Question about Sony PlayStation Portable (PSP) Console
Psp erroe messege
When i try to carry on with my game of fm2008 on the psp, i press load game... and a message reading "load game error" occures!!
I cant go into my game.
Please... how would i correct this?
  • 4 Answers
I know what to do
Posted on Jan 24, 2008
Black screen with text "An error occured....
Error Message: Error Has Occurred
Situation:
The Error Message: Error Has Occurred appears when loading or playing a game disc.
Applies To: All Games
What To Do:
There is likely a problem with the Wii console. Click here to begin the repair process.
Jul 27, 2013 | Nintendo Wii Console
Error 80010087
Check the firmware of your PSP. Some games may not work if the latest firmware is not installed.
You usually get this message if the UMD has errors reading or the UMD is not present or was ejected in the middle of playing a game. You should try testing your PSP with other disks, if it doesn't have the same problem with other disks then your UMD is most likely scratched or damaged.
If you are using a modded PSP then you will get this error if you load a game from the memory stick without having a disk inserted in the drive. Or if the game that you are trying to load requires a higher firmware version. You will need to install a higher modded firmware to fix the error if that is your case.
Hope this helps.
Jun 29, 2011 | Sony PlayStation Portable (PSP) Console
When i was playing Dj Hero 2 a Message pop up and said An erroe occurred Press the ejedt buttonremove the gae disc,and turn off the power to the console.Please read the Wii Operations Manual for further...
Try to turn off the Wii then insert a different disk see if youll still receive the same error. If not then insert the DJ Hero 2 CD then see if it will work. Check if you;ll get an error code if not
Thanks for using Fixya
Jan 24, 2011 | Nintendo Wii Console
I am having psp . game file is showing but once press the game start button game will be stuck. showing message "yhe game could not started 80010013. please give me solution.
This is a common error ........this error occur due to the internal defect caused by crashes in the cd you used
you can fix this easily don't worry .......... their are repair guide available for Sony Psp you can download it and solve your problem just like that ...... Click this link
CLICK HERE to download guide
Dec 10, 2010 | Sony PSP (Piano Black)
Key information timed out for my PSP.
get closer to router, or update the network settings.
Nov 29, 2009 | Sony PlayStation Portable (PSP) Console
I have a psp 2000 slim. I have downloaded
CHECK THAT FIRMWARE FILE IS CORRECTLY LOADED AND CHECK THAT IF THE GAME IS COMPITABLE WITH PSP2000
Nov 05, 2009 | Sony PlayStation Portable (PSP) Slim...
Error 8001002b gta4
try an dput alcohol on the disc and rub real good. if not working remove disc and replace it
Aug 09, 2009 | Sony Playstation 3 (PS3) Console
Psp error # 80010087 The game can not be started
Hi robbimic,
The first thing to check is the firmware of your PSP. You should make sure that your PSP has the latest firmware loaded. Because some games will not work or load up if the latest firmware is not installed or loaded up.
You usually get this error message 80010087 if the UMD drive has errors reading the UMD disc or otherwise the disc is not present or was ejected while in the middle of playing a game or loading a movie. I suggest that you try to testing to see if the problem happens with other UMD discs, if it doesn't then most likely the disc could be damaged or scratched.
Now if you are using a modded PSP then you will get this error if you load a game from the memory stick without having any UMD disc inserted in the drive. Or if the game that you are trying to load requires a higher firmware version installed into the PSP. You will be required to flash a higher modded firmware to fix this error if this is your case.
Hope this helps!
Peace! :)
Oct 21, 2008 | Video Game Consoles & Games
PSP
Well it look like you might not have a WiFi network connection set up yet on your PSP. So This is what you want to do if you have DSL at home and a WiFi router. When you search for a new network connection and you find the one from your home, you will still need the WEP key wich is the most inportant in order to allow you PSP to use that WiFi connection. That must be why you are getting this error messege
Aug 30, 2008 | Sony PlayStation Portable (PSP) Console
Psp internal error
I try to apply a theme and it says an internal error occurs. It freezes when a game starts off my memory stick, then it freezes when i leave the game
Dec 27, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
27 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
