Problem with Toshiba 32A33 32" TV
My CRT TV displays a single horizontal white line across the screen. It will flicker and try to display the picture. If you smack it you'll get a quick picture then back to a line. After about
10-15 minutes of warming up, the full picture will display and stay on (no more line)
Posted by avatar on Dec 21, 2009
Solutions (1)
Best Solution
The single line means that the vertical deflection doesn't work. And since it is working when you kick the tv or has warmed it's clearly a bad connection - open the case and reseat the wires going to the tube coil.
Add Your Solution
See all Toshiba 32A33 32" TV Problems
