Question about Hotpoint FFM90 Bottom Freezer Refrigerator
My fridge freezer motor was making a whole lot of noise
The fridge light has blown, the casing does not fit properly and the noise from the motor is extremely loud. It continually makes a cracking noise as if something is being snapped. When you open the door it does quieten down, but does not stop. It now no longer works and with Christmas around the corner we were hoping for a quick cheap fix.
There is a fan that blows air over the condenser coils under the fridge in the back. You will have to pull the fridge out away from the wall, remove the screws that hold the access plate or panel that covers it. There is probably something catching the fan. This would be a good time to clean as much of the evaporation coils with the light brush or vacuum. It could be the fan is shot but these things operate on a low speed and last a long time. Check this first before doing anything else, The screws are generally removed with w fillips screwdriver of you may have to find a set of small sockets to remove them. It is possible that the compressor is broken in which case you will need a new or used fridge which you can find all over.
Posted on Oct 21, 2017
SOURCE:
  • 1462 Answers
SOURCE: Hotpoint Fridge freezer FFA90 - Noisy fan top fridge
worthwhile checking closer. noisy fan can be due to fan blade hitting ice if there has been a build-up. otherwise needs replacing
Posted on May 07, 2007
  • 1314 Answers
SOURCE: Loud Banging Noise
if its a loud banging noise when the unit kicks off then broken spring in compressor will have to replace compressor check your 2-5th year warrenty in your owners manuel
Posted on May 14, 2008
  • 1462 Answers
SOURCE: Refrigerator making loud noise and fan: help!
take raer panel off inside freezer and check there is no ice build up which is hitting the fan
Posted on Jul 18, 2008
godtech
  • 51 Answers
SOURCE: Model HSS25IFMCCC GE Refrig motor/fan making loud noise
UN THAW YOUR REFRIGERATOR FOR 8 HOURS IF IT STOPS GREAT IF NOT.REPLACE YOUR FAN/IT IS LOCATED BEHIND THE TOP PANEL OF YOUR FREEZER.UN PLUG YOUR FRIDGE FIRST.BUY THE PART AT A APPLIANCE PARTS STORE,AND YOU CAN DO IT IT IS A EASY REPAIR.
Posted on Jan 16, 2009
  • 10865 Answers
SOURCE: Fridge and Freezer quit working
If your ice maker has stopped producing ice completely, check these, in this order:
  • It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these:
    • If your ice maker has a small red plastic lever, lower it to lower the wire.
    • If there's no plastic lever, simply lower the wire.
    In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
  • The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary.
  • The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Posted on May 30, 2009
My fridge is making a lot of noise. It does not stop. What might the problem be? Model# 2539668010 Serial# BA62202425
This is a basic no frills refrigerator so that things that can make a lot of noise is limited. And where you say it doesn't stop, then it is most likely a fan. You have two one in the freezer compartment that could have accumulated some ice on the blades which could through it out of alignment. So it might be hitting the sides of the case.
The other fan is underneath your cabinet, and blows air across the compressor, and condenser coil. If there is a lot of lint or debie in this area then the fan blades could be come coated and then the out of balance condition could cause noise.
If a cleaning doesn't fix the problem then you will probably have to replace the fan blades and motor.
Jul 05, 2011 | Kenmore Top Freezer Refrigerator
LG french door fridge - makes hideous noise - loose bearings? - whenever fan is running, which is several times an hour. Any idea what is causing it? Husband tried to grease the fan. It's really...
A broken fan blade can cause a noisy motor. or a buildup of ice can cause some noise. If thes aren't the case you will need to have the fan motor replaced.
Jan 04, 2011 | LG LRFD25850 French Door Refrigerator
Samsung refrigerator RS2556SH purchased Oct '05. Problem: Refrigerated side not cooling adequately. I removed vent cover to expose evaporator coil and discovered a few 1/2" tears in tubing, which appear...
Insufficient cooling is a fridge repair job that you can do without the help of a professional. Often the fridge has a frost-free failure, or the compressor is faulty but there are many other reasons for a fridge not cooling properly. Step 1 – Find the Problem
Your first job is to locate the source of the problem. Consider each of the following:
* Gaskets - Make sure the gaskets/seals are not torn and are sealing properly. * Evaporator fan – Make sure it is working. If it is now working you may have a problem with the fan motor. Check for power to the motor and also examine the fan switches around the door (not all fridges have these switches). * Air damper – Sometimes the air damper will not open up to allow the cold air from the freezer part to blow into the fridge section. * Condenser coils – Check to see that the condenser coils don’t have a dust build-up and that the condenser motor is working. * Compressor – Make sure your compressor is working with on and off clicking noises.
Thanks for using fixya
Aug 08, 2010 | Samsung RS2556 Side by Side Refrigerator
I have a Whirlpool Refridgerator model WBM39MS. It stopped cooling and I had it repaired. The Repairman replaced the electronic control box. Repairer claims that the compressor is working. It now seems...
Hi Lollipop, partially working fridge? A fridge either works or not, cold air is made in freezer then distributed to fridge via a vent. In your case WBM Series fridge, top mount freezer blows air down a vent (back centre of chiller compartment). A common fault with the WBM Series is both the PCB and Interface Panel (PCB beside compressor back of fridge, Interface is display panel front of fridge).
So if freezer is cold and fridge not, try a fan motor. If compressor doesn't work either comp is faulty or PCB has blown(has a burning smell).. Hope this helps you and maybe many other ppl.
Jan 21, 2010 | Refrigerators
Fridge makes chirping noise
Some areas noise may come from:
Inside:
Whenever the refrigerator is cooling a circulating fan is operating to move air through the freezer and refrigerator. This fan can be found in one of several locations: For freezers positioned on top of the refrigerator the fan can be found on the back wall at the center of the freezer; If your freezer is on the bottom then the fan will be near the top on the back wall of the freezer; and if your freezer is on the side the fan will be on the back about 1/2 way up or near the top.
These fan tend to wear out over time and make a noise like a whistle or chirping sound. Open the freezer and press any switch. If the noise is louder with the door open the motor that operates the evaporator fan is likely the cause. This fan cannot be serviced in any way and must be replaced.
The back of the refrigerator:
The compressor, defrost timer, or the condenser fan motor may be the cause of noise from the back. The compressor is located near the bottom and is identified by it's small black case that appears to have no moving parts, but several colored wires coming out of it. If you find the compressor is what is making the noise then you will have to replace it in order to get the noise to stop, these aren't serviceable (and can be expensive). Near the back of the refrigerator you'll also find the condenser fan. Sometimes this fan gets clogged with debris and can make a lot of noise as a result. If this is the case then simply clean the blade with a soft bristled brush, you can usually get one of these brushes from a hardware store, or you can order it from us by calling our 800 number. If it doesn't need to be cleaned then the whole motor may need to be replaced.
The defrost timer is usually found behind the kick panel. The timer has an electric motor attached to it that may become noisy over time and will need to be replaced in order to get it to be quiet again.
The bottom of the refrigerator:
Noises detected at the bottom of the refrigerator almost always originate from the back of the refrigerator. However, sometimes the drain pan under the refrigerator will rattle. You may need to tape the pan in place to stop a rattle. Also see the “Outside back of the refrigerator.”
Sep 21, 2009 | Refrigerators
My fridge freezer made by samsung is on the blink
These fridges have an evaporator fan motor on both sides - the freezer and fridge side. The freezer can maintain it's temperature because that fan is working fine. I had the same problem, and replaced the evaporator fan motor on fridge side, and it solved the problem. Also, if your fan motor is not working well, or stops working, the evaporator is prone to ice build up, and will prevent proper cooling. You may want to open up panel on fridge side and see if that's the case. Taking a blow dryer to the evaporator and surrounding area (while fridge is off), or letting it sit for a few hours might solve the problem. Ultimately though, it appears as if these fan motors are prone to failure, and need to be replaced.
Dec 19, 2008 | Samsung 24.8 Cu. Ft. Side-by-Side...
We have a fridge/freezer model srs758dp 12 months old tongight has started making a huge rattling sound from the back of the unit on certain cycles goes for a fair while when we open freezer door it stops,...
this sounds occurs due to fan & frost inside the coil
check weather evap.cover has fitted properly.if frost is there defrost the fridge for at least for 24hrs it will work properly
Jun 10, 2008 | Samsung Refrigerators
Samsung american style fridge/freezer needs repairing
Spray a good quantity of WD-40 on the spindle of the fan motor where it enters the motor itself. This should get the fan working smoothly with no noise. This will probably solve the other problems, as the fan prevents various components from overheating and shutting down.
Apr 01, 2008 | Refrigerators
May 07, 2007 | Hotpoint FFA90 Bottom Freezer Refrigerator
Fridge motor is very very noisy
It sounds like it could be ice around the fan motor. Unplug it and let it defrost for about 12 hrs with the doors open. Plug it back in and see if it has quit making the noise. If it did it probably needs the defrost timer replaced. Good luck. kstfas
Sep 29, 2006 | Hotpoint FFM90 Bottom Freezer Refrigerator
Open Questions:
See all Hotpoint FFM90 Bottom Freezer Refrigerator Questions
Hotpoint FFM90 Bottom Freezer Refrigerator Logo
114 people viewed this question
Top Hotpoint Refrigerators Experts
Steve Allison
Steve Allison
Carmen Mikulic
Jose Pino
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
