Question about New Home L-373 Mechanical Sewing Machine
How to intall a needle and thread the needle. Janome New Home Model L-373
I got the machine on Ebay, seems like the pressure foot is missing and also the needle is not there and seems like the needle assembly parts are not correct. Is there any way to figure it out how to install a new needle and I have some needles for a singer machine, they will fit or not in this model.
  • New Home Master
  • 11,732 Answers
Here's a manual for your machine:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0ahUKEwjr7ea5ndvYAhUW5mMKHbqfAm4QFggpMAA&url=http%3A%2F%2Fjanome.com%2Fsiteassets%2Fsupport%2Fmanuals%2Fretired%2Fother-models%2Finst-book-l372l373.pdf&usg=AOvVaw3cjeX4H_xN5Kb3BCsKq2Ut
This company may be able to help with some parts for your machine, ie presser feet and needles:
https://www.sewingpartsonline.com/janome-sewing-machine-parts-model-list.aspx
However, if there are more things missing or not working on your machine, then you will probably need to take it for service.
Posted on Jan 16, 2018
    Genius:
  • New Home Master
  • 2,414 Answers
-If you don't know any thing about the machine why buy it...?
-Reliable parts store might have the part you need, but you need to give them the model and series number to be able to give you the right parts.
Good luck
Mai
Posted on Jan 15, 2018
micromaster
  • 3614 Answers
SOURCE: Singer model 4212 needle threader
hello there,
check this link HERE & HERE
Posted on Jul 16, 2008
Mimito7
  • 128 Answers
SOURCE: howto thread a twin needle on Janome 6019
Hi there. If you have an acessory kit with your machine, there should be a plain spindle with a smaller bottom on it. There should also be a small hole on the top or back of your machine where your thread goes.. And yes you can thread both strands of thread thru the same areas till the needle.
Posted on Apr 28, 2009
  • 240 Answers
SOURCE: The needle doesn't catch the thread in the bobbin
Are you certain the needle is not bent and that it is in the right way around? Which model is it?(I used to sell them)
Posted on Jun 21, 2009
  • 136 Answers
SOURCE: will not pick up bobbin thread
Unusual for this machine. Check to be sure the needle is inserted with the flat side to the back of the machine. If it is, remove the needle plate, bobbin and bobbin case. Turn the hand wheel slowly toward you and see if the point of the hook is above or below the eye of the needle when the hook point is aligned behind the needle. If the eye is above the point of the hook the machine is out of time and best taken to qualified technician.
Posted on Jul 04, 2009
HI there..I'm looking for a guide on how to thread my sewing machine. I can't seem to find any like mine. My machine is a Janome New Home model 630071487
Essential part for any sewist!
Awesome,This thing has made my life so much easier. Easy to use and adjust and no more intense staring at the tiny, faint lines on my machine to make sure my seams are straight.
Amazon com Distinctive Adjustable Guide Sewing Machine Presser Foot Fits...
Feb 14, 2018 | Janome Sewing Machines
Parts Diagram For Needle Shaft.
send ur exact model and brand name ..will get ur schematic diagram soon
Sep 20, 2008 | New Home L-373 Mechanical Sewing Machine
Janome ezy lock 304 missing stitches, i have re-threaded the machine and also put in new needles?
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
Sep 10, 2013 | Sewing Machines
Tension to loose and missing stitches
SKIPPED STITCHES ON A SERGER
1. Is the needle bent or worn--replace
2. Is the needle inserted correctly into the needle holder--check needle
3. Is the Serger threaded correctly--rethread
4. Is the presser foot pressure right for the fabric--adjust
use a scrap piece of fabric to sew on as you adjust the tension
when the tension is to loose adjust one number higher till stitch
looks good
here's 2 links for a manual one is a hardcopy & the other is a
pdf downloadable--one is a different price from the other
http://www.sewingpartsonline.com/instruction-manual-janome-mylock-634d.aspx
http://www.sewingpartsonline.com/instruction-manual-janome-mylock-634d-download.aspx
Sep 08, 2012 | Janome MyLock 634D Mechanical Sewing...
Have a janome master craft 3000, just bought it used yesterday. Was sewing fine then all of a sudden it would stop pushing the material through like the needle was dull or something. Now it's doing it...
First do a process of elemination. Unthread the machine, both top and bottom, take out the needle. Place a piece of fabric under the pressure foot, lower the pressure, and depress the foot control. Does the fabric feed? If it does, then put in a NEW needle, thread up the machine, and see what happens. A dull needle won't prevent the fabric from feeding. If the fabric does not feed with no thread, then you have a pressure foot pressure problem, or a feed dog height problem, or a feed step motor problem, or possibly a board problem. If it only has a problem when you thread it up, then maybe you have a burr on the needle plate and the thread is hanging up on it and preventing the fabric from feeding. Check for all of these and if you still need assistance respond back.
Apr 27, 2011 | Janome Memory Craft 3000
Bobbin thread is phooey and loopy
Is it looping on the bottom of the fabric? If so it it probably a top tension issue, try this this quick test.
With the pressure foot up, you should be able to pull the thread easily right before the eye of the needle and when you put the foot down you should then feel a fair bit of tension on the top thread.
If you do not get tension with the foot down, check this:
-set the top tension dial to 5
-raise the pressure before threading the machine
-"floss" the thread by holding the thread as it comes off the spool with your right hand and holding the thread right before the needle. Make sure to do that with the pressure foot up. What happens is sometimes the thread doesn't go into the tension discs all the way due to lint or something else.
hope that helps,
Chris
Jun 06, 2010 | Janome Harmony 2041
My daughter in law's machine won't pick up the bobbin thread. I've never even seen a bobbin that loads like that so I don't know what to tell her. In fact, I've never even heard of a new home sewing...
New Home is Janome.
The bobbin thread may not be picking up because the needle is in backwards.
Refer to the manual for the machine - some require the flat side of the needle face to the back of the machine and some to the left side of the machine.
May 07, 2010 | New Home L-373 Mechanical Sewing Machine
SIMILAR PROBLEM OF TOP THREAD ACCUMULATING IN BOBBIN AREA
it sounds like a needle threading problem. if you have the instruction book, pull yout needle thread off the machine and re-thread as per the book ie presser foot up and make sure thread goes betwen tension discs and up over takeup lever.
to check needle tension is ok, lower presser foot and pull needle thread through needle, the needle thread should be tight enough to bend the needle a little.
goodluck,
scott.
Jul 28, 2009 | Janome Mini Compact
New Home L-373 Mechanical Sewing Machine Logo
2,339 people viewed this question
Top New Home Sewing Machines Experts
Tally Girl
Tally Girl
Nava Hirshenson
Nava Hirshenson
Level 1 Expert
Are you a New Home Sewing Machine Expert? Answer questions, earn points and help others
