Question about Frigidaire Affinity ATF7000EG
Just installed, will not work
Just took delivery of this unit yesterday. Got it plugged in, hooked up to the water, was ready to start washing.
The buttons all work properly to set up for the particular wash cycle, but the unit does not start when the start button is pushed. No water fills the cylinder, nothing.
Should I just call Frigidaire since it's still under warranty??
  • 1 more comment
  • Shadowchylde Jan 24, 2008
    Yes, it's a gently used model and did not have the bolt in it.
    Mistake on my part. I didn't know about the error codes.
    According to the toll free number for Frigidaire, the board is bad with a code 43.
    Thanks for the help, have a nice day.
  • DesertMoon Feb 28, 2008
    The technician replaced the motor and the motor board, error code was resetted to E00. The washer was tested for Normal, Warm/Cold timed at 50... when the timer reached 33, no tumbling action as time pass by... checked the error code and it showed E5E, any solution to this?
  • 770 Answers
Did you remove the shipping bolt in the back of the unit??
Posted on Jan 24, 2008
  • 1 more comment
  • Gary Davd
    Gary Davd Jan 24, 2008
    Call Fridg if it is under warrty they will cost the cost PS I know this sounds like a dumb question but i have to ask " IS the water turned on? Belive me it has happened before..
  • Gary Davd
    HERE are the codes for your machine if you need the manual on this model post your email i will send it in /PDF form 18mb it is a complete teardown book so if you have to replace the board yourself I dont know what your model number ends with but if it is a 0 this is the part you will need #134556600 cost around $122.00 Hope this helps
    Failure code chart
    Failure code Fault condition Check
    E11 Fill time to long. Refer to test (1).
    E13 Water leak in tub or air leak in air bell. Refer to test (2).
    E21 Water not pumping out fast enough. Refer to test (3).
    E23 Drain pump relay on control board failed. Replace control board orwire.
    E24 Drain pump relay on control board failed. Replace control board orwire.
    E31 Pressure sensor not communicating with control board. Refer to test (4).
    E35 Pressure sensor indicates water overfill. Refer to test (5).
    E36 Control board problem. Replace the control board.
    E41 Control board thinks the door switch is open. Refer to test (7).
    E43 Board communications problem. Replace the control board.
    E44 Board communications problem. Replace the control board.
    E45 Board communications problem. Replace the control board.
    E46 Board communications problem. Replace the control board.
    E47 Board thinks the door PTC circuit is open in spin. Refer to test (7)
    E48 Board thinks the door PTC circuit is closed. Refer to test (7)
    E52 Bad signal from tacho generator. Refer to test (8)
    E56 Highmotor current. Refer to test (9)
    E57 High current on inverter. Refer to test (9)
    E58 High current on motor phase. Refer to test (9)
    E59 No tacho signal for 3 seconds. Refer to test (10)
    E5A High temperature on heat sink. Test first if bad replace
    speed control board.
    E5B High temperature on heat sink. Replace the speed control
    E5C High temperature on heat sink. Replace the speed control
    E5D Communication problem. Refer to test (11).
    E5E Communication problem. Refer to test (11).
    E5F Communication problem. Refer to test (11).
    E66 Heating element relay failure. Refer to test (14).
    E67 Input voltage on microprocessor incorrect. Refer to test (15).
    E68 Current leakage to ground on heater or fuse opened. Refer to test (14).
    E74 Wash temperature does not increase. PlaceNTC in correct position.
    E75 Water temperature sensor circuit. Refer to test (12)
    E76 NTC temperature for the cold water valve over the limits. Hot and cold water hoses
    E82 Console control problem Replace the control board.
    E83 Console control problem Replace the control board.
    E91 Selector LEDs do not light up Refer to test (16)
    E93 Console control problem Replace the control board.
    E94 Console control problem Replace the control board.
    E95 Communication error. Replace the control board.
  • Gary Davd
    Gary Davd Jan 26, 2008
    do you want to know how to replace the ctrl board??
Ultra wash ll. Why isn't it draining after it's done?
Did you break out the plug in the garbage disposer so water can go thru it .
Jul 26, 2015 | Kenmore Dishwashers
Brand new whirlpool dishwasher starts on own
Because you cheated and filled it manually, it may be that the second running was actually resetting the programme. Do a normal wash, and if it does it again, contact the maker for advice.
May 10, 2017 | Whirlpool WDF750SAYB Gold Series...
New washing machine model wtw4800xq will not begin fill cycle -delivered yesterday and filled - not today?
Make sure it is level and that the drain hose is hooked up properly and not clogged. Check all electrical and water connections to make sure they are tight and turned on. Other than that You will need to call the people whom you purchased this and have them look at it becasue if you start trying to repair anything by taking it apart the warranty will be void. One other thing you can check is the pump filter under the tub. something may have gotten inside and plugged it up. If there is any water left in the machine it will not start filling.
Jul 03, 2011 | Whirlpool Washing Machines
Start load of wash, starts to spin, no water though, then flashes an F and H, eventually stops and machine starts to beep. I just did wash yesterday and haven't tampered with water levels, so can't quite...
FH means that the machine hasn't detected enough water entering the machine or possibly you have a problem with your pressure switch.
Potential Causes
If there is no water in the unit: • Make sure that both valves at the water source(s) are turned on all the way. • Check for plugged or kinked inlet hoses or plugged screens in the inlet valves • Verify inlet valve operation
If there is water in the unit: • Verify Drain pump operation • Pressure Switch Hose is in good condition and properly connected to Tub and
Pressure switch • Verify there is not a siphon problem • Verify wire harness connections to; Inlet Valves, Pressure Switch, Drain Pump,
Flow Meter, and Central Control Unit (CCU) • Check all hoses for possible leaks • Verify pressure switch operation • Verify flow meter operation • Verify CCU operation
Feb 03, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Hi we have just bought (today) a Zanussi ZWF14069W. It lights up- ready to start but does not start a wash. It has filled with water - which we've managed to drain out to begin a fresh cycle. But it's not...
if its never worked. have you connected the waste hose to a spigot pipe under the sink . check that the blanking plug has been removed from under the spigot or in some cases you have to cut off the end so water will pass. The end of the waste hose has an orange plug in it on delivery if its still in remove it. hope that helps.
Jul 24, 2010 | Zanussi ZWF1430W Front Load Washer
My Servis M6725 washing machine gradually fills with water even when it is switched off. We have tried changing the inlet valve but it still happens.
this is very comon review
decided to buy a Service M6725 machine. I bought one from Argos 'express delivery'. Installed it in a matter of minutes and did a cleaning wash. From then on the machine refused to work. Argos kindly replaced the machine (with the same model) and all seemed fine for a couple of weeks and then for no apparent reason the spin cycle would not perform. Yesterday a Service engineer arrived to 'sort' out the problem. He told me that the no spin was because of an unbalanced load and the machine was working correctly and left me to try more washing. Same result. House full of dripping washing and an angry wife. I am replacing the machine with another brand. ...
Apr 28, 2010 | Washing Machines
The wash cycle starts with a 5 second delivery of water then stop
Aug 11, 2009 | Bosch Nexxt 700 Series WFMC6401UC Front...
Pressure Washer quit running
I have owned four of those units. Every one of them did what you are experiencing or just wouldn't give me any pressure after only a few uses. The company was certainly no help. I gave up after four and bought a heavier gas model from Lowes. Hope this info helps.
Jul 06, 2009 | Karcher 1750 psi Electric Pressure Washer
Bought a new whirlpool estate washer today. brought it home. pulled yellow strap and removed long straight metal pin. (evidently broke 2 shipping pins off because they fell into their little plastic cups...
this is poor delivery,,jostled unit,,,you just broughjt it so your under warranty ,,by the time i tell you what to look for,,the warranty tech will be out ,,its better to let them handle it,,,if you open unit it will void your warranty...
Jan 18, 2009 | Maytag PAV2300 Top Load Washer
Onkyo TX -601 Zone two stopped working
any luck with sorting out the amp?
Feb 24, 2008 | Onkyo TX-SR601 Receiver
Frigidaire Affinity ATF7000EG Logo
220 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
