Question about Siemens SX66
Resets My SX-66 frequently resets and goes to align screen and everythings gets deleted!!
  • 3 Answers
This always happens to me when my battery wiggles loose. the little sliding catch that holds the battery isn't such a great design, and it easily slides out of it's "locked" position (particularly when i use the heavier extended-charge battery). resultantly, the battery momentarily disconnects and freaks out the operating system. this will happen even when the phone's in a travel case which i thought would hold the battery in place. But the amount of battery movement required for a disconnect is extremely slight. my resolution has been twofold: 1) i diligently backup everything to a 1GB SDcard weekly (they're very inexpensive now) using a great program named SPB Backup (very reliable); 2) i adheared a few pieces of clear plastic to the phone where the battery installs--this causes the battery to wedge more tightly against the sliding lock, and thereby keeps the lock from sliding loose. this hasn't been fullproof, but has cut down from several reboots per week to maybe once every 3 months.
Posted on Jan 30, 2008
ZTE projector needs a factory reset how can I fix this problem
Master reset from settings menu
A master reset restores the original factory settings and may delete your personal data on the internal storage, such as downloads, ringtones, images, apps, contacts, and Visual Voicemail. It does not delete data stored on the SIM card or SD card.
  1. From any Home screen, tap Apps > Settings > Backup & reset > Factory data reset > Reset phone.
  2. If your phone is password protected, you'll be prompted to enter your Pattern, PIN, or Password.
  3. Tap Erase everything.
Master reset with hardware keys
A master reset restores the original factory settings and may delete your personal data on the internal storage, such as downloads, ringtones, images, apps, contacts, and Visual Voicemail. It does not delete data stored on the SIM card or SD card. If the device menus are frozen or unresponsive, you can master reset using hardware keys.
  1. Back up data on the internal memory.
  2. With the device turned off, press and hold the Volume Up and Power buttons until the ZTE logo screen appears, then release.
  3. Press the Volume down button to highlight wipe data/factory reset.
  4. Press the Power button to select.
  5. Press the Volume down button repeatedly until Yes -- delete all user data is highlighted.
  6. Press the Power button to select.
  7. Wait as the device resets.
Device resets ZTE ZMAX
Feb 12, 2018 | ZTE Cell Phones
How to master reset zte z798bl
Hi @Kyle Glenn
Please follow the steps below:
Hope this helps!
Nov 01, 2017 | ZTE Cell Phones
How to reset iphone 4s
Press the on / off button and the home button in the same time for about 3 or 4 seconds, till the screen blanks and the Apple logo appears. then wait about one minute and switch the phone on again.
There are some more heavy resets, 9n settings, general, last line reset. Reset everything, will reset the phone and remove everything.
second line only removes everything (so just a bit less heavy.)
and every line down will delete less and less.
success
Jul 23, 2014 | Apple iPhone 4S
How to delete everything off htc eris
From http://www.htc.com/us/support/droid-eris-verizon/help/settings :Resetting the phone deletes all data, including downloaded applications, and resets the phone back to its initial state. Press Home > Menu, then tap Settings > Security > Factory data reset. On the Factory data reset screen, tap Reset phone and then tap Erase everything. To reset the phone using phone buttons, with the phone turned off, press and hold the Volume Down + Send + End buttons. The reset process will start after a few seconds.
Dec 30, 2011 | HTC Cell Phones
Ipad screen goes gray
Press round button twice , icon bar should come up on bottom row , press safari icon and it should shake with delete red circle on it . Press delete . Then turn off and turn back on . Usually means screen in safari jamed in a operation. This process dosent delete it of your machine it just resets it.
Nov 09, 2011 | Apple safari
Forerunner 50 resets automatically
I have the same situation with my Garmin. Have you sort this out??
Thanks.
Oct 09, 2009 | Garmin Forerunner 50
My O2 XDA is stuck on lock - i think the screen realigner may have come on in my pocket and been aligned to some wierd place as toch screen not woirkinh - can i reset with lock on - or what can i do ?
take the battery out for 1 min then replace it.
WARNING this resets the system.
then you can access it again but everything is back to default
Aug 10, 2009 | O2 Xda II Smartphone
Gps navigation screen is paralyzed--all other screens are working
hi did you install the software straight to your route 66 maxi using route 66 sync software ? if you did try downloading it to your computer then transfer it on to the memory card using a card reader
Jan 07, 2009 | Route 66 MAXI Car GPS Receiver
Screen align problem
try to do hard reset if its not works
try to update rom image
if still not works try to replace your touch screen to new one
Dec 15, 2008 | HP iPAQ H3950 Pocket PC
Screen keeps un-aligning
The only possible solution to this issue is to hard reset your phone but first back up all your info because when you hard reset the phone it deletes everything.
Apr 02, 2008 | Audiovox PPC 6700
Siemens SX66 Logo
144 people viewed this question
Top Siemens Computers & Internet Experts
Prashant M
Prashant M
john smith
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
