Question about GE Profile Prodigy WPSE4200A
Washer stalls while filling, must press start button to get it going again
I've got the GE Profile Prodigy top load washer. Lately the thing won't fill with water completely unless I check on it, see that it's stopped filling and hit the start button again. It then picks up where it left off. While watching it fill with water the water seems to barely dribble into the washer and makes a humming noise of sorts. I thought maybe it was clogged but every 25'ish seconds of filling the water will suddenly pick up quickly for MAYBE 10 seconds and then go back to dribbling. I do hear a slight "click" as the water fill changes from dribble to waterfall. This has been going on for maybe a month or two. I have yet to check anything really due to fearing ripping the washer open, but I've had enough. Thanks very much.
  • 2 more comments
  • bond1973 Jan 24, 2008
    I did a little more testing when I went down to press "Start" again. We always wash our laundry using cold water (we're cheap and oil isn't). I tried setting it to warm and hot and both settings had no problem filling, once I changed it to cold is start dribbling. Thus, that was my first thought is I'll have to move the washer (it's on concrete blocks to raise it enough for the drain hose to reach where it has to) and remove the cold line and see how much crap there is. I know our faucets get a lot of crap stuck at the screen in them from our well. I'm betting this is it. Thanks for the response and I'll get back on the results. Thanks!!
    I just noticed that. Set the thing to Warm (you're right, all cold rinses) and went down to check it and it was off again, hit start and it started back up. After this load of laundry's done I'm gonna check the screen. Thanks again and I'll report back.
  • bond1973 Jan 25, 2008
    It was the screen. Opened it up and did my best to scrape out the gunk. Fired it up and I've done like 4 loads of laundry lickety, split. Thanks all!!
  • Anonymous Jul 15, 2008
    While filling, the water slows down for a few seconds and then continues normally. Also, it will only fill normally when the lid is up. As soon as you put the lid down the tub will drain. It seems to be draining also as it is filling.
  • 770 Answers
How is the water tempture is it hot water when you have it set on hot?? and vice versa?? you may have a clogged fill valve screen you will need to shut off the water and remove the fill hoses and check the screens that are in the water inlet valve use a opened paperclip to hook and puul them out to cleans Hope this helps If not plz let me know and we can go futher into the mach
Posted on Jan 24, 2008
  • Gary Davd
    Gary Davd Jan 24, 2008
    also that unit i belive only has a cold rinse so if it is clogged you will get the dribble on the rinse but only on the Wash if it is set to cold temp Which to me sounds like the clogged screen
My GE Profile Prodigy WPSE4200A Washer does not spinning for drying and it smells like burning rubber. But it does aggitate for washing. It is a belt issue or could be some electronic device issue?
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Oct 03, 2010 | GE Profile Prodigy WPSE4200A
GE profile top loader, agitator and spin start and stop
Is this a newer model washer? I have one of the newer models and it does the same thing. It is supposed to do that.
May 23, 2017 | GE Profile Prodigy WPSE4200A
Washer stops several times in the middle of cycle
possibly it could be your un-balance switch getting very sensitive to any type of movement of the machine, normally they only actuate during the spin cycle when you have a very off balanced load of clothes
Oct 03, 2009 | GE Profile Prodigy WPSE4200A
Washer does not agitate. Will spin and drain.
bad dogs pull off center cap remove bolt carefully lift off dogs are two pieces that catch to agitate they are minimal cost and are easy to replace they wear out especially with heavy loads!!!Best of Luck to You!!
Jun 28, 2009 | GE Profile WPRE6100G Top Load Washer
Washer only spins
Have you tried to unplug the machine, sometimes the control boards can get stuck and if you unplug it for say 30 seconds then plug it back in, it may reset itself. otherwise you may have to call someone these are very complicated machines.
Jun 19, 2009 | GE Profile Prodigy WPSE4200A
Washer will not agitate or spin
HI,
you can view this site to have some ideas about your agitator problem.
http://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin/agitator-woes
any further question let me know.
thanks,
Mar 29, 2009 | GE Profile WPRE6100G Top Load Washer
Ge washing machine
Door not shut Check that the door is properly shut.Faulty interlock A faulty interlock might not allow the door to shut properly. Find your door interlock here and replace, or contact a qualified repairer.
No power Check the flex, plug wiring, fuse and mains supply for faults.
Faulty on/off switch Check the power light if fitted. Replace your on/off switch.
Water supply disconnected or off If a washer dryer cannot load water it cannot start a wash cycle. Check water supply.
Jul 23, 2008 | GE Profile Prodigy WPSE4200A
GE Profile Prodigy filled with water & won't start
If you don't hear a click when you close the lid, replace the lid switch.
Jan 29, 2008 | GE Profile Prodigy WPSE4200A
Washing Machines Logo
185 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
