Question about Canon PIXMA MP130 All-In-One InkJet Printer
MP110/130 drivers for vista
I want to instore my canon MP110/130 cd rom on my vista but it is not working. please help me solve it
  • 24 more comments
  • dannyron2 Jan 31, 2008
    thanks guys for the solution to my problem. i got it working now
  • LittleJimmy Mar 08, 2008
    My new computer has Windows Vista and the Canon Pixma MP110/130 will not work becauase I think the drivers are incompatable. What do I need to do?
  • gabra Apr 06, 2008
    I can't install mp 110 too on vista. How?
  • Anonymous Apr 26, 2008
    i need a vista set up cd rom
  • Anonymous May 13, 2008
    MP 130 won't install on Vista
  • axel_bulow Jul 06, 2008
    i want to instore my canon MP110/130 cd rom on my vista but it is not working. please help me solve it
  • Anonymous Jul 11, 2008
  • Anonymous Aug 03, 2008
    cannot print want to download vista
  • Anonymous Aug 05, 2008
    Disc not working due to windows vista
  • Anonymous Aug 07, 2008
    nose que le pasa a mi impresora.
    en la pantalla dice "please wait"... y e esperado muchisimo.
    le puse tinta y no responde..los botones tampoco me funsionan.
    help.!!
  • Anonymous Aug 08, 2008
    Doesnt get installed because of the vista
  • Anonymous Aug 14, 2008
    the drivers of my canon pixma mp 110 / 130 do not work on Windows-Vista. What can I do?
  • Anonymous Aug 31, 2008
    MP110/130 drivers
    problem
  • tunneba Oct 21, 2008
    i need driver for vista
  • lg23 Oct 26, 2008
    i have same problem...i no longer have disc that came with printer...can i download drivers somehow?
  • Anonymous Nov 06, 2008
    i need to connect my cannon pixma 110/130 printer to my laptop using vista
  • arooo2005 Nov 15, 2008
    canonmp110-130series 3 in one
  • MILLERANDREW Nov 24, 2008
    CANON MP110/130 DRIVERS FOR VISTA DOWN LOADING PROMBLEMS
  • ohtakieldin Nov 29, 2008
    canon pixma mp110
  • Anonymous Dec 11, 2008
    same problem ..
  • walleye joe Dec 14, 2008
    2 problems -
    1. Error reporter says paper jamb - no paper is jammed. Followed all trougbleshooter tips not fixed - cleaned roller by hand (maintenance programs don't work because of paper jamb report)
    2. Scanning function does not work - says not supported for Vista
    paper jambed message - paper removed - message still appears - maintenance cleaning doesn't work due to continuing mersage - paper jambed.
  • wishneee Feb 02, 2009
    I have the same problem.What should i do? Can you help me please?
  • Anonymous Feb 03, 2009
    ai change d'ordinateur impossible d'effectue l'installation sous vista
    President:
  • 1,944 Answers
You can download the drivers from Canon. Click on driver downloads and pick the Vista driver.
MP110
MP130
Posted on Jan 24, 2008
    Genius:
  • 1,067 Answers
Make sure u download the vista driver only from cannon website for you model ok
    Guru:
  • 28 Answers
Method #1: Install PIXMA Driver Using CD
Before using this approach, you need to make sure that the system is compatible with CD/DVD drive. You must have an installation disc and USB cable to connect the printer. Here's how to do:
    1.Turn on your printer in which you want to install the drivers. If you're prompted to connect USB to the PC, then connect it, otherwise, don't try to do that
    2.Put the CD into your system and run the setup file. It initiates to launch the instruction wizard, and then continue with the steps to finish it.
    3.Connect your PIXMA printer to the PC using a USB cable. Wait until it recognizes the printer and moves ahead to the next once all goes fine.
    4.Add the values for every step and finish the installation. You can now print from Canon PIXMA printer as it has installed. Method #2: Install PIXMA driver manually via the 'Add a printer' option
    The below instructions will let you know how to download the setup file of the Canon MP130 driver. Check these steps:-
      1.Turn on the PC and then connect your PIXMA printer to the Vista computer. Once it's connected and finishes the startup process, turn on your printer.
      2.Click the 'Start' menu and choose the 'Settings,' and then the 'Printer and Faxes,' followed by the 'Add a Printer' option.
      3.Once the installation wizard starts up, choose the 'Next' option and allow your system to recognize the plug-and-play printer.
      4.Now your PIXMA printer is ready to use as the driver is installed successfully. Method #3: Install Canon Printer driver with downloaded setup file
        1.Go to the Canon's official site. Choose the 'Drivers and Downloads,' and then the 'Driver Finder.' Input the model number in the search box and click the 'Search' option.
        2.Locate your printer in the list and click the 'Download Driver' option. Select the Windows Vista from the drop-down list and your browser will redirect to the download page automatically.
        3.Click the 'Download Now' button and choose to save the file. Wait until the download process completes. Now, open the downloaded file and go through the installation steps and answer the instructions. While the process has completed, you will be informed that it ends. Also, take a test print to make sure that your PIXMA printer is printing correctly.
MP110/130 drivers for vista - find the canon printer driver location in vista-nedlsruhys3nfxnpiivi4xq0-1-0.jpg
Canon Printers Customer Support Phone Number 888 348 1555 USA Technical...
Posted on Apr 11, 2017
How come i cant find the drivers for my printer? printer is a pixma MP 110/130.
Natasha
Posted on Jan 08, 2010
I dont have a cd-rom to install
You can find the drivers at below link. Please choose the drivers/software according to the version of windows you are running on your computer.
http://support-au.canon.com.au/EN/search?canonsearch=1&lang=EN&category=Scanners&series=Scanners+%28Small+Office+-+Home+Office%29&model=CanoScan+N1240U&menu=Download
Please rate this if this solves your problem.
Jun 02, 2009 | Canon CanoScan N1240U Flatbed Scanner
Canon MP500 all in one printer is not compatible with Windows Vista. Is there a solution for this problem, or do I need to buy a different printer?
My Canon PIXMA MP500, purchased in mid-2006, came with the (then) ScanSoft OmniPage SE2 software on a CD. The PC had WinXP Installed. I had no use for the ScanSoft it so I made no effort to install it.
Fast Forward:
Two PC crashes later, July 2009. Using Win Vista Home Premium
LOST, important WinWord document file, only a hard copy available.
I tried to recover, scanning the "Xerox" copy. The SE Version of OmniPage was very complicated but I succeeded in producing a replacement *.doc file.
It appears that newer editions of WinVista contain the right printer drivers for this Canon Model.
Apr 26, 2009 | Canon Pixma MP500 All-In-One InkJet...
Problems installing my printer
From Canon download page download driver for your OS and install it.
Download and follow instructions in user manual too
Feb 22, 2009 | Canon SmartBase MP730 All-In-One InkJet...
I want to ad a PIXMA MP160 to my new Windows Vista. Any problems?
If you have the CD-ROM A:
You can install the software that supports both versions of Windows Vista (32 bit / 64 bit).
- If you have the CD-ROM B:
You can only install the software for Windows Vista 32 bit version, however, you can download/install the software for Windows Vista 64 bit version from the web site - If your CD-ROM is "C" or you do not have any CD-ROMs:
Download/install the software for Windows Vista 32 bit / 64 bit from the Canon WEB page.: (select your OS) http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=13368#DownloadDetailAct
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 29, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Driver printer all-in-one Canon PIXMA MP150 for Windows Vista(Dell)
Disconnect first your canon printer to the pc. if you have CD utility of the canon printer then insert it to the CD/DVD ROM and the install the the softwares. the system will be prompted you to attach the printer to the pc. and follow the on screen instruction..
may this help,
melnavz
PS:
pls do not rate me if my solution not solve the issue and you need more further information. but if is invaluable solution rate me fixya.
May 16, 2008 | Canon PIXMA MP150 All-In-One InkJet...
No VISTA DRIVER!!!!????
Load the XP drivers and run it in compatibility mode. Or right click on the exe files after unzip and mark in compatibility mode xp. Works fine!!
Dec 16, 2007 | Canon CanoScan N656U Flatbed Scanner
Install problem to acer laptop travel mate 2428AWXMI
I had a similar problem - I needed Vista drivers - I downloaded the drivers from here - http://www.canon-europe.com/vista/
Stuart Cowie
Scotland
Oct 13, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Canon PIXMA MP130 All-In-One InkJet Printer Logo
5,067 people viewed this question
old marine
old marine
