Question about Creative Labs Zen MicroPhoto MP3 Player
Turning on My player turns on and everything, its just that when i do turn it on the screen says "rebuilding library". it takes me like five minutes to finally get to my music, and when i do, it doesnt display the title of the song im playing its just says, "select music to play". It still plays, its just kinda screwed up, any help would be greatly appreciated!
  • bartonizer Jan 24, 2008
    k thanks, but every time i go to install it it says that my player isnt connected to t he computer (even though its charging in the computer)? wuts up with that?
  • Anonymous Jan 28, 2008
    Having a very similar problem here, but I can't use the Recovery Tool that was posted. The reason is that when the library has been rebuilt, the player freezes. While frozen, it isn't recognised by the computer, so when you try and run the Recovery Tool, it says there's no player connected. The on/off doesn't respond either, so I removed the battery - but that just means that next time it's turned on, it goes into library rebuilding mode again before freezing. Vicious circle :(
    President:
  • 4,402 Answers
Try downloading the MP3 player recovery tool from Creative's website (the tool contains the latest firmware update available -- 1.15.03). Plug your ZV+ into your PC, run the program and let it update the firmware. Then format, reload your music and try it.
By the way, before updating the firmware, let the battery have a full charge, ok?
I hope it won't keep freezing on you after the update
Posted on Jan 24, 2008
  • Cary Farah
    Cary Farah Jan 24, 2008
    the power is a different connection then the signal.
Sony walkman NWZ-B135F doesnot turn on properly.. When turning it on 'Walkman' text appears and '.......' is appearing. after that no action.tried resetting also, no use
First guess. you have a large library and just added something. it is rebuilding its index
Second guess: you have other files than just music on here. it is rebuilding the library and has to scan all the non-mp3 files. Mine takes about 2-5 minutes to boot after adding / removing files
Oct 06, 2009 | Sony Walkman NWZ-S616F MP3 Player
My sony nwz-E436F turns on and gets stuck on the ''Creating Library'' screen and then shuts off. can anyone help
try to reset your sony or try to reformat your sony. then try to rebuild your library
Aug 01, 2009 | Audio Players & Recorders
Turns on and then goes to rebuilding screen then says firmware problem but computer doesnt register that its hooked up
check on the zen site and make sure you have the current version for your zen.
download it and do a rebuild with new firmware.
this mp3 has a hard drive, the exact one that the ipod has. They are not immuned from crashing for sure.
But doing a reinstall of the software will probably help alot.
May 19, 2009 | Creative Labs ZEN Vision:M Digital Media...
Creative Zen Rebuilding Problem (Freezing)
Hold the reset button with a paper clip AND the play button at the same time while flipping the power switch. The ZEN should go into recovery mode. You probably want to do format all but you can try the different options. You also may need to download/update the firmware here.
Feb 07, 2009 | Creative Labs Zen Digital Media Player
I have a sharp dv-rw260h. I put a DVD in to check what was on it and the machine won't stop 'reading'it. Cannot get machine to do any other function whilst it is 'reading and cannot find a manual dvd...
Turned machine off at the mains for about 15 minutes. When I turned it back on, it started 'reading' again but then a message came on screen saying that it was checking the disc....it said that the procedure would take about 15 minutes but stuck on 'five minutes left'. Tried the eject button again after about 2 hours and the drawer opened. Checking message still showed so I turned the machine off and on again and everything was fine.
Jul 23, 2008 | Televison & Video
Frozen
if it keeps on rebuilding the library the disk had a bad spot on it try going in to recover mode and do a clean if that doesn't work do a format if that doesn't work download the latest firmware if that doesn't fix you will need a new hard drive or flash drive.
Nov 15, 2007 | Creative Labs Zen Micro MP3 Player
Freezes at "rebuilding library"
I just found this on another website and it seems to be working so give it a shot
Listen!!!!! Anyone having problems try this before you blame the product. Turn off player........remove battery.......hold on button ON and put battery back in while still holding the power button on. When power comes on release the power button. You should now see a clean format and re-boot screen. Use the clean function two times. After the second time go down to reboot and should be fine. Worked for me. The Zen Micro Photo is a sweet mp3 player. Dont blame the product for something YOU most likely did. This will fix 99% of your players problems
Nov 12, 2007 | Creative Labs Zen MicroPhoto MP3 Player
Frozen screen in shut down mode
ow!!! you got a virus! a doomboot virus and or flakes virus! do not open again your mp3! you have to remove your virus with twister series!
Oct 11, 2007 | Creative Labs ZEN V Plus MP3 Player
Zen Micro
Sounds like it may be the index in your Music Library. Try going into Recovery Mode; remove battery, hold power switch to ON, replace battery, release power switch when the Recovery Mode screen appears on the screen. Run Option 1 CleanUP, after it completes run Option 4 Restart. You will get a Rebuilding Library screen when it reboots, that's normal, then it should go back to your startup screen. Good luck and let us know what happened
May 01, 2006 | Creative Labs Zen Micro MP3 Player
Creative Labs Zen MicroPhoto MP3 Player Logo
114 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
