Excessive Yellow ink use
Hi there
I have this printer now 12 months. Recently it has started printing out really off colour pictures. Before, photo print quality is 100% BUT no longer!
Using best settings and photo papers.
Have used TWO Yellow cartridges, in past two months, and not had to change any of other colour types,
Photos have yellow "hue" and seem to be darker. So basically i suspect i excess yellow output...
Have tried different settings and reducing yellow, changing colour setting, to no help. Also reset default...
Would reloading the software be an option?
Any ideas
  • srcamarv Dec 31, 2008
    I have a C7280 with the originally supplied cartridges installed. I have done some color printing, but mostly black and white. With the exception of yellow all colors show as essentially full on the ink level monitor. The yellow shows as all but empty and I get constant reminders that it will soon be empty. I'm speculating that basic printing (i.e. black text) uses yellow as well for reasons that don't make sense to me.
    My son has the same printer and does not have hte same problem. Turns out he had set the default printing to grayscale and USE BLACK CARTRIDGE ONLY. From Windows, this option is accessed from the HP Digital Imaging Monitor (on the taskbar) - settings - printer settings - color tab. I'm still looking for a similar option under Mac OS X.
  • RBones Jan 16, 2009
    I have used two yellow cartridges - one of them xl - in less than a month in a new L7680 priniting mostly B&W documents.
    In comparison, I am into my second B&W cartridge and the other color cartridges are about 75% full.
  • 167 Answers
Generally every color Red,Green,Blue use YELLOW!!! That's normal and yellow got the mostly, try to reinstall software but you will not achieve a lot!!! I work with toner cartridge and I tell from experience!!!
Posted on Jan 24, 2008
  • 32 Answers
The printer software should have an option for head cleaning & alignment. Make sure to run these maintenance options and see the results. You may need to re-run the tests.
Sometimes generic inks can cause a problem, so after cleaning, try to use an oem cartridge (same company as your printer) and observe the results.
Hi, I have a Canon Pixma iP4300 printer and the Yellow ink is not printing. I have changed the cartridge and all other colours are working except Yellow. I would appreciate any solutions you may be able...
I have a Canon Pixma iP4300 printer and the Yellow ink is not printing. I have changed the particular cartridge and all other colours are working except Yellow. I have cleansed the printer several times and tried with new Yellow ink cartridges with new chips, but nothing helps.
What should I do?
Jan 25, 2011 | Canon PIXMA iP4300 InkJet Photo Printer
Vertical and horizontal lines when printing photos - HP Photosmar
it sounds as if you may have the picture quality set to draft, its worth a check, especially if printing is ok. Does it print colour writing well too or just black, one of the colour inks may have a block or be low, go into printer settings menu and check what print quality its set for.
Apr 25, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Epson DX4000 printer
Hi..
Try this. Removed the color cartridge. Open the printer settings under Quality and check the box that says print in "greyscale" or "black and white.
This will rule out and color cart problem and also change the printer settings. You will have to change this back to print in Color,
Hope this helped........
Squipps
Feb 06, 2008 | Office Equipment & Supplies
Issue The printer is working, but the colors in the printed output are not the expected colors. The output may look as if only one color has printed, or as if a color has not printed, or as if the wrong colors have been printed. Solution Complete the following steps to resolve this issue. Step one: Check ink levels If the print defect is minor, it might be caused by reserve mode operation. When the printer runs out of some colors, it can continue printing using remaining inks, but print quality may be affected. If cyan, magenta, or yellow is out, the printer can print only in grayscale.
NOTE: HP cannot guarantee the quality or reliability of non-HP ink. If ink cartridges have been refilled, try replacing them with genuine HP ink cartridges. Replace any empty print cartridges. To access the ink level gauge, follow these steps.
  1. Press Setup .
  2. Press c00707172.gif to select Tools , then press OK .
  3. Select Display Ink Gauge and press OK . The ink levels are displayed. Figure 1: Ink levels c00410056.gif
    • Each icon corresponds to the cartridge that is the color of the icon. The icons are also in the same order, from left to right, as the cartridges in the printer.
    • If an icon is empty, the corresponding cartridge may need to be replaced soon.
    • The ink levels in non-HP, refilled, and remanufactured cartridges cannot be read by the printer. Instead of an icon, a question mark is displayed for these cartridges. HP cannot guarantee the quality or reliability of non-HP ink. Printer service or repairs required as a result of printer failure or damage attributable to the use of non-HP ink will not be covered under warranty.
Step two: Calibrate the color If the cartridges have not been refilled and none are empty, try calibrating the color.
  1. Open the printer Toolbox :
    1. Open HP Solution Center (click Start , then All Programs , then HP , then HP Solution Center ).
    2. If you have more than one printer installed, make sure to select the correct printer tab in HP Solution Center .
    3. Click Settings .
    4. Click Print Settings .
    5. Click Printer Toolbox .
  2. On the Device Services tab, click Calibrate Color , then follow the onscreen instructions. The procedure takes about two minutes and requires two sheets of paper.
Step three: Clean the printhead If the steps above did not help, clean the printhead.
  1. Open the All-in-One Toolbox :
    1. Open HP Solution Center (click Start , click All Programs , click HP , and then click HP Solution Center ).
    2. If you have more than one All-in-One installed, make sure to select the correct All-in-One tab in HP Solution Center .
    3. Click Settings .
  2. On the Device Services tab, click Clean the Print Cartridges , and then follow the onscreen instructions. Three levels of cleaning are available.
Step four: Contact HP If the error still occurs, click the link at the bottom of this page to contact HP.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00707165&lc=en&cc=us&dlc=en&product=1153481&rule=45772
Jan 24, 2008 | HP Photosmart C5180 All-In-One InkJet...
Ink won't dry
Unless the problem coincides with a change in ink cartridge, my guess is an incompatibility between the ink and the paper. Could you have changed the paper you're printing on. If so, is the new paper of a different quality? If you're using coated (eg photo) paper, are you printing on the right side? Check the "paper quality" setting on the printer (or the software you're using to drive it) - it needs to match the specification of the stuff you're printing onto. Photo quality papers are capable of absorbing much more ink than plain paper (which is how you get the colour intensity). If the printer thinks it's using photo paper, it will throw out enough ink to get that colour build - leaving a sticky mess if what is really loaded is just plain paper. A.
Apr 28, 2007 | Canon i860 InkJet Photo Printer
Will not print some colours
Rhis seems to be a printer Firmware problem, Nothing for it but to bin the printer and start again.
Nov 13, 2006 | Canon BubbleJet i9950 InkJet Photo Printer
Colour printing
Check the following thread, it might apply to your problem. and just as a printer can be fooled to show a low level ink, I guess it can happen the other way around. http://www.fixya.com/problems-solutions/t103191,p342983/Epson-Stylus-Photo-R300-InkJet-Printer.aspx Good luck
May 19, 2006 | Epson Stylus C64 InkJet Printer
347 people viewed this question
k24674
jasbo
jasbo
