.5~SEALED~SYSTEM 7 COMPAT~VINTAGE be run on windows, or is there a way to get a copy of Claris draw for windows
NO ! Forget it..
First it's an OLD MAC program, and not compatible with ANY windows.
Second It's obsolete. there is no manufacturer and no support.
You might acually find a Mac w/System 7 on it to use for this program.. I've thrown away 4.
But here's NO WAY to run it in Windows of any level - At this time.
Use Windows paint.. Or Google search for any number of Free Drawing Programs
Nov 11, 2010 | Computers & Internet
How to draw any kind of drawing.
best program to use for drawing is Microsoft Paint. Go to start, programs, accessories, PAINT.
Oct 20, 2010 | Microsoft Windows XP Home Edition
Claris Draw 1.0v3 will not start in Windows XP
re-install or repair option in program n software windows(control panel)
Mar 09, 2010 | Computers & Internet
It wont llet me downlaod yahoo messager
uninstall the previous version through these steps:
XP OS To do so, kindly follow these steps: 1. Click the "Start" menu and select "Run." 2. Type "appwiz.cpl" and press "OK." (This is a shortcut to "Add or Remove Programs.") 3. Select "Yahoo! Messenger" and click "Change/Remove." 4. In the window that opens, click "Finish" to uninstall. 5. Click the "Start" menu and select "Run" again. 6. Type in "%ProgramFiles%\Yahoo!\" and press Enter. 7. Delete the "Messenger" folder.
VISTA OS 1. Click the "Start" menu and select "Run." If you do not see the Run command, then select Start > All Programs > Accessories > Run. 2. Type in "appwiz.cpl" and press Enter. This opens "Programs and Features." 3. Select "Yahoo! Messenger" and click "Uninstall." 4. Click the "Start" menu and select "Run" again. 5. Type in "%ProgramFiles%\Yahoo!\" and press Enter. 6. Delete the "Messenger" folder.
Disable anti-virus and firewall before reinstalling using this link:
http://download.yahoo.com/dl/msgr10/us/ymsgr10us.exe
Oct 09, 2009 | Yahoo Messenger
I am unable to open Micrografx Windows Draw 6. I used it for clip art but now it won't open.
Hello, I had the same problem. windows draw has been working for years under Windows XP then suddenly impossible. I think there is a conflict with others programs i installed.
I found THE solution after reading many topics on the net :
Install acrobat reader 4 on your system. Then run acrobat reader 4. Last, run Micrografx windows draw 6 while acrobat reader 4 is running on your system too.
Maybe it works with a more recent version of acrobat reader but i didn't try. Maybe this solution works also with windows draw 5 but i didn't try.
Enjoy
Jul 10, 2009 | Micrografx Windows Draw Graphics & Print...
Using Window XP
hello friend
I think you are suffering from a severe virus infection. Try the following steps will improve the health of your computer
  1. you should have different partition for OS and data
  2. reinstall the antivirus
  3. get a disc of the windos Xp sp2 and with that in drive type sfc/scannow
thankyou
May 24, 2009 | Microsoft Windows XP Professional for PC
Umax Scanner Astra 4100 Drivers for Window Vista
required umax astra 4100 scanner driver for vista/win2003 server
Jul 27, 2008 | Microsoft Windows Vista Ultimate Edition
Window problem
repair or reinstall your window
May 03, 2008 | Microsoft Windows XP Professional
CLARIS DRAW 1.0 print problem with Windows XP
Sounds like old software (1995) with a much newer operating system. I would upgrade to whatever is compatible with XP or take your OS back to what works with the software. I'd go with Corel Draw with XP. Vintage software has to be run with the same vintage OS to work properly. Hope this helps!
Jan 07, 2008 | Claris Draw (DRAWV1) for Mac
Open Questions:
See all Claris Draw (DRAWV1) for Mac Questions
Claris Draw (DRAWV1) for Mac Logo
694 people viewed this question
Top Claris Computers & Internet Experts
Ekse
Marvin
Marvin
Are you a Claris Computer and Internet Expert? Answer questions, earn points and help others
