Question about Whirlpool LER3624JQ Electric Dryer
Dryer stopping in middle of cycle but timer continues to run.
My Whirlpool dryer (Model LER3624JQ0) starts drying but then stops as if the door was open and then closed. The timer continues to run and if I press the start it will start again but then about ten minutes later it will stop by itself again. Each time I press the start button and it will start back up again. The tumbler seems to turn without a problem, the belt does not squeal, and the heat element does work.
  • 4 more comments
  • ccjj Mar 10, 2008
    i have the very same dryer and very same problem and was about to purchase an element, wire and thermostat. does replacing the switch fix the problem instead?
  • donny58 Aug 29, 2008
    The dryer was making loud noises so we replaced the belt and drum rollers and now it runs smooth but only runs for a few minutes then stops. So do you think the new belt might be too tight or do you think it's the timer? or motor?
  • Anonymous Nov 17, 2008
    my whirlpool model ler5620kq1 starts and then stops every few minutes, the dryer will heat up but then dryer quits. i have tried the timer on different
    dryer settings with the same results. please help
  • Anonymous Mar 18, 2014
    dryer starts off with 35 minutes on normal cycle. it will run 35 minutes and still have 30 minutes or more on timer
  • Anonymous Mar 25, 2014
    when I turn the dryer on, everything works right until I push start cycle. when I push start cycle the sensor for detecting dampness lights up, the timer starts counting down but the dryer itself will not start running
  • Anonymous Mar 30, 2014
    my dryer door keeps opening up its self every Five minutes and then wont turn back on for an other Five minutes. Why is this?
  • 55 Answers
OK " It's your timer, it has to be replaced
it's not going threw all it cycles, will start but will not finish
not a big job, unscrew plate on back at the top you will see
timer , take it out and replace it
( can not stress enough that you have to unplug the electrical cord from the wall socket before working on a dryer or any appliance )
Posted on Jan 24, 2008
Why won't the buzzer alarm go off at the end of a drying cycle
Search Results
    Why does my Kenmore dryer model 417.94802/94862 end ... > Manage My Life > Questions
    Why does my Kenmore dryer model 417.94802/94862 end of cycle alarm go off ...washer/dryer unit I do see that it is normal for the end of cycle buzzer to go off ...Why won't my Kenmore dryer model 110.86872100 shut off at the end of the ...
    Why won't the buzzer shut off on my Kenmore 80 Series ... > Manage My Life > Questions
    The buzzer won't stop buzzing after the load is complete. ... or turn on the timer and the dryer will start just by selecting a cycle and closing the door. ... The dryer should continue to run and at the end the buzzer should only stay on as long as ...
    FIXED The Buzzer At The End Of The Dryer Cycle Comes On But Won't ...
    Dec 11, 2010 - 10 posts - ‎2 authors
    My maytag dryer has operated wonderfully until today. All of a sudden the buzzer that goes on at the end of the drying will go on but will not shut off unless I open the door.... To test it: by-pass the push-to-start switch and see if when you turn the timer on and close the door, the ... VERY annoying dryer End of Cycle Signal
    Jun 29, 2012
    Maytag DE8410 electric dryer - End of cycle buzzer stuck ...
    Mar 27, 2011
    Kenmore 80 series, buzzer won't shut off
    Sep 10, 2005
    More results from
Feb 08, 2016 | Whirlpool Dryers
I have a Whirlpool AccuDry Dry (Model LGQ8858JQ2). It will start fine, but will stop shortly into the dry cycle and beep three times. The drum turns and I checked the belt. The timer continues..but at
I think that it's a door switch error.
Open the door and locate the door switch. Exercise the switch with your finger about twenty times then try the dryer again. You may have to replace the door switch.
Check youtube for help videos on replacing the door switch.
Nov 05, 2014 | Whirlpool Dryers
Dryer stops but the timer continues on
Fixed! The "push to start" button was stuck. Must have been some dust. I pushed the knob a few times and that's all it took. Works fine now.
Dec 12, 2009 | Kenmore Dryers
I have a whirlpool dryer, model number lgt6634dq0. The timmer does not stop after the drying cycle has ended. My guest it might be the timer. After the dryer has finished it's cycle I can hear the timer...
HI. The timer will be the culprit here. The timer motor is damaged, and the cogs seem to be worn, as well. I recommend replacing this failed timer mechanism. Once replaced, the unit will operate correctly.
Dec 03, 2009 | Whirlpool Dryers
Water fills the washer during spin cycle
defective timer...a model # should be under the lid...or open dryer door and on front dryer panel right hand corner..onthejob
Jan 16, 2009 | Whirlpool LTE5243D Top Load Stacked...
Autodry cycle never stops
hi thanks for the question ther is a thermostat on the air duct at the back of the dryer it has 2 wires at ends and 2 wires in the middle smaller ones this thermostat opens to turn off heat and the small wires on this thermostat when the heats shuts off then power goes to the timer and not before if it shuts off on timed dry timer is ok i would vacuum the dryer make sure all the vent right to the outside is clean as air flow restriction can cause this problem thanks the appliance doc
Sep 15, 2008 | Dryers
Stopped running in middle of cycle
hi thanks for the question when your dryer stopped and you tried to restart if no noise the over load thermostat embedded in motor is suppose to open and not allow it to start then the motor cools down now it works till the motor over heats again and shuts off again. i would vacuum out the inside clean motor and check the venting right to the outside and try it again but remember do this with power off thanks the appliance doc
Aug 31, 2008 | Whirlpool LER5636P Electric Dryer
Shelly on some of the older models they used a inline resistor on the dryers timer. It looks like a inline fuse comming off the timer. If it goes bad the timer will not stop. Check the attachment. Cost around 17.00, Catriver, post back. Part number 3401076
May 09, 2007 | Whirlpool LER2614JQ Electric Dryer
Whirlpool LER3624JQ Electric Dryer Logo
498 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
