Question about HP Photosmart C5180 All-In-One InkJet Printer
Excessive Yellow ink use
Hi. The image of my photos and colour prints are very off correct colour.
It seems to be printing with too much yellow.
This is confirmed that i have only had to replace the yellow cartridge now twice in 3 months, other cartridge use still good... HP originals!!
The pictures also appear darker.
When i first got the printer it was printing perfectly... now RUBBISH.
I have reset factory settings, tried custom settings, printing from different photo editing programmes, alignments etc.
Should i reload software and drivers?
    President:
  • 4,402 Answers
Issue The printer is working, but the colors in the printed output are not the expected colors. The output may look as if only one color has printed, or as if a color has not printed, or as if the wrong colors have been printed. Solution Complete the following steps to resolve this issue. Step one: Check ink levels If the print defect is minor, it might be caused by reserve mode operation. When the printer runs out of some colors, it can continue printing using remaining inks, but print quality may be affected. If cyan, magenta, or yellow is out, the printer can print only in grayscale.
NOTE: HP cannot guarantee the quality or reliability of non-HP ink. If ink cartridges have been refilled, try replacing them with genuine HP ink cartridges. Replace any empty print cartridges. To access the ink level gauge, follow these steps.
  1. Press Setup .
  2. Press Excessive Yellow ink use - c00707172.gif to select Tools , then press OK .
  3. Select Display Ink Gauge and press OK . The ink levels are displayed. Figure 1: Ink levels c00410056.gif
    • Each icon corresponds to the cartridge that is the color of the icon. The icons are also in the same order, from left to right, as the cartridges in the printer.
    • If an icon is empty, the corresponding cartridge may need to be replaced soon.
    • The ink levels in non-HP, refilled, and remanufactured cartridges cannot be read by the printer. Instead of an icon, a question mark is displayed for these cartridges. HP cannot guarantee the quality or reliability of non-HP ink. Printer service or repairs required as a result of printer failure or damage attributable to the use of non-HP ink will not be covered under warranty.
Step two: Calibrate the color If the cartridges have not been refilled and none are empty, try calibrating the color.
  1. Open the printer Toolbox :
    1. Open HP Solution Center (click Start , then All Programs , then HP , then HP Solution Center ).
    2. If you have more than one printer installed, make sure to select the correct printer tab in HP Solution Center .
    3. Click Settings .
    4. Click Print Settings .
    5. Click Printer Toolbox .
  2. On the Device Services tab, click Calibrate Color , then follow the onscreen instructions. The procedure takes about two minutes and requires two sheets of paper.
Step three: Clean the printhead If the steps above did not help, clean the printhead.
  1. Open the All-in-One Toolbox :
    1. Open HP Solution Center (click Start , click All Programs , click HP , and then click HP Solution Center ).
    2. If you have more than one All-in-One installed, make sure to select the correct All-in-One tab in HP Solution Center .
    3. Click Settings .
  2. On the Device Services tab, click Clean the Print Cartridges , and then follow the onscreen instructions. Three levels of cleaning are available.
Step four: Contact HP If the error still occurs, click the link at the bottom of this page to contact HP.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00707165&lc=en&cc=us&dlc=en&product=1153481&rule=45772
Posted on Jan 24, 2008
Desoite changing all the cartridges and running print head cleans - the colours are not coming out correctly - the reds seem to come out much darker (almost pur magenta and the brown /yellow mixes also...
Few things to consider:
Are the new cartridges the same as the ones you took out (same make, same type)? If not this is the likely cause.
I am not to much in to Canon printers but probably like Epson they will have different types of genuine ink, you know longer lasting, brighter etc depending on how much you want to pay. Also you may have had Pigment Ink in before and now have dye inks or vise versa
Are your print setting the same (printers can be adjusted to print draft, text, or photo)
Are you using the same paper? Non-photo paper will significantly dull the colours.
Hope this finds you the reason. Best of luck.
May 04, 2011 | Canon Office Equipment & Supplies
When printing, if I select any other form of paper than "Plain Paper", e.g. "Photo Glossy Paper", the print (of a photo) comes out with a distinct Magenta overhue. The true colours are...
Hello Landscapeman ,
You need to specify the paper type when the print dialog box appears. Heavy glossy paper needs to spend more time in the fuser so that the toner is fixed.
Mar 25, 2008 | Computers & Internet
Colour prints coming out with a lilac hue
check whether the printer is in proper mode or not
Feb 29, 2008 | Epson Stylus Photo 950 InkJet Printer
Hi, I have a Canon Pixma iP4300 printer and the Yellow ink is not printing. I have changed the cartridge and all other colours are working except Yellow. I would appreciate any solutions you may be able...
I have a Canon Pixma iP4300 printer and the Yellow ink is not printing. I have changed the particular cartridge and all other colours are working except Yellow. I have cleansed the printer several times and tried with new Yellow ink cartridges with new chips, but nothing helps.
What should I do?
Jan 25, 2011 | Canon PIXMA iP4300 InkJet Photo Printer
Printer will not print yellow or orange, but prints other colors correctly. Brand new lexmark cartridge.
Yellow is one of the printer's "primary" colours.
Orange is mix of "red" and "yellow".
So, an empty "yellow" cartridge, or clogged ink-jets would cause your symptoms.
Sep 17, 2010 | Lexmark Z705 Photo Jetprinter InkJet
I have refilled my Ink Colour catridge, and now when I print documents the yellow colour can not be printed / come out..please help me
The yellow print head is clogged or you are out of yellow ink. You can try to get it flowing with a warm wet paper towel by rubbing and and pressing it into the towel.
Jun 08, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Ink issues Samsung CLP-510
Some paper tints can cause problems with color images, so make sure that you're using plain white paper, not another color such as beige, yellow, or blue. Even an off-white shade can affect your colors.
In addition, paper type can slightly influence your ink color. Highly absorbent papers can draw in the ink so quickly that the printed image may seem dull or a little washed out. If this is the case, try a coated paper that is specifically intended for color printing. If you're printing those important family vacation photos, use a good-quality glossy paper.
If your colors are way off, you may be running out of one or more ink colors. For example, blue and yellow are mixed to make green, so if your grass seems blue rather than green, you may be running out of yellow. Check your ink cartridges and replace any that are low or exhausted.
Thank you, & post back if you still need assistance.
May 07, 2008 | Samsung CLP-510 Laser Printer
The printer software should have an option for head cleaning & alignment. Make sure to run these maintenance options and see the results. You may need to re-run the tests.
Sometimes generic inks can cause a problem, so after cleaning, try to use an oem cartridge (same company as your printer) and observe the results.
Jan 24, 2008 | Office Equipment & Supplies
Dissapearing yellow
I run about 100+ canon printers from s800 up to the new ip4500.
I have met and solved almost every problem I find described on the web. Your problem with the disappearing yellow ink can be only one thing. The ink cartridge has not been sealed after you injected the ink. If there is even the smallest avenue for air to get into the cartridge it will allow the ink to flow very rapidly back out of the cartridge and into the waste ink pads in the bottom of the printer. You won't be able to see a puddle of ink under the printer until much later when you have done many cleanings or installed many leaky cartridges.
Dec 23, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
R220 colour errors
chech the ink pan below maximum waste overflow, take the injection pump it or enject until ink finish.check ink cartidge or not fully engage the lock.
Nov 15, 2007 | Epson Stylus Photo R220 InkJet Printer
HP Photosmart C5180 All-In-One InkJet Printer Logo
267 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
