Question about Sharp UX 300 Plain Paper Thermal transfer Fax
I get a "document jammed" message.
I get the message that there is a jam but nothing is in the way i have tried everything i can think of .... what can i do
  • censuslady Mar 14, 2009
    What do the sensors look like, and what is the fuser? I have same problem and have called the co. They said it is not fixable.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Sharp Master
  • 1,363 Answers
1-there is probably a piece of paper on a sensor
2- a sensor is bad
try to locate the sensors and look carefully
there should be no more than three on this model
1-in the paper tray so it knows there is paper in the tray
2-under the drum/toner cartridge and on in the fuser
Posted on Jan 24, 2008
What does the sensor look like?
Posted on Aug 23, 2012
6ya staff
SOURCE:
Hp 5660 photo paper jam from placing in wrong tray.
HP Printers - 'Paper Jam' Error ' HP® Customer Support
https://support.hp.com/ca-en/document/c04348351
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ...
https://h30434.www3.hp.com/t5/Inkjet-Printing/HP...5660-Paper-jam.../td.../4673198 Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ...
https://h30434.www3.hp.com/t5/LaserJet...HP...5660...photo-paper-in/td.../5285421 Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ...
https://support.hp.com/ca-en/document/c04759464 There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ...
https://www.manualslib.com > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
https://www.youtube.com/watch?v=mrjGs1ahOjw
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Jun 20, 2017 | HP Office Equipment & Supplies
How do I override a paper jam error message?
Dear
I am a bit of confused about paper jam but you are able to print but facing difficulties in scanning. I think the document jam is there. Pl. check the ADF (automatic document feeder) a small piece of paper or any foreign mater may obstruct or jammed at the sensor. clearing this may help you.
Thanks.
Feb 25, 2015 | Brother DCP 8085DN
An automatic document feeder paper jam has been detected
my scaner icon window show this messege:
an automatic socument feeder paper jam has been detected. clear the jam and try scaning again
Jan 13, 2012 | HP Scanjet 5590 Flatbed Scanner
PIXMA MX330 Error message "Document in
The sensor may be dirty even if it looks like there is no paper jam. Take a bottle of compressed air and give it a once over. Make sure you don't shake or tip the compressed air as you don't want to fast freeze anything.
If this does nothing, you probably have a failed sensor which will need replacing.
Chris
Aug 18, 2011 | Canon Office Equipment & Supplies
We keep getting the message that the document feeder is jammed but there is nothing in there and as soon as you put even one piece of paper in the error message pops up. Is there an easy fix?
Hey, if you're getting the Jam at Document feeder error even though there is no paper jam. First try turning the machine off and back on, if the problem continues you most likely need to replace the DADF assembly (document feeder) part# 004K07270. The part is a little expensive, but you can buy it as an exchange for your bad one from iteminc.com to save you money. Replacing the part is pretty simple, here is a video that shows you how.
Jul 04, 2011 | Xerox WorkCentre C2424DN All-In-One Laser...
My Documate 152 is saying paper jam but no paper jam
E08 error message which indicates papert jam is caused by lose or mis-alligned input paper tray (automatic document feeder).
Resolve issue by powering off the scanner, opening the paper path section, removing the adf, and then re-seating the adf.
Mar 26, 2010 | Xerox DocuMate 152 Pass-Through Scanner
Message shows 'clear paper jam then press check mark....no paper jammed in printer but it will not reset.
message keeps showing print cartridge cradle cannot move, I have check everything, no paper jams nothing under printer, I am turned off printed but keep getting same message.
Sep 17, 2009 | Lexmark X4530 InkJet Printer
Hp laserjet 1020 thinks it's jammed but it's not
you will have to first disconnect the printer cable and eject the paper from printer tray.
after you should be delete the pending document and uninstall and reilnstall the printer.
best of luck
Aug 30, 2009 | HP LaserJet 1020 Printer
Brother 2820 Says clear scanner jam and press stop
Make sure there is nothing caught where the documents go it. List up the scanner cover and look inside. It may need a separator pad or clean the feed rollers with some alcohol. Lawrence
Mar 23, 2008 | Brother IntelliFax-2820 Laser Fax
Document feeder jam?
So when you copy via docfeeder, everything comes out fine?
Look around where the paper exits the docfeeder...there should be some kind of black plastic flapping piece...the paper pushes it up as it goes through the machine.  If this is stuck up, the docfeeder might think that the paper is stuck inside the feeder.
Oct 27, 2007 | HP OfficeJet 7310 All-In-One InkJet...
Sharp UX 300 Plain Paper Thermal transfer Fax Logo
270 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
amir hamza
amir hamza
k24674
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
