Philips tv chassis L9.2A
The tv runs for about 10 seconds with good picture and sound but then turns off into stand-by, with the LED flashing 12 times repeatedly(I actually counted it).
  • martin sithole Feb 04, 2008
    I managed to get a service manual and the code implicated the crt which I replaced and the tv is now ok. Thanks everyone!!
    Tendi...
  • Anonymous Mar 31, 2008
    Philips 32PT6441/37 TV has following code. What does it point to?
    1 short Flash
    1 Long Flash
    2 short flash
    3 short flash
    Thanks,
    Novelist:
    Champion:
  • 211 Answers
The flashing LED is an indication code of a board problem. If the TV is shutting down after a very short period of time, it is an indication the something is heating up. To isolate the problem, you will need to purchase some freeze spray ( component cooler ) at your local electronic shop. turn the tv on and spray an area ( usall about 1/4 of the board at a time ) and try to isolate the bad part ( component ). By repeating this process after a bit of time, you should find the part thats bad when you cool the part and the set stays on until the part heats up again. Then simply replace the part and your good to go. Always use precautions when working inside a tv as the picture tube can have as much as 35,000 volts on it ( can cause bodly harm or death ). DON'T COME IN CONTACT WITH THE WIRE OR GET CLOSE.
Good luck and I hope this has helped
Ed
NC Electronic
Mills, Wyoming
Posted on Jan 24, 2008
No picture only sound.
Engineers are right, you need a new LED panel., or the component that supplies the light to the screen.
Mar 18, 2016 | Philips 55pfl4706df7 4000 Series Lcd...
Philips 26pf9531 reboots
Firmware has to be updated.
Jun 28, 2013 | Televison & Video
Tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Mar 13, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
HD50PLW164 Blue LED blink 10 times fast 1 time slow , TV restarts
For clarification of code/blinks significance you should check at mfg web site .
Sep 15, 2017 | RCA HD50LPW164 50" Rear Projection HDTV
Philips 42PF7220A/37 Chassis Number BP2.3U
I think its something on the picture frame board or on the line output board. I would sway to the line output simply because I think but not sure that error code is linked to the line output stage plus when you unplugged the cable the voltage seems within parameters. Good luck.
Aug 04, 2008 | Philips 42PF7220A 42 in. Plasma Television
Philips 42fd9954-175
Hi, and unfortunately I am facing the same issue. My TV blinks GREEN LED for a few seconds then starts flashing RED led. The result I hear from this is that it is the SSB Panel and the estimated cost for service is $600.00 it sounds like you are STARTING with the problem. I began that way too. If you are under warranty, call Philips NOW!
May 13, 2008 | Philips 42FD9954 42 in. Plasma HDTV
What happens
you have the V17+ chassis. The error code blinks a 2 digit code. So yours is either blinking a 12 for no error or a 21 for xray protect shutdown. Count the blinks carefull. it should blink a number pause then blink the second number. You will no doubt need the service manual. I have a good source for mitsubishi service manuals. Let me know if youd like more info and let me know what you discover with the blinking Led.
Mar 19, 2008 | Mitsubishi WS-48413 48" Rear Projection...
TV making ticking sound when turned on
most times I hear that ticking its the high voltage failure ...most likely a shorted HOT fallowed by flyback. the ticking is your shut-down engaged.
Jan 17, 2008 | Philips 32PT6441/37 32" TV
HV Sound no Picture
Sounds as though there is an intermitant, heat-related problem with the HV transformer. You can order this at a tv parts shop or from Sony (probably more expensive) the part number should be on the part or on a schematic. If not, the parts dealer can look it up from the model number.
Good luck! :)
Dec 27, 2007 | Sony KV-36XBR400 36" TV
Blinking LED and auto turn off
The repair kit comes with instructions for a skilled tech.......
Part # 483531057673 Horiz driver.......All L04.1U Chassis.....T.
Dec 22, 2007 | Philips 32PT6441/37 32" TV
Televison & Video Logo
272 people viewed this question
Top Televison & Video Experts
