Question about IBM ThinkPad 600X Notebook
Ibm screen error
Dear sir i have ibm 600x laptop
giving a error 00161 & 00163
and also not going in bios setup why????
pls help me
  • sirrob Mar 02, 2008
    I i'm get the 161,163 error codes and the date and time error.
  • petesza Mar 28, 2008
    I replaced the battery and no longer get error 161 an 163, but cannot get into the bios via F1 and still cant boot.  Any ideas?
  • 4,402 Answers
161 - Dead CMOS battery.
163 - Date and time are not set clock not updated.
Replace CMOS Batt: On the bottom of the laptop you will see a screw that holds the memory cover on. (Next to the main Batt) Remove the screw and cover. The CMOS is plugged into the motherboard it is yellow and round tucked in the side of the case. (note how the black cable is towards the center of the laptop and the positive red cable is towards the side of the laptop). Remove the cable connector from the motherboard and pull out the old battery. This can be done by either gently pulling on the cables or using an object like a toothpick and gently tugging at the old battery to free it. With the old battery removed plug in the new battery with the black ground cable towards the center of the laptop and the red towards the side of the laptop. Insert the new battery into the space the previous one set at. Reconnect the memory cover and turn on your laptop. You will have to set the time and date and may have to cycle the computer (reboot) a few times. You can get this battery (CMOS) on eBay or at a computer store they are only a few dollars. (5-8) Good luck in your repair!
you need a cr2025 to replace it you have to pull the tabs of the old one off and tape them to a new cr2025 battery.
Start with the machine OFF. HOLD DOWN and CONTINUE TO HOLD THE "F1" key. WHILE STILL HOLDING "F1", turn the power on, and CONTINUE TO HOLD "F1"
This will get you into the bios "setup." You should check the date, bootup order, etc, and reset.
Posted on Jan 24, 2008
How do i fix my ibm think pad with 161-163 error on start up
Hi drifty169
Looks like you need to change your CMOS battery
Here are the following code descriptions:
Please take time to rate me
Note: for some pointers on how to replace the battery go to this webpage:
161CMOS configuration lost (battery has died)162CMOS checksum error, CRC error, or adapter ID mismatch163CMOS error; Clock is not updating
Oct 19, 2012 | IBM ThinkPad 600X Notebook
Have a think pad 600 type 2645 with eo301 error, there is a display of a padlock w/ no1 and a blinking cursor on the top left corner
This laptop is protected with a Power on Password.
The password is setup from the BIOS configuration.
There is no backdoor password available and you need the password to boot up the laptop. Once you can boot up the laptop you can enter the BIOS configuration to remove the Power on password.
Removing the BIOS battery to restore the factory defaults will not remove the password because the password is stored on an EEPROM chip.
Oct 26, 2009 | IBM ThinkPad 600X Notebook
It says there are error codes 163, 8611, and 163 time and date pop up but if you try and pass that it freezes and shuts down again. please help
The 163 error is a BIOS Date & Time error. Go tinto the BIOS setting and set the Date & Time. If you boot up the next time and you get the same error, this is cause by a flat BIOS battery, replace with a new battery.
The 8611 error relates to the PS2 mouse bus connector, try a new mouse or use a USB mouse.
Jun 14, 2009 | IBM ThinkPad 600X Notebook
How to enter into BIOS when trackpoint was broken.
Hi there.
Its something to do with the trackpoint, possibly the cable has become loose.
* If an emergency power down is made by switching the system off during or while an application is open, then immediately switching the system on creates a 8611 error.
* Repeatedly turning power off and back on without properly shutting down or allowing the system to shut itself down.
Wait at least 6 seconds or longer after shutting down the system or before restarting to correct the 8611 error.
See if that gets rid of the error, if not it could be a loose cable to the trackpoint.
Good luck
Jun 01, 2009 | IBM ThinkPad 600X Notebook
Error 00163 and 00173 on THINKPAD 600X will not let initialize
Dear that is not bios problem but fist you are format all drive in hdd and after install the windows program and your problem is resolve .................ok
Apr 08, 2009 | IBM ThinkPad 600X Notebook
IBM thinkpad 600x
The battery that might be dead is not the main battery. It's the cmos battery, which is a coin cell battery located on the motherborad. It stores the setting in the bios and keeps the date and time accurate. Errors 161 and 163 mean the date and time are wrong. If the cmos battery is dead then, the date and time go back to 1/1/2000 every time the pc is restarted. Thus, you get the "wrong date and time" errors 161 and 163.
Jul 24, 2008 | IBM ThinkPad 600X Notebook
Replaced cmos battery
Try this:
Press and hold F1; then power on the computer. Hold
F1 until the “Easy-Setup” menu appears.
If you have set a password, the “Easy-Setup” menu appears
after you enter the password.
Plagiarized from:
Mar 28, 2008 | IBM ThinkPad 600X Notebook
Troubleshoot IBM laptop
The answer is very simple, Use Restore disc to Reinstall the Operating system.
Feb 06, 2008 | Computers & Internet
IBM Thinkpad Errors
Good evening!
163 & 173 are "date not set" and "configuration data lost", respectively.hat can be caused by the BIOS battery being dead, among other things. The 192 is a fan error, which also can be caused by the BIOS battery being dead. These errors can also be caused by other things, such as a bad system board, etc. But from what you've told us, I'd check that the BIOS battery is up o snuff, or that it may have gotten disconnected.
If you need any additional information, please feel free to ask. If this information has assisted you in the resolution of you problem, please return here to give my assistance an appropriate final rating. If this information has answered your question and/or lead to a resolution, please rate it as "Fixya!".
Thank you, and have a super day!
Dec 11, 2007 | IBM ThinkPad 600X Notebook
Ibm 600x .... cannot detect hard drive larger than 2.1gb .. it can detect 2.1gb below ... i installed winxp on 2.1gb .working fine
ibm is providing their computer with a relevant bios updtes . bios updte will solve most of this type of problems
Dec 02, 2007 | IBM ThinkPad 600X Notebook
IBM ThinkPad 600X Notebook Logo
179 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
