Inserted a disk to install printer - disk did not start - opened and empty tray - disk is inside computer
The CD drive is secured by a small small screw which is located on the under side of the laptop, it normally has a small picture od a cd next to it, if you remove the screw you can slide out the CD drive.
once you have remover the CD drive you can undo the small screws on either side of the CD drive and open the drive and remove the cd, reverse the steps to put it back in the laptop.
However please take care and be gentle
hope this helps
Hi, I think you probably place in without it being flat on the drive. You're going to need to remove the drive to get it out. What type of Toshiba Laptop is it?
