Help me please
The plug that the monitor connects to has two prongs that you screw into one prong has broken off
  • batchelor Jan 24, 2008
    Also the bios has locked up
    Genius:
  • 1,601 Answers
Batchelor:
The "prong" is actually a screw. you can remove it with a good needle nosed pliers. If you have an old computer you can take one off and screw it in your vga port where the old one was.
The problem with the bios, Please give me more info. Were you trying to update it when it happened?
Posted on Jan 24, 2008
How to wire a plug
In USA, Either the male or female plug connector would be wired the same. Black is hot wire and would connect to the BRASS colored round head screw ( Smallest flat prong or slot ). White is the neutral wire and would connect to the SILVER colored round head screw ( Largest flat prong or slot ). Green is the ground wire and would connect to the GREEN screw ( ONLY HEX shaped screw ). 1) FOR YOUR LIFE SAFETY, ALWAYS USE 3-WIIRE PLUGS WHEN REPAIRING 3-WIRE EXTENSION CORDS! 2) Check the male plug connector. It should have two flat and one rounded prong. The rounded prong is the ground wire connection. If the ground prong is missing, replace the plug. 3) Inspect the outer cover for damage. 4) Do not use cords with damaged outer covers. Taping over the damage is not an adequate repair, for safety, replace the cord.
Apr 04, 2014 | Woods Industries 12/3X100FT Yellow Jacket...
I dont understand the digram im tring to hook a plug outlet to plug the the timmerin to the wall and out from the timmer i would like to put a outlet to be albe to plug in my lights
You posted under T102 timer.
This timer is 240Volts, and you can't hook this to ordinary outlet.
Look at inside of timer door to see brand and model number, and then add a comment.
Once I know model number of your timer, I can help you with wiring.
If you have T101 timer:
1) Your power outlet has two prong openings: 1 is wide and 1 is narrow.
2) Black Hot wire from narrow prong connects to Terminal 1
3) White Neutral wire from wide prong connects to Terminal A
4) Black wire going to new outlet connects to Terminal 2, and also connects to brass screw on new outlet.
5) White wire going to new outlet connects to Terminal A, along with other white wire, and also connects to silver screw on new outlet.
6) Bare ground wire connects to green screws.
7) This is code wiring. Black is for Hot and White is for Neutral.
Hot wires connect to brass screw on outlet. White to silver screw on outlet.
Narrow prong on outlet is Hot; Wide prong on outlet is Neutral.
http://waterheatertimer.org/See-inside-main-breaker-box.html
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 26, 2011 | Intermatic T102 Indoor 120-Volt 40-Amp 1...
My dryer's power cord has 4 prongs, my wall socket has 3 holes, can I change the power cord, or is there an adapter to change from 4 to 3 pronges.
Un screw the 2 hex screws from the back of the dryer where the cord goes in.
There will be 3 screws that connect the cord to the dryer, loosen or remove them to remove the 4 prong cord.
A hardware store will carry the 3 prong cord you need, tell them it is for a dryer.
Re-connect the 3 prong cord to the dryer.
Plug in and test after you have installed the new cord.
Jan 02, 2011 | Asko T701 Electric Dryer
I have a 4 prong dryer but the plug in the wall is a three prong, ibought a four prong plug and i dont know how to connect a three wire into a four prong plug please help me.. hugo
Do NOT try and change the receptacle please. It is dangerous and we do not want anyone getting hurt. In your case, it would be better to put a 3 prong cord on the dryer. Overall you could call an electrician to install the 4 prong receptacle, which will require new 4 conductor wire as well and run to the breaker box. Get a flat style 3 prong dryer cord and we'll tell you how to install it. Unless you call an electrician. ;-) If this helps you, please rate my answer. Thank you.
Jan 07, 2010 | GE Dryers
Brand new dryer threw braker twice, then no heat and timer stopped working. Electrician tightened connections on wires to dryer settings dial, had heat for one load, then same as before. Replacement dryer...
might want to check your dryer outlet. If the terminals are loose in there it could cause you problems. If your dryer plug is a 4 prong you might be loosing one of your 220v legs due to a short . As the dryer runs the wires and connections will heat up and expand , if there is a faulty wire or connection then it may loose connection after a load. could be quite dangerous and a very possible fire risk so i would check it out ASAP . if the outlet is old they sell for about $20 at you local home depot or lowes home improvement. for a 3 prong plug you need to hook up the black and white wires on the brass screws and the copper ground wire to the green screw. in a 4 prong application you hook up the black and red wires to the brass screws, the whit wire t the silver screw and the copper ground wire to the green screw .
If your new dryer is supposed to be a 4 prong plug and you have it with a 3 prong cord then you will run in to issues . The difference being a 4 prong electric dryer is a dual voltage unit where it needs both 220v and 115v to operate correctly, where a 3 prong dryer only has 220v and the earth ground. if your not familiar or comfortable with electricity please call a qualified electrician to come hand handle the work. if not done correctly it can cause fires or possible electrocution
Oct 30, 2009 | Amana NED5500TQ Electric Dryer
I bought a roper with a 3 prong but i need a 4 prong. i bought a 4 prong plug but I don't know where to connect the left over wire in the dryer.
The laws in most states are changing to where the NEC Code requires the use of this 4 prong plug. It is quite common to see this 4 prong plug installed in new apartment buildings and rental properties because of this law requirement.
So what you have is a red, black, white and green wire on the dryer side of this wire plug.
The red and the black wires are your hots (110 volts) and shall be connected on each outside screw of the drier electrical terminal and the white wire (neutral) shall be connected to the center screw.
So now you are left with an extra green wire with no place to hook it huh?
I suggest just loosing one of the drier electrical terminal mounting screws and hooking it there. The ideal here is to ground the outside body of this machine to prevent possibility of electrical shock if water is present (like a leak somewhere nearby).
In actuality this really serves no viable purpose because the white wire does exacly the same thing, just in a different manor,,, but hey,,, our law makers are not certified electricians either. They just like new ways of stimulating sales and profits.
Note: if you are in a rental property and this 4 prong wall receptical is installed, I would not suggest you remove it or change it in any manor, as this will open yourself up to possibile legal liabilities if an incident were to occur,, like fire.
Oct 09, 2009 | Roper REX4634KQ Electric Dryer
Hi boughr Acer monitor 191w.IT HAS 15 PRONG AND 24 PRONG LEADS CONNECTED TO MONITOR BUT i DONT HAVE A 24 PRONG OUTLET ON MY COMPUTER.i HAVE NO SOUND SO I AM ASSUMING THIS LEAD IS FOR THAT.i have another...
No just connect the 15 prong vga plug and dont worry about the 24 prong one15 prong is vga and 24 is dvi both are for video and will not affect the sound. The audio should have a jack plug on it.
Dec 03, 2008 | Acer Computers & Internet
4 prong to 3 prong
connect green wire back to cabinet rear at green screw..in a 4 wire hookup the green wire from the dryer was supposed to be either cut off or attached back to neutral(center screw)
Oct 24, 2008 | Roper REX4634KQ Electric Dryer
I have a 3-prong plug on a 14-year-old dryer. Now must change to 4-plug. Is that possible ... and if so, how?
A three Prong contains L1 (Line1), L2 (Line2) and N (Neutral). A four prong will contain L1 (Line1), L2 (Line2), N (Neutral) and G (Ground) typically a green wire.
Connect the three wires as normal, connect the green wire to the screw provided on the cabinet.
Jul 04, 2008 | Dryers
Computers & Internet Logo
Alun Cox
David Payne
David Payne
