Problem for Electric Fans
Generic problem for all Electric Fans
Emerson remote control
Purchased a Emerson Jumbo universal remote control. Have 56" Sony HD Tv, When setting codes, unit went blank and now screen will turn green for a few seconds when the unit is turned on then go blank.
I have unplugged unit several times, even left unplugged overnight. Cannot get the with either old remote or new remote.
No 800 number on product packaging or directions. Very frustrating, can you help?
Thank You
Solution #1
posted on Feb 09, 2008
Rank: Wiz
Rating: 88%, 72 votes
It sounds like you loaded a wrong code to the TV. Though I don't know how. You should have been loading the TV's code to the remote. but if nether remote will work then something got loaded to the TV. check your TV's owners manual. There should be a way to bring everything back to default. Usually by pressing a series of buttons on the menu and turning on the tv. I wouldn't know the set of buttons as every tv is different. But it should be in the owners manual or on the web site. Reseting the tv to default should cure the issue. Sony will help you but they will charge you for the call. If you cannot find the information in the owners manual go to sony's web site and check the FAQ section to see if someone else has had this problem. Sony is usually fairly good with information on the web. You should be able to find what you need to do to take the TV back to default. BEWARE THOUGH! any information you programmed to the tv will be lost when you do this. You will have to reprogram it. (TV channels etc...)
Popular Solutions for Electric Fans
Questions and Unsolved Problems for Electric Fans
I am trying to decide whether to purchase Fanimation Belleria FP4320 with finish that is...
(More)
I am trying to decide whether to purchase Fanimation Belleria FP4320 with finish that is discontinued Aged Copper. When I asked the vendor via email if it had option for light kit, they said "no". I thought this model FP4320 had option for light kit even if this particular vendor did not sell. I cannot buy if I cannot attach a light kit that is available from another vendor for this model. Can anyone confirm this?
Also what is recommendation for this model.
Have a Hampton Bay Ceiling Fan Model # UC7067RC which has been rewired to cause light and fan to run...
(More)
Have a Hampton Bay Ceiling Fan Model # UC7067RC which has been rewired to cause light and fan to run when fixture has power. A loose wire is in the switch box and in the fan which has apparently been disconnected. Need to know how to rewire so light and fan are switched independently. Two switches located in wall electrical box. Only one currently functional.
it's mod 23457-380 and you can hear the electrical contacts but it doesn't turn on or off, but the...
(More)
it's mod 23457-380 and you can hear the electrical contacts but it doesn't turn on or off, but the light still works
fell over now it makes clinking noise and smokes!
I need the part that attaches to the fan blade to the motor. Homlmes Fan#8oM6/Model HASF1516
